ECLIPSE 7
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Radio Manufacturer Direct Support >> Hitec/MultiPlex Radios- Ask Hitec Customer Service >> ECLIPSE 7
Page: [1]
Login
ECLIPSE 7 - 4/20/2008 11:02:06 PM
Command Central
Status: offline
I just bought a used Eclipse 7 in VG condition. I find that throttle trim does not move the servo arm. EPA for high and low end and throttle cut works fine.
What am I doing wrong?
Roy
       Post #: 1
RE: ECLIPSE 7 - 4/21/2008 12:45:12 AM
A.T.
Status: offline
quote:
ORIGINAL: Command Central I just bought a used Eclipse 7 in VG condition. I find that throttle trim does not move the servo arm. EPA for high and low end and throttle cut works fine.
What am I doing wrong? Thanks, Roy
Does the trim work with throttle lever in lowest position? Similar to all other known computer transmitters, the throttle trim works betwen 0 - 50% of travel only. Please refer page 8 of the manual "Note that the CH3 trim only moves downward, so if you need more engine RPM, set up idle with the trim at -25% so you can increase it if needed."
Download .pdf Manual and addendum from
Eclipse features
Regards
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
(in reply to Command Central)
       Post #: 2
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.203RCU1
