RE: OFFICIAL!!! Kyosho Evolva
Tower Hobbies
Logged in as Guest
  Printable Version
CEN Racing CT4S - RTR
Seller:  solidgold5
Details:   $200.00   |  7/15/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC On Road Nitro Cars >> RE: OFFICIAL!!! Kyosho Evolva
Page: <<   < prev  1 2 3 4 5 [6] 7 8   next >   >>
Login
RE: OFFICIAL!!! Kyosho Evolva - 5/11/2008 1:09:32 PM
GYNAIKAS
Status: offline
Well OK then. Other questions about the setup sheet?
_____________________________
I simply love perfection...do something as good as you can or don't do it at all...
(in reply to Osirisf16)
       Post #: 126
RE: OFFICIAL!!! Kyosho Evolva - 5/11/2008 4:23:10 PM
Osirisf16
Status: offline
Well, first here the picture of the setup sheet again so you easily see it without seeing it in page 5 :
Kyosho Evolva M3 - OS VZR / Kyosho MP777 SP1 - OS Vspec / Hyper 8 - OS Vspec / Baja 5b
I CAN FLY, WHAT EVER THAT MEANS.
(in reply to GYNAIKAS)
       Post #: 127
RE: OFFICIAL!!! Kyosho Evolva - 5/11/2008 4:26:33 PM
Osirisf16
Status: offline
12th line: CAMBER ANGLE = it's simple the angle about the camber, right? Ok, next one...
13th line: TOE ANGLE = here a pic of what it is:
From that pic, you can understand, rigth: Ok, next one...
14th line: Front width = i think this is the width of the front evolva. I mean the width between the left front wheel untill the right front wheel, right???
       Post #: 128
RE: OFFICIAL!!! Kyosho Evolva - 5/11/2008 5:22:52 PM
GYNAIKAS
Status: offline
Everything you said is right. But you should have the same offset at both sides (left/right). I mean you should "unscrew" the bolts of the left and right side at the same width. If you still can't understand my explanation I'll explain at MSN soon.
       Post #: 129
RE: OFFICIAL!!! Kyosho Evolva - 5/11/2008 5:38:28 PM
Osirisf16
Status: offline
I think i know what you are talking about. MSN soon? With the others? When? Inform me, will ya?
       Post #: 130
RE: OFFICIAL!!! Kyosho Evolva - 5/11/2008 8:57:17 PM
GYNAIKAS
Status: offline
Don't worry! I will once i talk to everyone.
       Post #: 131
RE: OFFICIAL!!! Kyosho Evolva - 5/11/2008 9:22:40 PM
Osirisf16
Status: offline
17th line: Antiroll bar = i know what it is, but i can't understand those options the sheet has. What are they?
       Post #: 132
RE: OFFICIAL!!! Kyosho Evolva - 5/11/2008 10:09:41 PM
Pillbots
Status: offline
Its the angle the blade type anti roll bar is. The more inclined the stiffer it is.
< Message edited by Pillbots -- 5/11/2008 10:11:22 PM >
Serpent 960 ''08
Schumacher fusion
       Post #: 133
RE: OFFICIAL!!! Kyosho Evolva - 5/12/2008 9:02:57 AM
GYNAIKAS
Status: offline
Well imagine that circle with the line in it as the head of a screw. As you go from the 1st to the last one is like turning it anticlockwise. Collari has marked position 1 but I used the second one.
(in reply to Pillbots)
       Post #: 134
RE: OFFICIAL!!! Kyosho Evolva - 5/12/2008 11:13:07 AM
Osirisf16
Status: offline
Sorry guys, but i didn't understand of what you told me. I know what the antiroll bar (i think) but i can't imagine something like that in the sheet. Can you paint a picture of mine in page 4 and post it?
       Post #: 135
RE: OFFICIAL!!! Kyosho Evolva - 5/12/2008 1:30:13 PM
Pillbots
Status: offline
This is a front anti roll bar upright (more inclined) (l)
And this is it lay down (or less inclined) (-)
Serpent 960 ''08
Schumacher fusion
       Post #: 136
RE: OFFICIAL!!! Kyosho Evolva - 5/12/2008 2:01:09 PM
GYNAIKAS
Status: offline
Exactly! Thank you Pillbots!
       Post #: 137
RE: OFFICIAL!!! Kyosho Evolva - 5/12/2008 3:14:07 PM
Osirisf16
Status: offline
That part you showing me i can spin it arounf if i want. That's it, right? Here a pic:
But what is the purpose? Where is better? What difference is betwwen the horizontal position (-) and the vertical position (I).
I think i have it in vertical position now.
       Post #: 138
RE: OFFICIAL!!! Kyosho Evolva - 5/12/2008 7:50:17 PM
GYNAIKAS
Status: offline
Horizonal -> stiffer sway bar
Vertical -> softer sway bar
And yes that's the part you need to tune.
       Post #: 139
RE: OFFICIAL!!! Kyosho Evolva - 5/12/2008 8:09:31 PM
Osirisf16
