RE: Member Daily Flight Rreports
Tower Hobbies
Logged in as Guest
Users viewing this topic: Wolfpackin
  Printable Version
All Forums >> RC Helicopters >> Electric RC Helis >> RE: Member Daily Flight Rreports
Page: <<   < prev  1 2 [3]
Login
RE: Member Daily Flight Rreports - 5/8/2008 4:34:34 AM
srouthouse
Status: online
you want a linear pitch curve in idle up and %35-%40 for your lowest setting in normal mode.
at midstick you want 0 pitch in both blade,s after setting the swash up level
when i get home i have a link and will post it on how to set up a dx6 which is close enough to get you flying
(in reply to Magic Hook)
       Post #: 51
RE: Member Daily Flight Rreports - 5/8/2008 4:47:02 AM
noobflyer01
Status: offline
hey SR. do you have the settings on the dx6 for the BH450. on my bh in normal mode it flys awesome. but in idle up mode the tail is wagging. not sure why to begin fixing this issue. is it something with the tx i have to adjust? or the gyro? didn't think it was gyro because its fine in normal. i know it has something to do with my dx6.
_____________________________
EF mash rescue Co-ax, HBK2, HBFP, Belt CP, Blackhawk 450
(in reply to srouthouse)
       Post #: 52
RE: Member Daily Flight Rreports - 5/8/2008 6:10:04 AM
srouthouse
Status: online
that is vibration and or slop in the tail linkage issue and i have a 450se that does it to. has nothing to do with the TX or gyro.
same gyro and settings on a new heli and its all perfect and no wagging.
i replaced main bearings and tail bearings and a new pinion gear, then fixed some slop in the tail linkage and stopped most of it.
heres some good base settings http://www.digimemphoto.com/guides/backguide.htm
(in reply to noobflyer01)
       Post #: 53
RE: Member Daily Flight Rreports - 5/8/2008 6:12:37 AM
srouthouse
Status: online
oh 1 flight on the 500, practiced nose in FF amd hovering, inverted hovering a little and the usual rolls and some consecutive rainbows
       Post #: 54
RE: Member Daily Flight Rreports - 5/8/2008 1:26:35 PM
rocket-ron
Status: offline
No flying yesterday(wind),and today it's raining . I did run a pack through the CX though. Looks like more sim time (that's about all I get to do with the lousey weather we are having.) Ron
       Post #: 55
RE: Member Daily Flight Rreports - 5/8/2008 8:25:29 PM
srouthouse
Status: online
1 flight with the 500, had a guy watching so the pressure was on lol
one of the best flights ive pulled off, sure was nice!. inverted hovering, front flips, back flips, staionary rolls. rainbows front/back and from side to side.
no wrecks
(in reply to rocket-ron)
       Post #: 56
RE: Member Daily Flight Rreports - 5/9/2008 2:08:18 AM
Magic Hook
Status: offline
One pack on the 450 testing after repair. Its got a slight head wobble so am changing the main shaft. Finsihed the 500 radio setup just before dark so I could not resist to spooling it up. Awesome machine! Just a one minute hover only six inches high because the light was fading fast. This is going to be a fun heli! I am so addicted that I am already looking at the 600. I just cant decide between the nitro or the electric. Leaning to nitro. LOL
< Message edited by Magic Hook -- 5/9/2008 2:10:20 AM >
TR 450 V2, Xcell 60, TR 500
       Post #: 57
RE: Member Daily Flight Rreports - 5/9/2008 11:44:09 PM
Magic Hook
Status: offline
One full pack on the 500 tonight. Just hovering and side in stuff. Just making sure everything is okay. This thing is the bomb!
       Post #: 58
RE: Member Daily Flight Rreports - 5/10/2008 3:44:05 AM
srouthouse
Status: online
oh ya!! the 500 is great!
2 pacs with the 450, nothing fancy just had fun at the park doing the normal stuff. 3 close calls but no wrecks.
       Post #: 59
RE: Member Daily Flight Rreports - 5/11/2008 4:09:14 AM
Husko
Status: online
1 pack today on my HBFP. Painted some white out on my blades for the first time so I can actually see what they are doing. Very disorientating lol! I don't know if it was the paint on the blades or if there is some other electrical/mechanical problem going on here but I could barely keep it under control in light wind. Also, the plastic piece on my stock landing bar became separated from the main horizontal metal bar. Looks like it was glued on and I think this happened because I attached my anti crash kit incorrectly causing it to pull.
Flying an Esky HBFP. Crashing Belt CP and HBKV2
       Post #: 60
RE: Member Daily Flight Rreports - 5/12/2008 1:34:05 AM
Magic Hook
Status: offline
First thing this am I put a battery in the V2 after going through the head setup to increase the amount of pitch and installing a new servo on the ail. It flew perfect. I played with circles and bailed out of a figure eight twice. Second battery I guess I flew to long. As I was landing it reduced head speed, then quickly just layed over on its side from four feet high and fell out of control into the dirt breaking another freaking servo. I am loosing confidance in staying in control. I am considering a new ESC. Not sure about which one , need to research it. Head speed drops during the flight after reducing throd, and shoots back up at times.
Flew the 500 this afternoon twice. Wind was 15 and gusty and it was no trouble really. Stayed basic with FF, side in hover and spot landings. Side in hover is giving me fits, I will practice that more on the sim. Funny though, after flying the 500, I am a LOT more relaxed with the V2. I really like the 500. So much so that I have put my 600 plans on back burner. I will spend that money on upgrades for the 500 and MORE battery's. So far I am just using the Kong 2500 that I use in the V2. I have the timer on 5 minutes. What a heli! Really fun, love the sound, easy to see.
(in reply to Husko)
       Post #: 61
RE: Member Daily Flight Rreports - 5/12/2008 3:20:03 AM
noobflyer01
Status: offline
hey SR. i managed to stop the tail from wagging. now when i idle up the nose wants to go right. lots of left rudder to keep it in check. in normal mode it is perfect. what should i adjust?
       Post #: 62
RE: Member Daily Flight Rreports - 5/12/2008 4:04:49 AM
srouthouse
Status: online
no idea bud never had that happen.
what is your thottle % midstick in normal mode? raising it closer to idle up % may help
       Post #: 63
Jump to:
