Saito 100 muffler manifold problem.
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Glow Engines >> Saito 100 muffler manifold problem.
Page: [1]
Login
Saito 100 muffler manifold problem. - 4/18/2008 1:11:27 AM
Gauch
Status: offline
I've had to replace my muffler manifold (pipe between engine and muffler) twice in the past 4 weeks. Each time the break was at the section of the threads next to the header end of the pipe. Both prop and spinner are balanced. Very little engine vibration observed. Horizon Hobbys solution is to replace the pipe free of charge but they have no idea of what's causing it or how to prevent it from happening again. Any thoughts.....
       Post #: 1
RE: Saito 100 muffler manifold problem. - 4/18/2008 1:42:48 AM
w8ye
Status: offline
There are three different designs of these.
Straight all threaded
15 degree bend
30 degree bend
_____________________________
I've attended the CutFinger Institute of DirtNap University for years but never did graduate....
Club Saito Member #7
Original AMA #31261
(in reply to Gauch)
       Post #: 2
RE: Saito 100 muffler manifold problem. - 4/18/2008 2:16:41 AM
pumbadog
Status: offline
I have a Saito 100 and the original pipe broke at the thread as you described. My LHS had one that was bent at an angle instead of curved, it fit so I bought it. So far this ones ok. The wall thickness on these is really thin and then when it's threaded, it's worse. If yours is like mine, it would get loose and have to be retightened regularly. I think when these are torqued down it stretches the thread and creats a crack then just breakes off. Luckily mine was held to the aircraft by the pressure line so I didn't lose the muffler.
(in reply to w8ye)
       Post #: 3
RE: Saito 100 muffler manifold problem. - 4/18/2008 2:29:17 AM
Broken Wings
Status: offline
My guess would be a manufacturing defect. If you had a thread micrometer you could measure the minor diameter of the thread and see just how much material is left holding the muffler/header pipe on the engine.
It's probably getting thin right at that joint. The header gets hot, cold, hot, cold and work hardens until it gets brittle and breaks or cracks. Maybe you could fabricate a small aluminum stay or bracket to help keep the muffler from moving. Kind of like a motorcycle "P" clamp.
Just a thought.
Regards,
John
(in reply to w8ye)
       Post #: 4
RE: Saito 100 muffler manifold problem. - 4/18/2008 2:51:51 PM
blw
Status: offline
The straight, all threaded manifold is meant to be a breakaway type.
The ultimate responsibility of pilots is to fulfill the dreams of the countless millions who can only stare skyward...and wish.
(in reply to Broken Wings)
       Post #: 5
RE: Saito 100 muffler manifold problem. - 4/21/2008 6:23:25 PM
chuck993
Status: offline
I have a Saito 100 sitting in a box, third time the muffler broke and it broke the cylinder and Horizon will not fix it, they claim they never heard of this before and I posted this info in another thread and some Saito ***** reamed me, they believe it can't be true and that it must be my fault, the Saito ***** always claim they have never heard of a problem with Saito or mufflers even though I've run into several people with the same problem as mine...$300 piece of junk...O.S. is a much better engine and much better quality, go to O.S.
< Message edited by blw -- 4/22/2008 2:19:03 PM >
(in reply to blw)
       Post #: 6
RE: Saito 100 muffler manifold problem. - 4/21/2008 7:11:42 PM
Hobbsy
Status: offline
How about a picture there Chuck, I have 17 Saitos, I've never broken a muffler nor ever had one come loose. I don't buy it.
Giant Saito, 73.2 Cu. In., 70.5HP @ 5,800 rpm, 79 ft. lbs torque @ 3,500 rpm, 57 mpg, 3.50 bore, 3.81 stroke. 563 lbs.
(in reply to chuck993)
       Post #: 7
RE: Saito 100 muffler manifold problem. - 4/21/2008 8:30:27 PM
chuck993
Status: offline
yeah right...none of the Saito nuts ever believe that something could be wrong with Saito...search the forum, open your eyes, that's how I found this one...LOL
drink the Saito Cool Aide!
(in reply to Hobbsy)
       Post #: 8
RE: Saito 100 muffler manifold problem. - 4/21/2008 8:54:59 PM
wcmorrison
Status: offline
quote:
ORIGINAL: blw
Thats not a bad thing, better to break a pipe than a head. I had have Clarence Lee fix my head, albeit it was a OS four stroke, but same issue.
Cheers,
Chip
(in reply to blw)
       Post #: 9
RE: Saito 100 muffler manifold problem. - 4/22/2008 2:38:18 AM
scott17
Status: offline
I posted pics of 2 broken in a row on my saito 56. I ended up going with a flex pipe. It happens....
(in reply to wcmorrison)
       Post #: 10
RE: Saito 100 muffler manifold problem. - 4/22/2008 1:41:49 PM
Hobbsy
Status: offline
Chuck, I'm not only a Saito nut but also an Enya, Fox, Webra, SuperTigre, Irvine, LASER and OS nut.
       Post #: 11
RE: Saito 100 muffler manifold problem. - 5/10/2008 11:48:22 PM
Gauch
Status: offline
Meanwhile, back at the ranch.....#3 broke today.......
       Post #: 12
RE: Saito 100 muffler manifold problem. - 7/3/2008 9:05:27 PM
bingo field
Status: offline
I was just looking to see if someone had found a method to secure the pipe. The original on my 91 split off after about 50 flights, Horizon sent me a new one, no questions asked. But this one keeps loosening up on me. I love the way it runs, but hate having to keep tightening the manifold.
http://www.tailhook.org/AVSLANG.htm
Sign over Ready Room Door: "Complacency Kills" - Thimk
(in reply to Gauch)
       Post #: 13
RE: Saito 100 muffler manifold problem. - 7/5/2008 3:04:57 AM
bingo field
Status: offline
#2 just broke. Exactly like the first. The pipe breaks where it exits the head. Does anyone have any suggestions?
(in reply to bingo field)
       Post #: 14
Page:   [1]
Page: [1]
Jump to:
