googlydoogly
Joined: 4/1/2008 From: sandy, OR, USA Status: offline
Sadly, nope. This Panther will definitely need the metal tracks...which I couldn't afford at the moment. (Building two tanks at once with all the upgrade parts). So Here's the basic start of this build. Starting with the tension pulleys. Each pulleys has 9 parts. Good thing there's a good show on TV while I was building this tank. I also installed the suspension housings, torsion bar stays, torsion bars, and suspension arms. Had a bit of a problem with one of the suspension housings, because the srew holes won't line properly. So I had to use brute force. -_- Tension pulleys installed. Metal sprocket wheel guides installed. I prefer this because the sculpt is far more detailed than the stock Tamiya parts. The mechanism deck plate and the two gearboxes installed. I need to remember to break these gearboxes in before I run in outside. Idlers, sprocket wheels, and the roadwheels installed. Each roadwheels are composed of 9 pieces, including the rubber tires. This is probably the most tedious part of the build. Up next, installation of the remaining of the electronics, turret assembly, and detailing of the hull.
