Building and tuning, Bud Bottle Mufflers.
Tower Hobbies
Logged in as Guest
  Printable Version
BME BME-50
Seller:  gdeezer
Details:   $400.00   |  10/11/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> Building and tuning, Bud Bottle Mufflers.
Page: [1] 2   next >   >>
Login
Building and tuning, Bud Bottle Mufflers. - 4/17/2008 9:20:17 PM
altavillan
Status: offline
This post is to show how to build the Bud Beer Bottle Mufflers, and for sharing tips on tuning and mounting ideas. Feel free to add your own designs or ask questions if you like what you see and want to try building your own.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
I didn''t put the bullet in the fire and you quit talking about my mother! "Cosby, Shop Class, 1968 or so"
       Post #: 1
RE: Building and tuning, Bud Bottle Mufflers. - 4/17/2008 9:30:44 PM
altavillan
Status: offline
Tony, The header lengths for the 115 in the Katana is 6 9/16" from the engine exhaust flange to the coupler, measured on centerline. From the coupler to the lip of the Bottle top is 2 1/8" for an overall length of 8 11/16".
The stingers do not seem to add nor detract power. But are very helpfull for reducing noise and ejecting exhaust oils away from the plane. The headers were adjusted to length for using KS86 cannisters. I can't get the Bud Bottle mufflers any farther forward or they would be 2 1/8" closer. I'll eventualy get around to making a new set of pipes with the bottle farther forward to more closely match the way the KS canns. fit.
(in reply to altavillan)
       Post #: 2
RE: Building and tuning, Bud Bottle Mufflers. - 4/17/2008 10:34:49 PM
tonyc
Status: offline
altavillan, thanks for starting this. I found this picture on the Giants site. We do not know who's it is because the poster of the picture said it was not his. But it gives a view of the BME and a bottle muffler. Perhaps someone will reconize this picture and tell us something about it.
Click for fullsize
       Post #: 3
RE: Building and tuning, Bud Bottle Mufflers. - 4/18/2008 2:07:34 AM
fritzdecat
Status: offline
time to drink some Iron City...New Iron City Bottles
Twist Brotherhood #15 AMA # 871253
(in reply to tonyc)
       Post #: 4
RE: Building and tuning, Bud Bottle Mufflers. - 4/18/2008 7:09:19 PM
mmattockx
Status: online
Since we don't get the aluminum bottles up here, does anybody want to drink a case and then send me the empties?? I brought a couple of empties back from Vegas 18 months ago, but I will need more that that eventually...
PM me if you are serious about shipping some, we can make arrangements off line.
Mark
Waco Brotherhood #4
(in reply to fritzdecat)
       Post #: 5
RE: Building and tuning, Bud Bottle Mufflers. - 4/23/2008 4:20:56 PM
tonyc
Status: offline
What diameter tube did you use for the 115? Did you find something that would fit the nick of the bottle or did you widen the nick?
I did find the Budweiser bottle's. So far I have $6 invested for 4 bottle's. I think this means I need a second twin to use up the extra bottles. Must not be wasteful.
(in reply to mmattockx)
       Post #: 6
RE: Building and tuning, Bud Bottle Mufflers. - 4/23/2008 4:40:18 PM
sscherin
Status: offline
All the stores around here stoped stocking the AU bottles..
I might have to check out the Specialty stores.
AMA #163334
There is no mechanical problem so difficult that it cannot be solved by brute strength and ignorance
(in reply to tonyc)
       Post #: 7
RE: Building and tuning, Bud Bottle Mufflers. - 4/23/2008 5:48:41 PM
coronabob
Status: offline
Where can I get a 1" Flairing punch?
(in reply to sscherin)
       Post #: 8
RE: Building and tuning, Bud Bottle Mufflers. - 4/23/2008 6:57:04 PM
altavillan
Status: offline
Get a long 1" bolt or rod and grind it round. A piece of hardwood dowel should work also for flairing a hole out the back. You will still need something hard/round and close to 1" to be able to hammer the neck out to 1" ID.
Tony almost all exhaust pipes use 1" O.D. material. 50cc and up per cylinder.
No reason why the neck couldn't be cut off where a 1" OD pipe would fit so as not to have to reshape the bottle top.
< Message edited by altavillan -- 4/24/2008 3:34:12 AM >
(in reply to coronabob)
       Post #: 9
RE: Building and tuning, Bud Bottle Mufflers. - 4/24/2008 1:55:16 AM
Nogyro
Status: offline
I know this is for gassers, but I'm using one on my OS AX 120. Mac's header cut to 6" overall length, 3/8 hole drilled in bottom of bottle. That's it..... I may have to give it a try on my next gas project.
Click for fullsize
Click for fullsize
Click for fullsize
Frank
       Post #: 10
RE: Building and tuning, Bud Bottle Mufflers. - 4/24/2008 6:38:05 AM
sscherin
Status: offline
I have an el-cheepo tip for a flaring punch..
I've done it before by working my way up through a series of progressively larger sockets on an extension.
the dowel idea would also work fine.. Use a good hardwood dowel.
AMA #163334
(in reply to Tony Hallo)
       Post #: 11
RE: Building and tuning, Bud Bottle Mufflers. - 4/24/2008 2:31:29 PM
tonyc
Status: offline
Is the flaring tool expand the nick of the bottle to fit the tube or is it just for the outlet in the back of the bottle?
       Post #: 12
RE: Building and tuning, Bud Bottle Mufflers. - 4/24/2008 3:23:21 PM
altavillan
Status: offline
I put the flaring tool in a vice and start working the neck on it by rocking back and forth and using a hammer to expand and flatten the neck until it slides through. Then punch out the back.
(in reply to tonyc)
       Post #: 13
RE: Building and tuning, Bud Bottle Mufflers. - 4/24/2008 8:55:10 PM
