Bigger battery or parallel setup?
Tower Hobbies
Logged in as Guest
  Printable Version
Cell Indicator/Checker
Seller:  mds007
Details:   $11.00   |  7/11/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> Batteries & Chargers >> Bigger battery or parallel setup?
Page: [1]
Login
Bigger battery or parallel setup? - 4/15/2008 3:41:09 AM
jester_s1
Status: offline
I''m only getting 3 flights out of my 600 Mah battery per day before the voltwatch (verified by a good meter) says it''s time to stop, which doesn''t quite cut it. Would I come out better to get another 600 Mah battery and run them together in parallel or just retire the one I have and get a 1200 Mah or more? I like the idea of redundancy in my system but am curious how different the flight times would be. I am also going to have a friend cycle my battery to make sure it''s good.
Paul
       Post #: 1
RE: Bigger battery or parallel setup? - 4/15/2008 4:34:21 AM
SavageX78
Status: offline
If youcan get a higher capacity pack.600mah isnt much these days. And rather than double the weight you could get 1 that has a higher MAh and keep the same weight. And there notthat expensive.
_____________________________
RCs : XXX-T MF2 ~ Xray M18 ~ Micro-T~ E-maxx 3905 ~ Mardave Cobra ~ Old Lunchbox (needs Restoration)
(in reply to jester_s1)
       Post #: 2
RE: Bigger battery or parallel setup? - 4/15/2008 2:43:36 PM
jester_s1
Status: offline
I can get whatever I need and I know the cost is negligable. But I do like the idea of a redundant setup so if I can get the same amount of time out of two 600 batteries as I can out of 1 1200, then I''m inclined to go that route even though it does addd a few more ounces of weight to my plane.
(in reply to SavageX78)
       Post #: 3
RE: Bigger battery or parallel setup? - 4/15/2008 4:35:37 PM
SavageX78
Status: offline
quote:
ORIGINAL: jester_s1
I can get whatever I need and I know the cost is negligable. But I do like the idea of a redundant setup so if I can get the same amount of time out of two 600 batteries as I can out of 1 1200, then I''''m inclined to go that route even though it does addd a few more ounces of weight to my plane.
Well if your not worried about the weight then I see no reason it cant be done. But I dont think its good to run an older pack with a newer pack. I know thats true if your running in series. But im not sure if when running in parallel it matters if there both new or not. I would think it would be ok.
And you should get about th same amout of runtime with 2 600s as you would with a 1200. But that may be affected by your current battery. Once your buddy cycles it you''ll know for sure.
       Post #: 4
RE: Bigger battery or parallel setup? - 4/15/2008 5:31:24 PM
richrd
Status: offline
Interesting thought about redundancy but without extra circuitry a short will still pull down the parallel pack. But still better than just one pack then again battery packs IMHO are the most reliable part of a plane if will maintained. The down side is now two packs to charge separate you can not charge Nixx in parallel & weight just doubled. So I always end up with a higher capacity pack. BTW I use Sanyo HRU 1650 thur 2700 MiMH myself. Go check them out
http://www.radicalrc.com/shop/?shop=1&cart=1633429&cat=19&
Rich
< Message edited by richrd -- 4/15/2008 5:38:16 PM >
       Post #: 5
RE: Bigger battery or parallel setup? - 4/15/2008 6:47:34 PM
RJConnet
Status: offline
One other advantage with the parallel packs is that the internal resistance/impedance is halved so the voltage seen by the servos under heavy load stays a little higher.........RJ
(in reply to richrd)
       Post #: 6
RE: Bigger battery or parallel setup? - 4/15/2008 11:43:47 PM
jester_s1
Status: offline
My plane isn''t that demanding on the batteries to need more current draw capacity. If there isn''t much worry about the batteries going bad, then I''ll just get a higher capacity pack. Thanks for the help.
(in reply to RJConnet)
       Post #: 7
RE: Bigger battery or parallel setup? - 4/16/2008 12:27:20 AM
rlmcnii
Status: offline
jester s1,
Take a look at this page. The 2/3A 1500 is a nice, light pack with good capacity. This place makes a very nice product. If you want to learn a lot about NiMH and NiCd cells read his FAQ''s. It will be time well spent.
http://www.hangtimes.com/sportrxpacks.html
       Post #: 8
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.547RCU1
