2.4 GHz and ignition interference
NM
If I have interference in my system, will switching to a 2.4 GHz system eliminate my problems? I can't find the source of my interference but I can only walk away from my plane about 10 paces with the engine running with the antenna down (72MHz) before my control surfaces and throttle start to jitter. I've read about people switching to 2.4 GHz - does the noise not bother with the receiver at that frequency?
Gary
Gary
LA
RE: 2.4 GHz and ignition interference
ORIGINAL: AirWizard
go 2.4 and you won't have the problem
Do you know actual result of using 2.4 and gas/spark ignition. I am testing 2.4 now and have only used it in glow up to .40 and now moving to a bigger plane with objective to put it in a 92" gasburner.
LA
I installed a new 10 ch XPS 2.4 in my cub today,, .52 4 stroke. Great little plane.
Quick installation. Only thing I noticed was throttle servo chattering a bit, none of the others. Might just be a bad pot in the servo due to 6 or so years of very frequent flying. I will replace it tomorrow prior to flying.
When the 27% Extra 330S was in development, we used spark-ignition (gas) engines and 72 MHz with no problems through a few different prototypes of that model. Now, I have my own 27% Extra and am using 2.4 GHz, also with no problems. A minimum of 10" is always maintained between the engine and any electrical components associated with it (ignition module, ignition battery, switches) and the rest of the radio gear.
I run my Spectrum DX7 in two gasser airplanes without any problems at all. One is a Hellcat where everything is pretty crowded inside. There is no way of placing the receiver more than 12" away from the ignition box and I still have no interferences. I trust my Spectrum radio. The other airplane is a giant scale Giles with a Brison 6.4. Again, no problems either.
LA
ORIGINAL: BaldEagel
Jim
Be aware that a lot of people are having problems with the XPS system, including myself.
Mike
Jim
Mike
If you don't want to publish PM me.
My Feedback: (35)
KY
According to all the testing XPS isn't what it's advertised to be . Be aware that it won't hop if necessary.but it will mast the interference. Dennis
LA
ORIGINAL: DadsToysBG
I have heard this from some of the guys who quit flying XPS but have no confirmation. So far it still functions ok in my applications,, but this doesn't mean it is working as advertised.
My Feedback: (10)
'Futaba XPS' System? Not heard of it called that, I thought Futaba refered to their 2.4MHz stuff as 'FAAST' I am interested in getting their '10C 2.4MHz FAAST Transmitter' not aware of a 8 & 10 channel XPS stuff?
LA
ORIGINAL: dasintex
2.4 G Extreme Power systems XPS Futuba compatable. Not Futuba MFG.
ORIGINAL: jimcork1
Mike what issues are you having? You now have my attention!. Jim
ORIGINAL: BaldEagel
Jim
Mike
Jim
Mike
My sytem was the Graupner IFS which is XPS in Europe, I fly on an interferance prone site where PPM glitches in four different place's around the site, the IFS system went into lock out in these positions, IMO this system is only as good as flying on PPM it does not seem to hop to another channel when experiencing interferance it just locks out, plenty of threads around expalaining the problems that people are having, do a search I am sure you will find them, RCGroups have a dedicated site.
Mike
EDIT: to add link: http://www.rcgroups.com/forums/showthread.php?t=816989
To answer the original question, 2.4Ghz does not eliminate RF interferance, it is just not as prone to RF, the interferance is still there, you should do all you can to eliminate RF in your installation as you could interfear with someone else in close proximity and cause them problems.
Mike
Mike
Running a Spektrum DX7 in three gasers with absolutely NO problems at all. One is a G26 in a Giant Spacewalker, another in a GP SuperSportster 40 with a gas/spark converted SuperTigre G51, and finally a Big Stick 60 with a Saito 91 also converted to gas/spark. All of my planes use the original CH ignition with built in synchro-spark and I haven't had any problems. Been using it for about a year now and I have it in a total of 7 planes and 2 heli's.
The SuperSportster is the tightest fit and the ignition module is sitting within 1" of the main receiver (no other way to get it all in) and the two batteries are stacked on top of each other just aft of the wing for balance. None of the three have the ignition module any farther than 2 1/2" from the main receiver and all of them have the batteries mounted either on top of each other or side by side in the case of the SpaceWalker. Again, not a single hickup out of any of them and the SuperSportster has more than 35 hrs since it was converted to spark. I agree with Terry (tkg), it may not cure a poor installation but I sure as heck wouldn't call any of my installations good and yet it just works and works and works . I also have a Futaba 7C FAAST system that I have been testing and it seems rock solid as well. (Won it in a raffle at a fly-in)
ORIGINAL: GMoneyPit
Gary
Gary
Had I never had the problem I would still believe that 2.4 was intference proof, but seeing is believing.
NB, CANADA
Radio is radio regardless of the frequency. 2.4ghz should be able to hop from a frequency where it encounters interference to another to try to clean things up.
Trouble is, ignition noise and other RF noise our planes generate, no matter if it's from the plug, boot, wires, linkages, or loose metal bits is wide spectrum, radiating over entire bands, not over single channels. So, if you're lucky, the system may be able to jump away from the trouble. But it may not be able to.
Always do everything possible to eliminate RF noise before changing radio systems to dodge it.
J
J
Just one other thing I can think of to add. The servo is listening to an electronic "signal" from the receiver to "know" how much to move. When a servo glitches it does not have to come through the receiver. It can also enter through the servo lead or the control board in the servo. I have personally had servo's glitch like that and changing the servo also cured the issue. I could have worked to reduce the RF noise but in my case the filters on the servo board were bad causing it to "hear" the RFI. Lot's of little things......that's what makes this soooo much fun for me.
TX
FYI,
I have XPS in a Futaba 8UAFS transmitter and have been flying the XPS receivers in 5 airplanes and 2 helicopters and have had no problems at all. This is at a renegade field that has "supposedly" had FM problems and has had 1 Spektrum go into fail safe.
I can't speak for others, but I've been satisfied.
My Feedback: (27)
CA
Radio is NOT radio regardless of the frequency.
At our field we have had a lot of trouble with being "HIT" .
We found out that there is a pager tower that operates right next to 72mhz in our area.
A year or so it was pretty bad. After checking into it and calling the pager company things got much better.
I believe they recalibrated their system.
It is not as crowded at 2.4 mhz as it is at 72mhz.
Plus 2.4 mhz tends to be a shorter range signal.
More intense but shorter range.
