Montague
Make sure you have at least 2 extra of every screw, bolt, nut, etc on your plane. Including the spinner nut. I don't know how you prefer to make your pushrods, but it pays to have a spare elevator and aileron pushrods already made up and set to length, they have an annoying tendancy to disappear, espeically the aileron rods. I agree with the "one prop per round, plus one on the airplane" rule. The more spare parts you have, the better. After you're really hooked, you can reduce your spare parts somewhat by having spare airframes. It's really nice going to a 6 round contest with 4-5 airplanes all trimmed out and ready to roll. If something breaks, you just go to a backup, which makes the contest a lot less stressful. Wings get damaged more often than fuses, so spare wings are really handy even if you can't build and equip a ready to go plane. While I don't mean to suggest you have to, or even should, run out and set up 4-5 planes, it really pays to have a second ready as soon as you can manage it. Having a backup plane ready to go can be huge. If you can't afford to fully equip it, build one plane, fly it, trim it, save the model configuration in the radio, then pull the engine and radio and put it in a second airframe and configure that. Now if you splatter the airframe, you can just move the engine and RX. Engines get dirt in them, but are usually not broken, same with RXs. Which reminds me, bring carb cleaner or some other means to "pressure wash" the mud out of an engine. I've been to more than one contest where on-field engine rebuilds were done mid-contest. When you do start with multiple airframes, keep with the interchangeable parts thing. I always use the same control horns, screws, etc on every plane, so I can "combine wrecks" to make a flyable plane if I have to. Btw, if you haven't already, score the needle mount on the OS .25FX. It could keep you from replacing the whole backplate. Having a spare needle isn't a bad idea either. Also, a tip when you're building wings, it pays to pick a color scheme and stick with it for a number of reasons. First, you get used to seeing your plane which means you have to think about flying your own plane less. Second, it lets other guys know who you are. Now, that might or might not be a good thing, but personally, as an experience pilot, if I can recognize a newbie's plane, I'll work extra to avoid knocking it out most of the time, and I usually target them late in the heat when they are the only streamers left. Now, if you fly with someone known for picking on newbies, that might not be a good idea, but I don't think there are many like that. Also, if you know what the "hot shots" in your area tend to use a color scheme, it often pays to NOT look like them in the air, as they often attract a lot of extra attention
_____________________________
Kirk Montague Adams RCCA 560
