Crash Campbell
Joined: 4/18/2007 From: Port MacquarieNew South Wales, AUSTRALIA Status: offline
Hi Mark, Hopefully the Wallabies may give the All Blacks a "run for their money" in the Bledisloe cup this year. I'm an eternal optomist! Your build looks good and I second your idea of changing the U/C. The mods on mine are alloy mains bolted with 1/4" nylon bolts to a piece of alloy angle, cf tailwheel assembly, fiberglass cowl, pull/pull on individual elevator halves as well as the rudder, two servos for the four ailerons and powered with a Saito 125a. Set your control throws to the recommended for the test flight but make sure the elevators are on dual rates for landing the min throws arn't sufficient to flair properly. Make sure you have the strip before reducing power to sink in, (from about 1/4 throttle on mine). Good luck, Colin
