Pz III conversions
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Tanks >> War Room >> Pz III conversions
Page: [1] 2   next >   >>
Login
Pz III conversions - 4/18/2008 3:56:12 AM
pattoncommander
Status: offline
Before I start on some pz IVs, one of which is already an f2, here are my conversions to variations of the workhorse Pz III, I now have ausf, L,. G, N, H, Sig33, Russian SU-76i and Japanese type,97. My ausf M Flammenpanzer is nearing completion but photo merely shows the flame gun. As soon as the early ausf E kit is on stock again, I will add that. .
Any more Pz III variations out there?
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 1
RE: Pz III conversions - 4/18/2008 4:00:22 AM
pattoncommander
Status: offline
oops...doubled up on the sig 33 and missed the Japanese 97
Click for fullsize
(in reply to pattoncommander)
       Post #: 2
RE: Pz III conversions - 4/18/2008 7:34:10 AM
borealis
Status: offline
I would have liked to sse a build thread about the Jap 97. Did I simply miss it?
       Post #: 3
RE: Pz III conversions - 4/18/2008 3:11:55 PM
The_Stuff
Status: offline
i'd like to know more info about the russian one.
_____________________________
RC''s are like pringles... you can''t have just one!
(in reply to borealis)
       Post #: 4
RE: Pz III conversions - 4/18/2008 10:06:08 PM
pattoncommander
Status: offline
the Russian SU-76is from Modellino, very good kit and you can go two ways with it, use the Pz III TC cupola or a flat plate like an SU-85.
(in reply to The_Stuff)
       Post #: 5
RE: Pz III conversions - 4/18/2008 10:10:20 PM
pattoncommander
Status: offline
I did take a few shots as I was doing it....I'll have to resize my photos and put them on the web...probably tonight. Also some on the SU-76i. Thanks for asking...it was a (female dog) of a job and I lost elevation/depression of the gun, but it runs nice. Have to have metal tracks to give it that typical WW II Japanese slack track look. I did take out one link so i could run a bit faster, but with the sloppy track, it really looked good.
       Post #: 6
RE: Pz III conversions - 4/19/2008 2:15:28 AM
pattoncommander
Status: offline
Here's the rebuild photos on my SU-76i
Get the kit from Peter at Modellino@t-online.de. Peter also has some photos of museum artifacts that he can forward. I believe I also got the Russian crew from him.
Really basic. Strip everything off the fenders of the Pz III. Remove turret and take out elevating mechanism. Make a platform to support the mechanism, mount the gun brackets, install gun. Attach a stiff wire to the back of the gun to link with the elevating cam.
Mount superstructure with hatches etc ect, then fuel drums, paint, add decals, dirt, etc. The SU-76i is really an easy conversion and would be really simple to set up with an DBU. A very well made kit and takes very little sanding and fitting. Disconnect the MG sound....the SU-67i didn't have one...or what the heck, mount one for the commander or put a captured German SMG in his hands.
I had the uniforms painted to light in these photos, but since have redone them in a proper dark brown (artillery, not grey tank uniforms). Used a lot of dullcoat.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 7
RE: Pz III conversions - 4/19/2008 2:53:19 AM
pattoncommander
Status: offline
OK, Here's the rebuild of my japanese Type 97 Shinhoto Chi Ha. Tank based on one from the 71st Tank Regt, 2nd Armored div, luzon, Phillipines 1944. Re Japanese Tanks 1939-45 Osprey Vanguard.
Removed turret and reconfigured with sheet styrene. Lost elevation/depression of gun due to the style and location of the gun mount.
Reworked suspension by disconnecting shocks from 1 & 6 roadwheels and connecting them to the tube. (before doing this, suggest moving the main board as this tube will cover the mounting screws.) Buildup of bow and diver sections. this must deviate from the real tank just a bit and build a bit higher, to allow clearance of the gears. (same Stu problem). Add muuuucho rivits from round styrene rod. Rebuild all exterrior with sheet styrene, add mufflers from scrap leftovers. (something new?) It was necessary to add a stiff tenor saxophone spring into the 1-2-3 road wheel supports, as the metal track was too heavy for the Pz III spring in the 1st road wheel. (I heated it and melted it in place.) Finally painted the tank IAW with colors and pattern on my photos from APG, added 21st Century Japanese figures and decals from a 135 scale model of the same tank. It's a real great runner and historically a very good tank. The HV 47mm gun was very accurate and could take out a Sherman at 500 yds.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 8
RE: Pz III conversions - 4/19/2008 3:14:39 AM
pattoncommander
Status: offline
this is a test...twice I have submitted the additional 4 photos for the Japanese tank and they still haven't shown up....
       Post #: 9
RE: Pz III conversions - 4/19/2008 3:17:18 AM
pattoncommander
Status: offline
try again,
the wheels I filled in with Hardware stoere washers, (same as my T-34/76) the sprocket with modelling putty (until i find a smaller one to fit) and made a filler for the idler from steet styrene.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 10
RE: Pz III conversions - 4/19/2008 3:28:26 AM
pattoncommander
Status: offline
OK, I performed a vertical intercourse on photo numbers, but the second set never did get there...the finished tank is shown on my initial post. It's a neat tank and I'm thinking about doing another Japanese tank. [)]
       Post #: 11
RE: Pz III conversions - 4/19/2008 5:44:11 PM
swathdiver
Status: offline
Bill, Are you going to do a PZIII H Befehlswagen? How about the weapons carrier with the wood superstructure in place of the turret?
James -
You do have spare boards, don't you?
       Post #: 12
RE: Pz III conversions - 4/19/2008 10:28:43 PM
Leon01
Status: offline
All I can say is Wow. Talk about mod Skills. I like them all fine collection. The 97 has to be the rarest and your conversion is amazing.
LOL I have trouble just petting a basic model kit together let alone something like you have done
< Message edited by Leon01 -- 4/19/2008 10:31:34 PM >
1/24 VS Abrams 1/24 VS Leo 1/16 Tamiya Tiger 1/16 Tamiya Sherman HL Pershing HL Tiger MS has me down but not out.
(in reply to swathdiver)
       Post #: 13
RE: Pz III conversions - 4/19/2008 11:31:48 PM
