Goldberg Ultimate Biplane Engine
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Kit Building >> Goldberg Ultimate Biplane Engine
Page: [1] 2 3 4 5 6 7   next >   >>
Login
Goldberg Ultimate Biplane Engine - 4/17/2008 11:47:58 PM
fallingleaf
Status: offline
Hi All. I think my previous post was deleted Grrr. Essentially I am transitioning from an UltraSport 60 with an os61fx (my seccond glow plane after a basic trainer) to a more snappy aerobatic plane. I love bipes so am thinking of building an Ultimate biplane (Goldberg kit). I love fourstorkes and the scale sound they have but alas, I live in New Zealand and by the time I factor in shipping this won't be a cheap build. So I am looking at two strokes for the plane and am thinking of the os120ax. I fly traditional aerobatics but 3d does interest me, although I am not building this kit of that purpose.
So what do people out there, (from your experience with the plane) think about this engine/plane match? Will the 120ax be too much power or should I be looking at a lesser two stroke? I don't want to rip the wings off or anything! Or alternatively is there anyone would knows of a comparable fourstroke that will give me good performance and a price similar to the 120ax ($249US)?
Thanks for the help! I would like to do a build thread once I get it too!
       Post #: 1
RE: Goldberg Ultimate Biplane Engine - 4/18/2008 12:10:20 AM
daveopam
Status: offline
If you have the 1.20 it will be good but a little overpowered. A .90 size two stroke is perfect for sport flying. The plane your talking about will fly fine even on the heavy side.
David
_____________________________
"Choose your shirt and shoes by the color. Choose your friends by their character." unknown
(in reply to fallingleaf)
       Post #: 2
RE: Goldberg Ultimate Biplane Engine - 4/19/2008 9:39:26 PM
alfredbmor
Status: offline
I have built the same bipe and use a Magnum 4 stroke 120 size and I feel that it does not have the punch I am looking for, the engine is taching a little higher than 9000 rpm with a 15 x 6 wood prop. (15% nitro fuel). I understand that the OS 120 AX can handle bigger props using the same amount of nitro and I am planning to aquire it this month at Tower, This month is on the best 100 deals and I can use the three months payment convenience.
Saito Club Member
(in reply to daveopam)
       Post #: 3
RE: Goldberg Ultimate Biplane Engine - 4/19/2008 10:18:13 PM
fallingleaf
Status: offline
Thanks for that alfred, that the sort of advice I am looking for. I considered that 120 fourstroke magnum as a possibility given its good pricepoint, but that feedback about its performance relative to the Ultimate really helps! I am sure with the 120ax I will have power a plenty to spare, but I always figure its better to have more power than no enough. Least it will swing a bigger prop which will appear more scale, and I can always dull down the pitch a little so the plane doesn't end up on mars. I was thinking a Zinger 15x6-10 initially then see what happens.
Does anyone know if the stock 120ax muffler with the 90degree adapter will fit inside the ultimate cowling? Or is is necessary for a hug cut-out to make it fit? Cheers!
(in reply to alfredbmor)
       Post #: 4
RE: Goldberg Ultimate Biplane Engine - 4/20/2008 7:50:39 AM
eurof2
Status: offline
I thought mine was going to be overpowered with a ST 90, but a 1.20!!! That thing should take off vertical!!! Should be fun though as long as the balance is kept correct.
       Post #: 5
RE: Goldberg Ultimate Biplane Engine - 4/20/2008 12:11:37 PM
fallingleaf
Status: offline
Choice! Well I bit the bullet and just ordered the shipment of goodies off tower including the 120ax. i am hoping the 'powerbox' muffler will fit in the cowel with minimal trimming and I hear it is slightly tuned to the engine which is a good thing in my book. Prefer not to mess around with a pitts muffler if I don't have to despite the added looks advantage ofthe pitts! 16oz tank with fuel filler valve and initally a 15x10 prop as reccomended in the 120ax manual.
Will be going with dual elevator servos (dependant on balacing) either at the rear or at the stock location, pull-pull rudder and two aileron servos. I may custom build my landing gear out of some durallium I have lying around (approx 3mm thick...nice and strong + LIGHT)....just for those who are interested. Thanks to those who chimmed in on this thread!
(in reply to eurof2)
       Post #: 6
RE: Goldberg Ultimate Biplane Engine - 4/21/2008 5:39:09 PM
alfredbmor
Status: offline
I installed a 16 oz tank on mine, it also has a smoke pump installed in the CG. My Engine is around 32 oz I believe that the OS 120 is almost the same weight. I did the dual elevator option and instll them at the rear of the fuse, here is a link to my build.
http://www.rcuniverse.com/forum/m_4913575/mpage_3/key_carl%2Cgoldberg%2Cultimate/tm.htm
I hope it can be helpful.
