StanDouglas
TX, USA Status: offline
Every once in a while I build one that has pitch problems even though I use templates, a router and cut the wings from the same templates and a Feathercut system. When it has happened I simply loosen the wing bolts and place 1/32" shims under the front bolts (given I want to give it more positive incidence) tighten the bolts and fly. If it''s better, but not great, land and add another shim and so on until it''s right. Of course if its getting worse we may need shims under the trailing edge bolts. Once I''m happy, I re-pot the wing saddle with epoxy and filler with the shims in place. The shims become part of the saddle. Your going to find that getting the incidence to within .04 deg is a little precise. And anyway the actual incidence required will be slightly different depending on how well you cut the wing core; wire lag, sanding the skin, incidence of the tail and all the rest. Depending on all the variables you might actually need to alter the engine thrust line as well. Usually Q500''s work well with 0 engine incidence. But some actually require a different set up. You can do all the usual things like for a pattern plane. It''s actually an art form, so it may help to get a local artist help out! Ciao
