How do you strip anodize off of parts????
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Painting, Detailing & Bodies >> How do you strip anodize off of parts????
Page: [1]
Login
How do you strip anodize off of parts???? - 4/20/2008 10:32:38 PM
Dirt_hawg
Status: offline
_____________________________
Factory Team RC8 .21 RB
HPI Baja 5B SS
       Post #: 1
RE: How do you strip anodize off of parts???? - 4/21/2008 3:19:20 AM
Boxhead from MN
Status: offline
I've read that Drano crystals or Easy-Off oven cleaner works.
But there will be some bad fumes from doing this. Use gloves
and eye protection at least. Soak the parts for a few minutes
and then rinse in soapy water. Repete as necessary. Afterwards you
will have to polish with an aluminum polish.
Do a search for Drano. There's a lot of info on this.
Chris
I came into this world with nothing and I plan on having most of it left when I leave.
(in reply to Dirt_hawg)
       Post #: 2
RE: How do you strip anodize off of parts???? - 4/21/2008 2:41:32 PM
cltcrns
Status: online
I do know Easy-Off heavy duty original works great to remove it. Just soak the part for about 5-10 minutes then just rub off anodizing, use a q-tip for bolt holes. Reapply/resoak as needed. You will end up with a dull aluminum, white-ish in color. Depending on how far or what way you want to go, you can make the aluminum shine like a mirror in the sun.
(in reply to Boxhead from MN)
       Post #: 3
RE: How do you strip anodize off of parts???? - 4/22/2008 9:44:21 PM
Beasley1
Status: offline
quote:
ORIGINAL: cltcrns
+1 thats excactly what I did.
" If it aint Breakin, It aint Bashin "
(in reply to cltcrns)
       Post #: 4
RE: How do you strip anodize off of parts???? - 4/22/2008 10:29:54 PM
goldendesign04
Status: offline
ditto on easy off
(in reply to Beasley1)
       Post #: 5
RE: How do you strip anodize off of parts???? - 4/23/2008 3:54:17 AM
hakmazter
Status: offline
easy off is too splotchy and gives inconsistant results. There is a thread over at casterracingusa about how to do it. I learned by belonging to a bmx restoration forum.....
Caster Racing USA
(in reply to goldendesign04)
       Post #: 6
RE: How do you strip anodize off of parts???? - 4/23/2008 9:25:21 PM
Beasley1
Status: offline
its not splocthy. Put some muscle in it and it comes right off. Then polish with some aluminum polish. Its that easy. I had it anodized red though.
Click to see fullsize image.
Click for fullsize
Click for fullsize
(in reply to hakmazter)
       Post #: 7
RE: How do you strip anodize off of parts???? - 4/29/2008 2:44:00 AM
hakmazter
Status: offline
So, you did it one time and it turned out perfect? You mention using some muscle. Just for fun, try using red devil instead and see how it all comes off uniformly and there is no muscle involved. You can then give me a written apology. I'm just trying to help everyone.
Caster Racing USA
       Post #: 8
RE: How do you strip anodize off of parts???? - 4/29/2008 2:50:29 AM
hakmazter
Status: offline
http://www.os-bmx.com/forums/index.php?showtopic=30334&hl=anodizing
Caster Racing USA
       Post #: 9
RE: How do you strip anodize off of parts???? - 4/29/2008 2:57:28 AM
hakmazter
Status: offline
supposedly you can use greased lightning also.......but I have never tried it.
Caster Racing USA
       Post #: 10
RE: How do you strip anodize off of parts???? - 4/29/2008 9:19:30 PM
Beasley1
Status: offline
quote:
ORIGINAL: hakmazter
Yeah, 1 time. I did mention using some muscle. It will get most of it off by spraying it on and letting it sit but if you dont want it blotchy scrub it with some rubber gloves on (strong sruff) and follow with a good aluminum polish and presto, anodize off.
       Post #: 11
RE: How do you strip anodize off of parts???? - 5/5/2008 5:51:48 AM
jetpack
Status: offline
I've used Easy-Off sprayed in a normal ziploc bag with the part and sealed it up and swished it around through the bag. I found the blackish can be chased off the part that way by handing it.
It seems the easy-off only works for awhile on the anodizing when you first use it in the bag, then it seems to darken what it has stripped other than whats left. Starting over with a fresh bag and spray works better than letting it stay in the original slurry. I guess its safe to say a couple fresh applications work better than one good soak.
Wear gloves and dont breath it.
< Message edited by jetpack -- 5/5/2008 5:56:51 AM >
       Post #: 12
RE: How do you strip anodize off of parts???? - 5/5/2008 9:01:38 PM
kryptonite5b
Status: offline
i have used draino crystles with the best resoults. i also found the easy off to be slightly blochy and un-even. the draino worked way easer and was aeser to get a good polish out of it.
sponsored by: vsmodelsport.com
(in reply to jetpack)
       Post #: 13
RE: How do you strip anodize off of parts???? - 5/10/2008 5:46:00 AM
splcrazy
Status: online
if you want to remove your stubborn annodise of without scrubbing , get a tub or half cut container and fill it up with heavy duty DE GREASER the concentrate kind , fill the container up with UN DILUTED de greaser and put all your parts in and leave them in there untill the color is all disolved off , it starts working straight away , and only takes off the color and leaves a smooth finish , then just take it out and polish them up .. DONT use oven cleaner as it eats the alluminium and leaves the surface blotchy and ROUGH
(in reply to kryptonite5b)
       Post #: 14
Page:   [1]
Page: [1]
Jump to:
