Eclipse 7 question
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Hitec/MultiPlex Radios- Ask Hitec Customer Service >> Eclipse 7 question
Page: [1]
Login
Eclipse 7 question - 4/18/2008 4:09:15 AM
mr.edzadventure
Status: offline
I need a new radio and I'm not totally sold on spread spectrum as of yet. What receivers are compatible with the Eclipse QPCM ? And can you change the Module on the transmitter to a FM to take advantage of a smaller receiver for a Foam plane. I have yet to own a Hitec Radio but it looks like it has a ton of flexibility for allot of different applications. Thanks
_____________________________
"Lay down your burdens by the riverside","Take a deep breath and go for a Ride".
       Post #: 1
RE: Eclipse 7 question - 4/18/2008 4:36:06 AM
mglavin
Status: offline
The Eclipse QPCM TX is capable of working with nearly any PPM RX, single or dual conversion as well as specifically with Hitec’s QPCM RX’s. The only caveat’s are the RX channel band/frequency must match that of the TX.
QPCM like other PCM equipment is manufacturer specific, you cannot mix equipment brands. A Hitec QPCM RX is the only RX that will work in the QPCM mode.
The TX is programmed to work with either PPM or QPCM modulation and the appropriate modulation shift for the PPM RX in play. The TX frequency module matters not, it will work in either modulation scheme.
Michael Glavin
RCU Community Moderator
Hitec * Multiplex Field Representative
(in reply to mr.edzadventure)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.221RCU1
