crashinator
Joined: 8/27/2007 From: westport island, ME, USA Status: offline
I have a shrike 10, newly built, all the controls are tight, close tolerences on the surfaces blah blah blah, There is no "slop' from the servo arm out to the horn (almost) During high speed passes it has a flutter that will go away during a turn. It seems that the aileron control wire I used is "torqing" If the aileron is true to the trailing edge of the wing, no twists, nice taper,ect., shouldnt they not flutter? It would be nice to make an aerodynamic adjustment instead of ripping the plane apart to replace the wires.
