MVVS 26CC IFS
Tower Hobbies
Logged in as Guest
Users viewing this topic: gdryer
  Printable Version
All Forums >> Glow Engines, Gas Engines, Fuel & Mfg Support Forums >> Engine Manufacturers Direct Support Forum >> MVVS Support >> MVVS 26CC IFS
Page: [1]
Login
MVVS 26CC IFS - 4/18/2008 7:40:50 PM
mc1982
Status: online
Hey guys,
What is the best prop to use on the mvvs 26cc with pitts and with tuned pipe silencer? I want to mount the pipe if the plane allows it but i dont know what prop to use can anyone with this engine help me out?
       Post #: 1
RE: MVVS 26CC IFS - 4/18/2008 7:58:24 PM
pe reivers
Status: offline
with a pitts, go for 16x10 to 18x8, depending on what you want to do and your plane weight
with the tuned pipe, the range will be much the same, but you will see a substantial rpm increase.
When you shorten the header and remove the end section of the tuned pipe, a 16x8 or 16x10 will scream.
_____________________________
Pe, Dealer for MVVS, MTW and Mejzlik; www.mvvs.nl
There is sanctuary in analisys.
(in reply to mc1982)
       Post #: 2
RE: MVVS 26CC IFS - 4/18/2008 11:07:57 PM
mc1982
Status: online
Sounds good =) my plane will be 5.5kg max. How can i remove the end section of the pipe?
(in reply to pe reivers)
       Post #: 3
RE: MVVS 26CC IFS - 4/19/2008 5:15:49 PM
pe reivers
Status: offline
Check out Mark Fues at
http://tech.flygsw.org/all_about_evolution_26_gt.htm
       Post #: 4
RE: MVVS 26CC IFS - 4/20/2008 7:27:37 PM
mc1982
Status: online
I have the engine and pipe now, i dont intend to cut it unless i can find someone that knows what they are doing because i dont have any good way of cutting the pipe like the picture. What prop should i go for with just the pipe?
       Post #: 5
RE: MVVS 26CC IFS - 4/21/2008 11:56:58 PM
pe reivers
Status: offline
18x6
       Post #: 6
RE: MVVS 26CC IFS - 4/27/2008 8:03:04 PM
mc1982
Status: online
Thanks!
       Post #: 7
RE: MVVS 26CC IFS - 4/27/2008 8:03:41 PM
HW50
Status: offline
I have a 18x6 MenZ S prop on my 26 IFS which is fitted with the MVVS tuned pipe.
I got 8640 rpm with the engine a little on the rich side. Is that good?
Helge.
       Post #: 8
RE: MVVS 26CC IFS - 4/27/2008 10:17:47 PM
pe reivers
Status: offline
you seem to be running too rich. With settings as they should be, rpm will be about 8800 - 9000 (conservative estimate)
I got 8200 rpm on APC 18x10, which is a slender blade design.
(in reply to HW50)
       Post #: 9
RE: MVVS 26CC IFS - 6/10/2008 3:47:47 PM
asmund
Status: offline
quote:
ORIGINAL: HW50
Helge.
I get 8900 rpm on the very same prop, haven`t tried to lean it more, but I think there`s even more in it
(in reply to HW50)
       Post #: 10
RE: MVVS 26CC IFS - 6/10/2008 5:59:33 PM
pe reivers
Status: offline
8900 is fine, and allows the engine to unfold.
When using larger props, you are better off using an extra shim under the head. The engine then runs even "smoother".
(in reply to asmund)
       Post #: 11
RE: MVVS 26CC IFS - 6/19/2008 9:52:04 PM
Adrenalin2m
Status: offline
Hi guys, what are all the differences between the new 26 IFS SP and the old 26 IFS other than the head and carb stack?
       Post #: 12
RE: MVVS 26CC IFS - 6/20/2008 9:14:56 AM
pe reivers
Status: offline
heavier crank/conrod
beefed up lower rod bearing
modified crankcase
Only is SP: narrower, deeper hemi head to allow side plug (resulted in wider squish zone)
(in reply to Adrenalin2m)
       Post #: 13
RE: MVVS 26CC IFS - 6/20/2008 11:59:03 AM
Adrenalin2m
Status: offline
quote:
ORIGINAL: pe reivers
modified crankcase
Thankyou sir, I will wait until they become available at our Canadian dealer, Dave Moen in BC and buy the SP model instead of the old model that he has in stock.
       Post #: 14
RE: MVVS 26CC IFS - 9/6/2008 10:32:51 PM
ottertok
Status: offline
Hi, the link you have provided for the pipe mod doesn't seem to work. I have the new 26 IFS SP and would like to mod my tuned pipe. Could you help with the picture please.
Ed.
       Post #: 15
RE: MVVS 26CC IFS - 9/7/2008 1:41:21 PM
pe reivers
Status: offline
Mark's page seems to be down.
from google cache:
