supertib
quote:
ORIGINAL: slayerphonics quote:
ORIGINAL: shankdog626 Thanks Slayer, I order the motor today. I'm hooking it up with the JP-4 pipe I like that pipe plus it's a good middle and top end pipe since it said to be a good low end motor. Any suggestions on the break in ? I did the heat cycle method, i've had very good results with that method, Thing I liked the best about this motor, is that it responded very well to changes on the needle, Some motors you turn the highspeed 1/2 turn and there is no change in the motor. I went with a low end pipe with this thinking, If the motor has a strong bottom, why not play on its strongest ability, and change the gearing to match, I own 2 of these Cl7B engines... Anyways it is not a bottom end motor by any means, it has extremely high port timings, and has a crank timed like a onroad motor...... running the EFRA pipe you run is likely severely bottling up that engines full potential... switching to a 086/short manifold will likely unleash more power from bottom to top on that motor....... As I say that motor is timed high and built to scream....
_____________________________
seeing is believing !
