Hawk sport.....
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Helicopters >> Century - Predator, Hawk IV, Falcon, Raven >> Hawk sport.....
Page: [1]
Login
Hawk sport..... - 4/15/2008 7:50:06 PM
NITRO_VEEDRIVER
Status: offline
ok all so i sit here and i just traded my electric heli(walkera 60) for a hawk sport 30 size.... without elecs of course. but the walkera is full rtf. so now i ask this. how much info can you guys all give me on this bird... meaning the hawk sport lets here it ... the good the bad and the ugly . i wanna here lots of opinions on this heli pls.....
_____________________________
Drive Dirty!
I REJECT YOUR REALITY AND SUBSTITUTE MY OWN!
       Post #: 1
RE: Hawk sport..... - 4/16/2008 5:43:27 AM
syclic
Status: offline
You are gonna love it. It is not a Hawk Pro, but a good little heli in its' own right.
Going from your Walscara to the Sport is like going from a soap box derby type car to a Honda Civic.
Take your time to set it up properly and it will fly very well and take you from hover to 3D.
I would get the feathering spindle collars from the Hawk Pro as soon as you can once you are into aerobatics. They tighten up the damping, and takes up the purposely designed vertical float (that makes for softer feel for training) in the spindle, resulting in a more linear collective relationship from right side up, to inverted.
< Message edited by syclic -- 5/9/2008 11:53:29 PM >
(in reply to NITRO_VEEDRIVER)
       Post #: 2
RE: Hawk sport..... - 4/16/2008 8:50:08 AM
NITRO_VEEDRIVER
Status: offline
good analogy on it... yes i know its alot different then electric....on a better note i shall be goin to pick the hawk up friday morning .... will post pics of it as is right now .....
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Drive Dirty!
(in reply to syclic)
       Post #: 3
RE: Hawk sport..... - 4/17/2008 11:46:13 PM
syclic
Status: offline
Just a note on your statement "yes i know its alot different then electric."
Actually my analogy was relating to the micro/mini class of electrics you were flying.
My 5 cell electric Century Swift 16 with 520mm blades, flies very much like the Hawk Pro with the powerful Toki 40H in it. And there is not much difference in size either.
       Post #: 4
RE: Hawk sport..... - 5/7/2008 4:03:35 PM
Props4ever
Status: online
Make sure you fly it with Gyro or you rather sell this heli to someone who would...he he he
       Post #: 5
RE: Hawk sport..... - 5/7/2008 8:15:58 PM
syclic
Status: offline
Yes....unless you want your training to progress VERY slowly - do use a gyro, even a basic Yaw rate unit.
< Message edited by syclic -- 5/7/2008 8:18:35 PM >
(in reply to Props4ever)
       Post #: 6
RE: Hawk sport..... - 5/9/2008 12:52:45 PM
NITRO_VEEDRIVER
Status: offline
sitting here waiting on a gyro
Drive Dirty!
       Post #: 7
RE: Hawk sport..... - 5/11/2008 6:09:11 PM
NITRO_VEEDRIVER
Status: offline
got my gyro. its a old mechanical one, but works. i havent tried it outside as of yet . no instructions came with it , but here are the pictures of it and what i found out . asked about it also and the way i have it setup is the correct way.
Click for fullsize
Click for fullsize
Drive Dirty!
       Post #: 8
RE: Hawk sport..... - 5/13/2008 7:28:32 AM
Props4ever
Status: online
Hey Bud,
That's great that you got yourself a Gyro finally, it's worth waiting few extra days just to be safer then sorry. I'm waiting on a gyro now too but not in any kind of rush though.
Let us know your maiden flight's results now that you are ready to fly this heli...
       Post #: 9
RE: Hawk sport..... - 5/13/2008 5:21:01 PM
NITRO_VEEDRIVER
Status: offline
not really ready so to speak. still need balls for the links to go on for servos. but am goin to fire it up some time today just to hear it run. and setup tx. also gotta get wire ties to tie the wires all back and strap the gyro down. its huge so i had to put it infront of the tank.
Drive Dirty!
       Post #: 10
RE: Hawk sport..... - 7/11/2008 1:56:42 PM
chris6414
Status: offline
Hey Guys, just picked up a Mint Hawk sport and was wondering what the difference in the tail drive system was. I saw that there was an upgrade to a constant tail drive system. What exactly does this do and what does the stock Sport have. Does it's tail not continue to rotate in an Auto with the stock configuartion. Thanks for any info.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by chris6414 -- 7/11/2008 2:47:24 PM >
       Post #: 11
RE: Hawk sport..... - 7/12/2008 5:29:29 AM
syclic
Status: offline
The current Hawk Pro and the previous Hawk Sport of three or four years ago, have many similarities, but some very important differences:
1 - The Pro uses a different lower frame - it uses the aluminum one from their Raven 50. This lower frame moves the fuel tank in under the mainshaft to keep the c.g. more consistant as the fuel is burned off, and also acts as a heat sink for better cooling.
2 - The Pro uses some special damping spacers on the spindle that provide harder damping and give a more consistant collective from right side up to inverted.
3 - The Pro replaces all of the pivot points in the Sport that used bushings, with bearings.
4 - The Pro replaced the wire-in-tube tail drive system of the Sport, with a torque tube tail drive system.
All of these can be added to the Sport at relatively little extra cost, and make it a surprisingly capable 3D machine, specially when used with the newer, more powerful Toki 40 or OS 37 engines and a good muffler, like their CN3037.
As for the autorotation system, like most 30's, both the Sport and the Pro, use the standard auto system that does not drive the tail during an autorotation. This leaves more energy in the blade for newbies practicing autos. But once you get proficient enough, and if you want to do inverted, aerobatic and backwards autos, you can always add the relatively inexpensive CTD system from the Raven 50.
< Message edited by syclic -- 7/12/2008 5:34:57 AM >
(in reply to chris6414)
       Post #: 12
RE: Hawk sport..... - 7/12/2008 1:34:40 PM
chris6414
Status: offline
Thanks syclic, makes sense. Can't wait to get her flying. I have been flying a 450 elctric for a year and half now.
       Post #: 13
RE: Hawk sport..... - 7/13/2008 12:38:11 PM
chris6414
Status: offline
