Reducing the surface area of the wings for going faster?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Aerodynamics >> Reducing the surface area of the wings for going faster?
Page: [1]
Login
Reducing the surface area of the wings for going faster? - 4/15/2008 10:07:14 AM
p3990013
Status: offline
Hello!
I want to modify my Cessna for flying faster. As the pictures show, I want to reduce the size of the wings (the red color is the are of the wings that will be removed). Do you think it will be succesful or will the plane be unable to fly?
Before:
After:
Also any suggestions for battery? Should I go for a 4-cell? (now I use a 2250 mAh 3-cell LiPo)
Thanks!
_____________________________
http://www.youtube.com/watch?v=CgM0xPnWt4Y
       Post #: 1
RE: Reducing the surface area of the wings for going f... - 4/15/2008 12:19:39 PM
da Rock
Status: offline
Designers in real life reduced wings on regular production airplanes to make them into racing planes. But what they did was to cut the span, not what you propose. There were a number of very good reasons they did what they did. And there are a couple of good (or bad) reasons what you wish to do will cause problems.
Shorter span reduces drag a couple of ways. And that modification keeps the fore/aft aerodynamic balance unchanged. The CG locations that worked before are still going to work. There is the least "collateral damage" from just reducing span.
What you want to do is going to screw the wing''s airfoil over it''s entire span. For example, at the new tips, the profile is basically 90% ailerons, 10% "airfoil". And that airfoil is a screwed one. It''s gone from a smoothly cambered profile to a sort of wedge thing that will have a relatively large thickness to chord ratio. The result is not anywhere like a highspeed profile would be. Also, the part of the wing you''re removing is going to take quite a bit more lift capability for the area removed than simply chopping the span will take. Whacking the airfoil from root to tip is going to screw the airfoil from root to tip. The entire wing is going to lose it''s lift and probably increase it''s drag exponentially.
The original airfoil from root to tip was probably a simple cambered one. Cambered airfoils aren''t the choice for speed airplanes anyway. But start to chop the nose off a cambered airfoil and the resulting airfoil is an even worse choice for speed. The farther out the span, the more nose you chop off the profile at that point the worse that airfoil becomes.
Also, if you look at the remaining wing on your redesign, where is the MAC going to be? Where will the Center of Lift of the whole wing now? The wing is now going to be lifting quite a bit further aft than before. That is going to screw up the balance.
There is a reason the aero engineers just chopped the span. Actually there are a lot of reasons they did what they did. And even more reasons they didn''t do what you propose.
(in reply to p3990013)
       Post #: 2
RE: Reducing the surface area of the wings for going f... - 4/15/2008 12:23:09 PM
da Rock
Status: offline
If the electric motor will take the extra voltage, that''s certainly an excellent way to up the speed. You can look that up on the motor specifications, and also see what prop is recommended at the new voltage.
How much heavier is the new battery than the old?
(in reply to da Rock)
       Post #: 3
RE: Reducing the surface area of the wings for going f... - 4/15/2008 1:16:32 PM
crasherboy
Status: offline
I my opinion,doing that to your wing would be a disaster and most likely you would not fly it long if at all. Of course I could be wrong.
Do unto others as you would be done unto,well most of the time anyway!
       Post #: 4
RE: Reducing the surface area of the wings for going f... - 4/15/2008 1:53:58 PM
p3990013
Status: offline
thanks for the tips! yes, I assumed I would destroy the airplane in the process, that''s why I started this thread. good thing I did that!
(in reply to crasherboy)
       Post #: 5
RE: Reducing the surface area of the wings for going f... - 4/15/2008 2:29:44 PM
seanreit
Status: offline
Rock, I must admit, I''m going through this right now on a different level. I have a wing panel that was 29 inches with 16 inches of sweep and took it down to about 24.5 span and 20 inches of sweep.
Original airfoil was naca 008 root 22.125 and tip naca 0012 about 10 inches.
Same root, tip naca 0010 8 inches.
Goal of course to go faster.
I don''t pretend to understand everything you wrote, but I do want to hear if I''ve done something over the top wrong. The fuse width is about 12 inches wide.
The mind is like a parachute, it works better when open!
       Post #: 6
RE: Reducing the surface area of the wings for going f... - 4/15/2008 6:13:16 PM
BMatthews
Status: offline
Also these little models are often running with as little wing area as you want in the first place. Then there''s the little issue that foam models often do not have the best reputation for stiffness. If you were to truly hotrod this thing for speed you may well find that if you manage to reach racer like speeds then the wings will flex, flutter and rip themselves off the model.
From there it''s all about the motor and prop. Chances are from the look of the prop you have this is not a good motor for flying fast. You probably would be best off to get a motor that has a Kv value in around the 2000 to 2500 range that will turn a small prop at some crazy RPM''s and result in higher propjet like airspeeds.
All in all I would suggest that if you want to go fast you just get a model that is setup for going fast. I believe that there's a version of the Stryker propject ARF foamie that comes with the right motor already. It's mostly the motor and prop that determines the speed of models in this size range. The model design merely determines if it rips itself apart in the air or not.
A couple of options would be to go and buy that Stryker or to get a Speed 400 class racer or if you want to do your own work do a Search in the 1/2A forum for "sheet wing racer" or "swr" to see what some of the guys there have managed to come up with for simple but fun high speed models. It'll still require the right motor to achieve those speeds but the model will be more suitable.
< Message edited by BMatthews -- 4/15/2008 6:18:34 PM >
Bruce-
Proudly wasting balsa since 1965.
Free Flighters go that extra mile........
