Advisory: Receiver Connections
Tower Hobbies
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Smart-Fly (Quest Engineering) Support Forum >> Advisory: Receiver Connections
Page: [1]
Login
Advisory: Receiver Connections - 4/15/2008 4:27 PM
rrritchey
Score: 100
Last Login: 11/2/2009
Status: offline
When connecting a receiver to any Smart-Fly PowerExpander or PowerSystem, you should never plug any of the receiver pigtails into any battery port on the receiver. On PCM systems this will usually put the receiver into Direct Servo Control (DSC) mode where it will stop listening to the transmitter and expect commands on the DSC link. On 2.4GHz receivers this will look like a bind plug when put in the BAT/BIND port. It may not immediately turn the bind function on but it may at any time. The receiver connections on the PowerExpanders and PowerSystems are ONLY meant to be plugged into servo output ports. Please e-mail us at Info@Smart-Fly.com if you have any questions.
_____________________________
Robert Ritchey
Owner, Smart-Fly
Hide Signatures
       Post #: 1
RE: Advisory: Receiver Connections - 11/23/2008 10:50 AM
bob_nj
Score: 100
Last Login: 10/5/2009
Status: offline
There is some information going around that the two power leads on my PE Pro for instance, shouldn't go into the power ports on my receiver.
I have a JR 921 for instance which has two seperate power in ports.
Can I in fact put the two leads from my PE Pro to the two power inputs on my receiver?
Also, what is the proper procedure to bind a 2.4 Rx when connected to a PE Pro?
Thanks for the help
Bob
Hide Signatures
(in reply to rrritchey)
       Post #: 2
RE: Advisory: Receiver Connections - 11/23/2008 6:21 PM
rrritchey
Score: 100
Status: offline
Hi Bob,
When you get done hooking up your JR921 to the PowerExpander Pro the two battery ports on your receiver should be empty. The 2 leads on the PE Pro are servo channels as well as supply power to the receiver so the two three lead connectors from the Pro should go into THROTTLE and AUX4. You should leave on of the single wire connections unconnected. When you want to bind, put the bind plug in the BAT/BIND port and then turn on your receiver. After its bound remove the plug. Please let me know if you have any other questions.
Robert Ritchey
Owner, Smart-Fly
Hide Signatures
(in reply to bob_nj)
       Post #: 3
RE: Advisory: Receiver Connections - 11/23/2008 7:31 PM
bob_nj
Score: 100
Status: offline
I'm good now
Love your stuff!
Bob
Hide Signatures
       Post #: 4
RE: Advisory: Receiver Connections - 11/23/2008 7:34 PM
rrritchey
Score: 100
Status: offline
Thanks Bob.
Robert Ritchey
Owner, Smart-Fly
Hide Signatures
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.344RCU1
