Inrunner and outrunner motors?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Electric Aircraft Universe >> Electric Training >> Inrunner and outrunner motors?
Page: [1]
Login
Inrunner and outrunner motors? - 4/16/2008 12:43:18 AM
dandodge
Status: offline
Ok guys
New to electrics but not RC flying.
What''s the difference between an inrunner motor and an outrunner motor. I''m assuming it has to do with application.
Danny
       Post #: 1
RE: Inrunner and outrunner motors? - 4/16/2008 5:29:11 AM
jdetray
Status: offline
The most obvious difference is that in an outrunner, the fixed windings are on the inside, while the outer can holding the magnets rotates around the windings. With an inrunner, the fixed windings are on the outside, while an inner shaft holding the magnets rotates inside the windings.
- Jeff
_____________________________
My other hobby: www.AstronomyBoy.com
(in reply to dandodge)
       Post #: 2
RE: Inrunner and outrunner motors? - 4/16/2008 10:36:00 AM
whitecrest
Status: offline
quote:
ORIGINAL: dandodge
Ok guys
What''''s the difference between an inrunner motor and an outrunner motor. I''''m assuming it has to do with application.
Danny
Also, outrunners generally produce greater torque while spinning more slowly than inrunners. This allows for the use of larger props in applications requiring greater thrust and slower speeds. Inrunners are good for spinning smaller props at higher speeds in applications that require greater speed at the expense of thrust. You have assumed correctly.
Some things that count can''t be counted, and some things that can be counted don''t count. << A.E.
       Post #: 3
RE: Inrunner and outrunner motors? - 4/16/2008 1:06:49 PM
dandodge
Status: offline
Thanks Guys
(in reply to whitecrest)
       Post #: 4
RE: Inrunner and outrunner motors? - 4/16/2008 5:54:53 PM
-pkh-
Status: online
quote:
ORIGINAL: whitecrest
Because of the torque difference mentioned above, outrunners are typically used to direct drive props, while inrunners are typically used with gearboxes to drive props. Although some inrunners are used to direct drive small props, especially in small, high speed planes.
Direct driving with an outrunner has the advantage of not having a gearbox that can generate noise and suffer mechanical failure. Using an inrunner with a gearbox has the advantage of flexibility, you can choose from a wider range of props, and adjust the gearbox ratio to keep your current draw within the limits of your motor/ESC/battery. With an outrunner, you have a more limited prop selection to keep under your max current limit.
Paul - Helis: Two Raptor 50V2s, Venture 30CP, Blade CX2
Planes: Twist 150, Twist 60, Tribute 36, GP .40 Mustang
       Post #: 5
RE: Inrunner and outrunner motors? - 4/18/2008 1:46:24 AM
Swift427
Status: offline
Which motor (outrunner vs. inrunner) is more efficient = less watts/amps required to power the same direct drive ducted fan.
Is the 5100Kv outrunner a better investment at $63 or the 5100Kv inrunner introductory price of $35. Which one will outlast the other given the same use-care. Please explain.
5100Kv inrunner - http://www.hobby-lobby.com/brushless-eth.htm
5100kv outrunner - http://www.hobby-lobby.com/littlescreamers.htm
Never Give Up, Never Slow Down, Never Grow Old, and Never Ever Die Young
(in reply to -pkh-)
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.844RCU1