Saito Club Member
       Post #: 7
RE: Goldberg Ultimate Biplane Engine - 4/21/2008 6:00:26 PM
mmattockx
Status: online
I built the Ultimate a lot of years ago and used a ST90 on it. It was somewhat porky at around 8.5lbs and the 90 flew it fine for sport flying and IMAC style aerobatics. It did not have unlimited vertical like everybody wants now, but it would pull straight up for a solid 350-400ft. I think the 120 would be a great match (it does have a throttle, after all) and the plane will not be grossly overpowered with it. The weight is no issue, the model has near 1000sqin of wing and a bit of extra weight will not be noticeable. It also makes a great candidate for a small gas engine for this reason.
A couple of things to know with the 120 up front:
1) Do not use the single aileron servo, it will not be strong enough. Use a servo in each wing panel for a much stiffer arrangement. You can flutter the ailerons with a lot of power and the standard single servo set up.
2) A dual elevator servo set up would be a good idea as well, considering the extra power and engine weight to offset.
3) You may have prop clearance issues with a 15" prop. I ran a 13x8 and had no problems but I never tried bigger so I never worried about it.
Hope it turns out good for you,
Mark
Waco Brotherhood #4
       Post #: 8
RE: Goldberg Ultimate Biplane Engine - 4/21/2008 8:38:10 PM
alfredbmor
Status: offline
quote:
ORIGINAL: mmattockx
Mark
Mark, you are right about dual aileron set up, when I built mine many other builders had it done the same way, I just followed the right way.
As for fluttering I used clear monokote at the upper side of the hinge lines to reduce the risk, I am still aware of it everytime I fly it.
About the prop clearances do not worry about that I have tried the 16 x 6 and clearance is ok but it is to much for my engine to load fine so I am flying with a 15 x 6 by now, that is the reason why I wanted to change for an OS 120 AX. (I am using the stock wire landing gear)
Saito Club Member
(in reply to mmattockx)
       Post #: 9
RE: Goldberg Ultimate Biplane Engine - 4/21/2008 9:29:22 PM
fallingleaf
Status: offline
Cheers guys, that's great feed back. I am sure ow that I made a good choice in that engine...its all shipping now so the fingers are twidling for a good winter build! I am currently building a Greg Chapman 'Omega' sailplane off some plans at the moment so once that is done I am sure I will have the building skills back up to scratch...a little rusty!
Most of my build methodology and choices for the ultimate have actullay been inspired bt your build thread Alfred and also Truwood's (which sadly met its demise on the maiden flight). I will definately be using dual aileron servos and twin elevator ones too. Whether in the centre or rear of the fuse will be determined on balancing. Im not really a fan of having the servos so exposed at the rear so may mount them internally similar to the ailerons. Having siad that, such an option could be complicated to install so may just stick them in like everyone else has. I wil also be sealing all control surfaces in the same method Alfred has, but on both sides.
I don't know too much about props but from consensus the 15x10 seems to be the best suited to the Ultimate and the 120ax, and clearance appears to be good from some pictures I have seen. Anyone have expierience with what prop would go good? 16x8 seemed a little big for me and I want to keep te rev's up to maintain fuel draw (not using a pump) but not at the expense of over-reving the engine!.
I am also thinking of simply getting some aluminium landing gear rather than that stock wire...looks a little thin! Any opinions on the quality of the ABS cowling? Obviously ibreglass would be better but If I can live with the stock ABS I will (I don't have a bottomless wallet!).
       Post #: 10
RE: Goldberg Ultimate Biplane Engine - 4/22/2008 12:36:04 AM
alfredbmor
Status: offline
My ABS cowling is still there (With some cracks and patches), fair enough but lighter than the fiberglass and that is why I keep it.
I will be ordering the engine by the end of this month so I can't feed you back with prop options by now.
Saito Club Member
       Post #: 11
RE: Goldberg Ultimate Biplane Engine - 4/22/2008 11:45:08 PM
fallingleaf
Status: offline
Thanks for that, great to get feed back from friendly fellow modlers! I will see what the cowling is like when I see it in the flesh and then make a call...I can always order the fiberglass one at a later stage. I may actually reinforce the ABS one with a little fiberglass around the seams and any cutouts for good measure if I go that way.
       Post #: 12
RE: Goldberg Ultimate Biplane Engine - 4/23/2008 12:41:14 AM
Chuckar
Status: offline
I have a YS 120 in mine it has more than enough power I am using the ABS cowl no big problems yet I think the O.S. 120 would be great I have TNT gear 3/16 thick the engine is swinging a APC 16-7 love this plane.
Click to see fullsize image.
Click for fullsize
       Post #: 13
RE: Goldberg Ultimate Biplane Engine - 4/23/2008 1:27:57 AM
2slow2matter
Status: offline
