da Rock
NC, USA Status: offline
Actually, you're not providing near enough info to get good results from. You need to provide the planform. And some measurements. And don't be surprised if the response isn't too huge. In fact, it's actually true that some wings are going to stall at the tips first no matter what the difference in airfoils is from root to tip. And twisting can't do but so much. It is going to depend on the planform. It's an unfortunate belief in the flying model hobby that there is a way to stop tip stalls. It's just not universally possible. And in most cases it just doesn't happen. Depending on your model's planform, it could be helpful to change the airfoil from root to tip. But helpful is the best promise. Truth is, the advice that's probably going to have as good a chance of working is to simply make the tip airfoil a couple of percentage thicker and build the sucker. BTW, with tapered wings, if you don't reduce the airfoil thickness from root to tip, you get that automatically. (But tapered wings stall at the tips first naturally and aerodynamic twist can't stop that in most cases.) Whomever helps you will probably need to know the root chord and tip chord to even begin to help.
