RE: Building and tuning, Bud Bottle Mufflers.
Tower Hobbies
Logged in as Guest
  Printable Version
RCGF 26cc Rear Induction Gasoline Model Airplane Engine
Seller:  jewillis2
Details:   $224.88   |  12/30/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Gas Engines >> RE: Building and tuning, Bud Bottle Mufflers.
Page: <<   < prev  1 [2] 3   next >   >>
Login
RE: Building and tuning, Bud Bottle Mufflers. - 5/20/2008 3:19:52 AM
buck1856
Status: offline
Sure,post some pics so we can see.
(in reply to tonyc)
       Post #: 26
RE: Building and tuning, Bud Bottle Mufflers. - 5/21/2008 3:25:17 PM
tonyc
Status: offline
Vibration mounts from muffin pan.
I bought this at a kitchen gadgets store. They cost about $5 for two pans. They are very flexible and good to 450 degrees.
What I think will work is to cut out one muffin cup with the bordering silicone edge and mount this cup within a light plywood frame and cut a 1 inch round hole in the bottom of the cup to pass the exhaust pipe through it
Click to see fullsize image.
Click for fullsize
(in reply to altavillan)
       Post #: 27
RE: Building and tuning, Bud Bottle Mufflers. - 5/22/2008 3:14:38 AM
buck1856
Status: offline
Thanks for the pic.Ill see if i have any around my stores.
(in reply to tonyc)
       Post #: 28
RE: Building and tuning, Bud Bottle Mufflers. - 5/22/2008 7:48:57 PM
tonyc
Status: offline
High Temperature Copper Silicone. Does it make sense to use this to seal the aluminum tube going into and out of the can? It’s a tight fit anyway, would the exhaust just blow it out?
(in reply to buck1856)
       Post #: 29
RE: Building and tuning, Bud Bottle Mufflers. - 5/23/2008 3:07:08 AM
altavillan
Status: offline
The HT Copper is what I use to make the center plug. The Silicone hose and clamps should seal the ends to the pipe without needing a sealant. But a small dab would lock it in tighter. It will not blow out after it cures.
_____________________________
I didn''t put the bullet in the fire and you quit talking about my mother! "Cosby, Shop Class, 1968 or so"
(in reply to tonyc)
       Post #: 30
RE: Building and tuning, Bud Bottle Mufflers. - 5/23/2008 2:59:33 PM
tonyc
Status: offline
The Coleman Rambler stool had a little surprise for me.
I was surprised to find that the Coleman stool has an inner steel tube in all 4 legs. The tube is 6” long and reinforces the aluminum legs where they are riveted together. This caused me to modify the way the exhaust goes into the can.
Instead of a bunch of 1/16th holes on both sides of the silicone plug my aluminum tube will have a big cut out in front of the plug, 1” long x ¾” wide and then a bunch of 1/16th holes exiting behind the plug. This gives me an open exhaust going into the can and the same exhaust going out as in your picture. I would think this would have no effect on the function.
       Post #: 31
RE: Building and tuning, Bud Bottle Mufflers. - 5/23/2008 4:36:00 PM
altavillan
Status: offline
Ha! Ya never know. You might stumble on another 200 rpm. To keep the tuning length short I'd think you will want the holes to start close to the neck for the 115.
(in reply to tonyc)
       Post #: 32
RE: Building and tuning, Bud Bottle Mufflers. - 5/27/2008 3:39:58 PM
tonyc
Status: offline
Got-R-Done, it was easy. Thanks for the great directions.
Click for fullsize
       Post #: 33
RE: Building and tuning, Bud Bottle Mufflers. - 5/28/2008 3:32:09 AM
altavillan
Status: offline
Nice lots and lots of work Tony. Putting 1/2" stingers on is very easy too in case you run out of things to do And get a 90* snorkel from AI so you can wrap some foam over the intake. These older 115's will become very rare and sought after once everyone has the reedblock fixes. You will not believe how it will run till you get it flying. Nothing compares. So take very good care of it.
(in reply to tonyc)
       Post #: 34
RE: Building and tuning, Bud Bottle Mufflers. - 5/31/2008 8:38:11 PM
Ialwayscrash
Status: offline
I just stumbled across an alternate source for the aluminum bottles. Our local WalMart is selling Mountain Dew in the aluminum bottles now! I bought a couple to use because I don't drink beer .
       Post #: 35
RE: Building and tuning, Bud Bottle Mufflers. - 6/1/2008 4:14:18 AM
buck1856
Status: offline
Im going to have to check my walmart and see if they have them and buy a pack to compare the thickness of the metal.I have to special order mine from the local mart because no one buys them.In my town they buy quanity before quality.Of course in my drinking days when funds were a little low so did i.
(in reply to Ialwayscrash)
       Post #: 36
RE: Building and tuning, Bud Bottle Mufflers. - 6/6/2008 7:00:22 AM
yallaair
Status: offline
Hi!
did you gain any extra power with this "bud-pipe", or was there drop in noise level?
Darn the ground..... and the jumping trees
       Post #: 37
RE: Building and tuning, Bud Bottle Mufflers. - 6/7/2008 2:22:20 AM
buck1856
Status: offline
Go to page 1 and look at post#21.Altavillan already posted his results there.
(in reply to yallaair)
       Post #: 38
RE: Building and tuning, Bud Bottle Mufflers. - 7/6/2008 3:09:15 AM
Whistling Death
Status: offline
Can anyone tell me what this flexable tubing is? Where can I get it?
Click for fullsize
CORSAIR Brotherhood Lucky #13
AMA# 856000
       Post #: 39
RE: Building and tuning, Bud Bottle Mufflers. - 7/6/2008 4:36:01 AM
altavillan
Status: offline
I get mine from Napa Auto parts. It's 1" ID silicone heater hose. Check your phone book for a store like this in your area.
http://www.deltarubber.com/ They carry it in a large amount of sizes and stiffnesses. The Napa stuff is the stiffest with 3 plys. There are single ply's that are very soft and flexible.
(in reply to Whistling Death)
       Post #: 40
RE: Building and tuning, Bud Bottle Mufflers. - 7/22/2008 2:59:35 AM
zahir
Status: offline
hi there,
I am totally new to this but can i use this muffler for 0S 50 fx.
       Post #: 41
RE: Building and tuning, Bud Bottle Mufflers. - 7/22/2008 5:59:00 AM
mmattockx
Status: offline
quote:
ORIGINAL: zahir
hi there,
Nope. We are talking 50cc engines here, not 0.50in^3 engines. Your OS is just under 9cc, less than 1/5 of the ones above. If you need a muffler for your OS Mac's Products, Jett Engineering, Ultra Thrust and others make ones that work. You can also Google "mousse can pipe" and find lots of info here on RCU and the net in general for home made pipes.
Mark
Waco Brotherhood #4
(in reply to zahir)
