noobflyer01
went to the park with trex this morning. flew 2 packs doing flips and rolls and nose in. For the first time i had it nose in and push the cyclic forward to make it fly towards me. did a hard left bank and flew it around in a circle. . it was awesome. on the third pack i spooled it up and hit the idle switch. it lifted to about 5 feet up and it started doing piros by itself. i had no tail control! . lucky i had some quick reflexes and bought it down to 2 feet and hit the throttle hold switch. whew. no damage. its still crash free. . i went over to investigate what went wrong. first thing i check was the belt. it was LOOSE. now i usually check the belt every 10 flights or so but havn't done so because it was flying so well. took it home and found out the 2 screws on the boom mount was loose. the bad news is that it wont tighten up. i guess i may have over tighten them and its stripped. Luckily i have an extra boom mount from the exi and will swap it out. what a close call. i'm so glad that the belt didn't came loose on the first 2 packs or i would of crash for sure. whew.
_____________________________
EF mash rescue Co-ax, HBK2, HBFP, Belt CP, Blackhawk 450, EXI 450, trex 450 SA, mars 480, mini titan e325, gazaur poseidon.
