RE: New Seagull Extra 260 180    Gallery
Logged in as Guest
    Search This Thread
Printable Version
ReDUCED Balsa USA Fokker DR-1 Triplane - 1/3 Scale - Kit
Seller:  JSZ
Details:   $1,500.00   |  6/6/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> ARF or RTF >> RE: New Seagull Extra 260 180
Page: <<   < prev  12 13 14 15 16 17 18 19 20 [21]
Login
RE: New Seagull Extra 260 180 - 7/23/2012 12:15 AM
Fl_Matt
Score: 100
Last Login: 6/16/2013
Status: offline
Very Nice. I have a couple pics of some assembly and details I added to the underside. I will try to post them. Next week I will take some assembled photos.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to dodgers72)
       Post #: 501
RE: New Seagull Extra 260 180 - 7/23/2012 12:20 AM
Fl_Matt
Score: 100
Status: offline
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to Fl_Matt)
       Post #: 502
RE: New Seagull Extra 260 180 - 7/23/2012 12:32 AM
dodgers72
Score: 116
Last Login: 6/18/2013
Status: offline
Excellent detail under the wing!! All I did was put some orange stripes under mine. I'm also jealous of you shop!
Chris
Hide Signatures
       Post #: 503
RE: New Seagull Extra 260 180 - 7/24/2012 12:07 AM
Fl_Matt
Score: 100
Status: offline
Thank you, the shop is small but functional, the hard part is trying to keep it organized . The underside of the plane is all white so something has to be done to help keep orientation. The only complaints I have about the plane are weak landing gear and lack of underside graphics other than that I think the Seagull Planes are a great bargin.
< Message edited by Fl_Matt -- 7/24/2012 12:43 AM >
Hide Signatures
       Post #: 504
RE: New Seagull Extra 260 180 - 8/3/2012 12:41 AM
Fl_Matt
Score: 100
Status: offline
Anybody else flying one of these planes?
Hide Signatures
       Post #: 505
RE: New Seagull Extra 260 180 - 8/7/2012 11:40 AM
Ricko1
Score: 100
Last Login: 5/7/2013
Status: offline
Just got my 260 the other day. Been looking for a first gasser and saw this thread and took the plunge after reading the favourable reviews. Looking at sticking a DLE 30 in her. My first impression is to go with the CA hinges in the wings and elevator but will stick pin hinges in the rudder because of the greater deflections.Will replace the stock control horns with longer versions as the originals are far too short. There is no way they can line up on the hinge line. Also considering changing the colour of the underside for better orientation. Pin and epoxy the engine box. Also noted the standoffs that come with the DLE 30 place the drive hub 12mm further out from the firewall so considering replacing them with 50 mm standoffs. Any build suggestions welcomed.
Cheers, Rick
Hide Signatures
       Post #: 506
RE: New Seagull Extra 260 180 - 8/9/2012 1:03 AM
Fl_Matt
Score: 100
Status: offline
Dle just came out with a 35 which has more power and rear exhaust for just a few bucks more. I did not use any factory horns or links but I did use the ca hinges and so far they have been fine. I used 1 life battery 3200 mah for both reciever and ignition with a Wike RC IBEF. This helped keep the weight down on the build and has worked perfect so far.
Matt
quote:
ORIGINAL: Ricko1
Cheers, Rick
Hide Signatures
(in reply to Ricko1)
       Post #: 507
RE: New Seagull Extra 260 180 - 8/9/2012 1:05 AM
Fl_Matt
Score: 100
Status: offline
I also made shorter stand offs for the engine and cut the firewall so the carb can sit half way in the fuse.
Hide Signatures
       Post #: 508
RE: New Seagull Extra 260 180 - 8/13/2012 8:42 AM
Ricko1
Score: 100
Status: offline
Thanks for the idea about the battery, the lighter the better and that's good news about the ca hinges.
Hide Signatures
       Post #: 509
RE: New Seagull Extra 260 180 - 8/13/2012 8:55 AM
Ricko1
Score: 100
Status: offline
Matt,
I see you have not used the stock fuel tank. What size tank did you install and what flight times are you looking at ?
cheers, Rick
Hide Signatures
       Post #: 510
RE: New Seagull Extra 260 180 - 8/13/2012 11:04 PM
Fl_Matt
Score: 100
Status: offline
quote:
ORIGINAL: Ricko1
Matt,
cheers, Rick
Rick,
I used a Dubro 14 oz  tank. I set a timer for 12 minutes and have at least 1/3 tank left at end of flight, so I think I could fly 15-18 minutes with a small safety margine.
Matt
Hide Signatures
       Post #: 511
RE: New Seagull Extra 260 180 - 8/14/2012 10:31 AM
Ricko1
Score: 100
Status: offline
Cheers Matt,
Already got a smaller tank and that will do nicely. I can only manage about 10 mins max before brain fade occurs.
Rick
Hide Signatures
       Post #: 512
RE: New Seagull Extra 260 180 - 12/20/2012 12:55 AM
daddyo79
Score: 100
Last Login: 2/23/2013
Status: offline
Hey folks,
I just bought one of these with a PTE-36r in it and have been looking for some kind of authoritative reference on alignment of the motor. The guy who built this has the motor angled to the left and up (looking from the front to the back of the fuse. I've had one guy tell me that is the exact opposite of what it should be. Yes? No? Maybe?
Hide Signatures
       Post #: 513
RE: New Seagull Extra 260 180 - 12/20/2012 6:23 PM
Fl_Matt
Score: 100
Status: offline
 should be angled to the right by about 3 deg from the perspective of sitting in the plane as if you were the pilot.
Hide Signatures
(in reply to daddyo79)
       Post #: 514
RE: New Seagull Extra 260 180 - 12/20/2012 9:46 PM
bgw45
Score: 113
Status: offline
A little right thrust seems to counteract torque or P-factor and is common. To me, downthrust depends on the way it flies ( what happens on throttle transition/level vs. inverted and other stuff).
Hide Signatures
       Post #: 515
RE: New Seagull Extra 260 180 - 12/21/2012 3:57 AM
daddyo79
Score: 100
Status: offline
Thanks guys. Looks like I have a little work to do.
Hide Signatures
(in reply to bgw45)
       Post #: 516
RE: New Seagull Extra 260 180 - 12/21/2012 3:06 PM
til
Score: 100
Last Login: 6/14/2013
Status: offline
Definitely right and down by 2 to 3 degrees or you can make it straight ahead and mix down elevator and right rudder with increase in throttle.
Hide Signatures
       Post #: 517
Jump to:
Google
SITE MAP!   : :   FORUM RULES
1.227RCU1
