Li-Ion Transmitter Batteries    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Futaba 18MZ - RTF
Seller:  Newgadgets
Details:   $2,900.00   |  5/13/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> Radios, Batteries, Clubhouse and more >> RC Radios, Transmitters, Receivers, Servos, gyros >> Li-Ion Transmitter Batteries
Page: [1]
Login
Li-Ion Transmitter Batteries - 4/21/2008 8:34 PM
Don_Sinclair
Score: 100
Last Login: 5/6/2013
Status: offline
Hi Danny,
A number of battery suppliers are offering Li-Ion batteries for transmitters. I am considering use this type of battery in my JR9303 transmitter. The batteries operate at approximately 10.8 to 11.5 volts. Assuming I keep the battery charge rate to a reasonable level (300mah), is it safe to use a battery of this voltage in a transmitter that was designed to operate at 9.6 to 10 volts? Thanks for your help.
Hide Signatures
       Post #: 1
RE: Li-Ion Transmitter Batteries - 4/21/2008 11:10 PM
onewasp
Score: 115
Last Login: 4/15/2013
Status: offline
See:
Support forum CLOSED 0 Nathan 731 3/26/2008 7:37:44 PM
Nathan [Go to latest post!]
While the site is presently closed Danny did answer similar questions a number of times in the past.
Do a search and you'll come up with his answers which, as I remember it, were "Not recommended".
< Message edited by onewasp -- 4/21/2008 11:18 PM >
_____________________________
The ground reached up and smote my airplane
Hide Signatures
(in reply to Don_Sinclair)
       Post #: 2
RE: Li-Ion Transmitter Batteries - 4/22/2008 6:30 AM
luckyy
Score: 100
Last Login: 4/19/2013
Status: offline
Ive been using it with no problems???
Hide Signatures
(in reply to onewasp)
       Post #: 3
RE: Li-Ion Transmitter Batteries - 4/22/2008 8:05 AM
chrisF test pilot
Score: 100
Last Login: 3/15/2013
Status: offline
If your reasoning for wanting to use li-ion is the low self discharge look at the Eneloop cells or similar of the newer technology nimh cells. The Eneloops are advertised to retain more than 85% of their charge after one year. Pretty impressive.
Hide Signatures
(in reply to luckyy)
       Post #: 4
RE: Li-Ion Transmitter Batteries - 4/22/2008 7:24 PM
rmh
Score: 252
Last Login: 5/19/2013
Status: offline
quote:
ORIGINAL: chrisF test pilot
LiPo still is a magic word for some
If it is LiPo -or LiIon -it must be better . (it ain't)
I have had people tell me their 2100 LiPo lasts longer than a 2100 NiMh
The problem is -it is true -
but not because it has Mo Powa. (amps is amps)
It simply does not self discharge as fast - better shelf life n flatter discharge
LiPo is not a good choice as a TX retrofit - as a reg needed that is another problem point. more component changes -more potential problems
Best bet - just add the new camera Nimh cells - terrific shelf life -(low self discharge)
and no reg change nor new charger req'd
SAME power as the 2100 LiPo and cheap!!
Want latest technology with best bang for the buck and best safety for yer model?
use the new camera cell in the tx and A123 for rx pack (the A123 does require new charge tho)
The future is now
< Message edited by dick Hanson -- 4/22/2008 7:26 PM >
Libby is still watching you
Hide Signatures
(in reply to chrisF test pilot)
       Post #: 5
RE: Li-Ion Transmitter Batteries - 4/23/2008 5:13 AM
chrisF test pilot
Score: 100
Status: offline
x2. And you can actually get a Dapter and use a nicd charger for the A123 for $40.
Hide Signatures
(in reply to rmh)
       Post #: 6
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.328RCU1
