googlydoogly
Joined: 4/1/2008 From: sandy, OR, USA Status: offline
quote:
ORIGINAL: hdbeast OK, that's what I used, mine is white and the green I haven't seen, when I did this to my Sherman I found that the putty would stick to my blade, so I would dip it in water first and that helped seal the putty edges to the surface of the hull. your looks great, man I need to get back to work on mine. Yep, I cannot recommend Milliput highly enough. It's a life-saver. And I can't wait to see your King Tiger when you finally paint it! I started priming again, but I ran out of my gray primer, so I used red-oxide primer. THEN I realized I forgot to add a few details on the turret. :? I added the gun depression stopper on the rear side of the mantlet on both sides. I also forgot to add a third gas detection mounting panel on the rear side of the turret roof. Hopefully, the texturing I did shows through. Done! For a brief period of time during the fall of 1944, The Germans built armor with only the red-oxide primer as the base coat, and the camo colors were painted directly onto the primer. I believe this was done during September-October 1944. I was going to keep it and use the red-oxide primer, but eh. Since there's such a big unresolved debate among modellers and armor historians how this order was implemented, I decided not to use the red-oxide primer as the base coat. I believe Minichamps released a 1/35 Panther with this camo job in mind. So...I decided to paint my panther in dark green base color instead. This was done to all heavy armor from November 1944 to early January 1945. So I'm hoping to base my Panther to a Panther built around November-January. Because in February 1945, I think that the AAMG ring on the cupola was deleted from the Panthers. Here's the roadwheels painted. And here's my Panther with her base coat applied. And here's the muzzle break: Minor **** about the IMPACT muzzle break. The main advantage of aftermarket metal muzzle breaks is that you don't have to spend time trying to smooth away the seam on a lot of two-piece, stock plastic muzzle breaks. Guess what? IMPACT muzzle breaks still has a ugly seam running along the entire length of the muzzle break!!! Why???? Oh wells.
