Engine shutting off when I brake.
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> HPI Racing >> HPI On-Road >> Engine shutting off when I brake.
Page: [1]
Login
Engine shutting off when I brake. - 4/16/2008 1:15:12 PM
triphop631
Status: offline
Hello all,
I am having a problem where when I brake the throttle arm also moves with the brake arm a little and my engine is shutting off. I know that the carb is getting completely closed and no air is going in the engine so that is why it is happening. My question is, is there a way to stop this from happening. I have loosened the servo screw to almost coming off the servo and it is still happening. I also tried a little grease between the two and same outcome. if there is anything else that you suggest that would be great. I have a Spektrum DX3.0 with a Z590 servo.
thank you,
Mike
       Post #: 1
RE: Engine shutting off when I brake. - 4/16/2008 4:43:35 PM
wyumez
Status: offline
I had that problem yesterday. The problem is not the servo but the idle screw.... Mine was way too rich. Usually the factory settings are dead on but mine got loose for some reason or another.
_____________________________
Hpi Savage, Hpi NitroMt2
Hpi Micro Rs4, Xray M18
(in reply to triphop631)
       Post #: 2
RE: Engine shutting off when I brake. - 4/16/2008 9:25:13 PM
dar123
Status: offline
your idle is set too low! just turn it in until there is a 1-1.5 mm gap in the carb whilst pressing the breaks!
if it isn`t broke get a bigger ramp
(in reply to wyumez)
       Post #: 3
RE: Engine shutting off when I brake. - 4/16/2008 11:39:19 PM
triphop631
Status: offline
I am not sure if you guys are understandind what I am saying. when I press on the brakes the servo arm for the throttle moves with the brake arm. It doesn't move all the way but it moves enough for the carb to shut and the engine cuts off. I tried the idle screw and that works but it idles to high then when I am not on the brakes.
Mike
(in reply to dar123)
       Post #: 4
RE: Engine shutting off when I brake. - 4/18/2008 4:48:26 PM
mkoresh12
Status: offline
I had a similar problem with RS4 Evo+. Except when I started my car it would be at full throttle. I had to take my servo saver off and adjust from there. Take the air cleaner off. Put the brakes on and see how much if carb fully shuts or if there is a gap. If it fully shuts then move your servo saver a couple teeth on the servo. Before you do this make sure your radio adjustments are all set to neutral(actually, you may want to check that prior to, maybe thats the problem, to much rearward travel in the servo). You may need to adjust your brake afterwords. I had to do this with my steering servo as well because it was not properly centered out of the box.
       Post #: 5
RE: Engine shutting off when I brake. - 5/4/2008 11:54:13 PM
NitroTherapist
Status: offline
Adjust the Throttle trim on your radio. If that doesn't work...unscrew the the screw on the servo. lift up the plastic piece thats connected to the throttle arm and turn it clockwise just a little and then just tighten it up.
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.391RCU1