(in reply to seanreit)
       Post #: 7
RE: Reducing the surface area of the wings for going f... - 4/16/2008 6:13:07 AM
pimmnz
Status: offline
Of course the other way to make this thing go faster is to increase the span. Longer wing equals higher aspect ratio, which means less drag, and lowering the wing loading means that you can fly at a lower angle of attack, again less drag. And the most efficient way of going faster is to reduce drag, increasing power is a poor way of going faster, ideally you need to do both for maximum gain.
Evan, WB #12.
(in reply to BMatthews)
       Post #: 8
RE: Reducing the surface area of the wings for going f... - 4/16/2008 12:48:10 PM
B.L.E.
Status: offline
quote:
ORIGINAL: pimmnz
Evan, WB #12.
Are you trying to say that clipped-wing Cubs fly slower than the regular version?
At high speeds, all wings operate at a very low angle of attack to provide the needed lift. This means that induced drag is low at high air speeds regardless of aspect ratio. What is the aspect ratio of a SR-71 wing anyway?
At high speeds, parasitic drag from the fusilage, engine cooling, and wing wetted area is the biggie.
(in reply to pimmnz)
       Post #: 9
RE: Reducing the surface area of the wings for going f... - 4/16/2008 9:04:32 PM
Nathan King
Status: offline
Parasitic drag exponentially increases as a function of airspeed while induced drag tapers off at high speeds. As airspeed is doubled your drag goes up by a factor of four! Where those curves cross is your best endurance airspeed. Now, parasitic drag can be further narrowed down into form drag and skin friction drag. Form drag is caused by air coming in contact with the frontal area of the aircraft. Skin friction drag is just what the name suggests. Howard Hughes had all rivets installed flush with the body of his H-1 Racer to minimize skin friction drag. He also utilized flowing fillets at the fuselage/wing junction to reduce intereference drag.
A high aspect ratio wing is a bit of a tradeoff since they offer a reduction in reduced drag but have a more parasitic drag. This is why airplanes designed to be efficient at lower speeds typically have high aspect ratio wings. Now parasitic drag can vary by factors as minute as air density but to a much smaller extent.
Essentially, a fast airplane boils down to having as little drag as possible with gobs of power. After all, total drag determines the necessary amount of thrust to maintain a given airspeed. Specifically regarding the original question: Don''t cut the wings like that. I can guarantee you won''t like the way it flies. As Yoda would say, "A modified wing only does not a fast airplane make." It's just not that simple.
< Message edited by Nathan King -- 4/16/2008 9:08:00 PM >
Nate,
WACO Brotherhood #99
(in reply to B.L.E.)
       Post #: 10
RE: Reducing the surface area of the wings for going f... - 4/16/2008 10:09:20 PM
Montague
Status: offline
The whole "make the wing longer" vs. "make the wing smaller" thing depends on what you're starting with, and just how fast you're going.
When designing SSC combat planes, we discovered that more wing area and a longer span made the planes go faster. Faster here meant a top speed around 55-60mph. Obviously, the lighter wing loading was allowing a lower AOA and getting us to a better place on the L/D curve.
On the other hand, as I understand it, one of the reasons for cutting down a wing on a full scale racer is because the origional warbird was designed for performance at a combat weight that's a lot higher than the weight of the stripped down "a flew laps around the pylons" configuration. Less weight means that they could chop wingarea without causing too high an AOA. Someone correct me if I'm wrong on this last bit, but I do know that the "combat weight" of a P-51 is quite a bit higher than the weight of a P-51 with out guns, ammo, armor plate and drop tanks...
Anyway, when modifying a model to go faster, you need to know, did the origional designer put in too much wing, not enough wing, or just the right amount of wing for the speed you want to go. I could see a situation where adding wing makes you go slower and chopping wing makes you go slower, if the origional designer did a good job.
Kirk Montague Adams
RCCA 560
(in reply to Nathan King)
       Post #: 11
RE: Reducing the surface area of the wings for going f... - 4/16/2008 10:24:54 PM
combatpigg
Status: online
P399, if you would like to build a fast little plane with your existing equipment, carve a similar sized wing [to the Cessnas']out of contest grade balsa and build a minimally sized [in cross section]fuselage. Leave off the wing struts and the upper cabin, also make the vertical fin shorter than the Cessnas'. Now you will be all set with a little speedster that will be light enough and tough enough to take pretty much any power source that you can fit within the confines of the firewall.
I build and fly a lot of planes in the 8-11 oz range and have played with various shape and size wings. Try to stay with wing designs that have at least 4 inches of chord and no less than 100sq inches of area for a small speed plane of this weight.
The portions of the wing that you show [above] with the pointed tips would be nothing but dead weight and drag, contributing nothing to lift. Keep in mind that the minimum wing chord for your model is dependent on its' weight, but your model would have to be infinately light to allow that drastic of a taper.
< Message edited by combatpigg -- 4/17/2008 12:52:15 AM >
Led Zeppelin is NOT "old fogie" music.
       Post #: 12
RE: Reducing the surface area of the wings for going f... - 4/17/2008 3:32:49 AM
HighPlains
Status: offline
It's a wee bit more complex than all the above.
As long as you are only flying in un-accellerated flight, span doesn't matter all that much. But most of us need to turn the airplane, so induced drag becomes an issue.
Reynolds visits some ugly truths when chord goes away.
Nobody cares about supersonic designs when designing RC models. Might as well talk about spacecraft.
The wing is the small part of the overall drag when flying level. When you turn, it dominates.
"Pay no attention to the man behind the curtain"
(in reply to combatpigg)
       Post #: 13
RE: Reducing the surface area of the wings for going f... - 4/18/2008 12:09:32 AM
