RE: Sirio 21 CL7B STI Engine
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Truggy >> RE: Sirio 21 CL7B STI Engine
Page: <<   < prev  1 [2]
Login
RE: Sirio 21 CL7B STI Engine - 5/13/2008 6:01:16 PM
supertib
Status: offline
quote:
ORIGINAL: slayerphonics
quote:
ORIGINAL: shankdog626
Thanks Slayer,
I order the motor today. I'm hooking it up with the JP-4 pipe
I like that pipe plus it's a good middle and top end pipe since
it said to be a good low end motor.
Any suggestions on the break in ?
I did the heat cycle method, i've had very good results with that method,
Thing I liked the best about this motor, is that it responded very well to changes on the needle, Some motors you turn the highspeed 1/2 turn and there is no change in the motor.
I went with a low end pipe with this thinking, If the motor has a strong bottom, why not play on its strongest ability, and change the gearing to match,
I own 2 of these Cl7B engines... Anyways it is not a bottom end motor by any means, it has extremely high port timings, and has a crank timed like a onroad motor...... running the EFRA pipe you run is likely severely bottling up that engines full potential... switching to a 086/short manifold will likely unleash more power from bottom to top on that motor....... As I say that motor is timed high and built to scream....
_____________________________
Warning !!!! I have an opinion and I am not afraid to use it !
(in reply to slayerphonics)
       Post #: 26
RE: Sirio 21 CL7B STI Engine - 5/13/2008 6:30:25 PM
shankdog626
Status: offline
So, you've ran a jp4 on one of your motors and found it to "kill the top end" ?
hmmm... is that a blanket statement or actual experience ?
I read the JP4 pipe is designed to help middle and top end and some top
drivers have tested all 4 JP pipes on this motor and found great results.
Kyosho ST-RR, Sirio, JP4, JR,ProlineLPR
Losi 8
(in reply to supertib)
       Post #: 27
RE: Sirio 21 CL7B STI Engine - 5/13/2008 7:11:03 PM
slayerphonics
Status: offline
I seen a guy running a JP-2 on one at our track, I thought it killed the motor. The motor screamed .. just didn't have the rev up mine had with the 2056 pipe. I'll give it a shot though.
There's a right way and wrong way to do everything and the wrong way is trying to make everybody else do it the right way
       Post #: 28
RE: Sirio 21 CL7B STI Engine - 5/13/2008 7:17:36 PM
shankdog626
Status: offline
Well, this news really blows because I have my new CL7B coming today
and I also bought a new JP4 because AMain had almost all Sirio pipes
on backorder. My buddy runs the JP4 on his .28 Picco and it seems to
run it's butt off.
Maybe I should send it back (unopened) and look for another online
shop to find a sirio pipe ?
Losi 8
       Post #: 29
RE: Sirio 21 CL7B STI Engine - 5/13/2008 7:20:07 PM
supertib
Status: offline
086 will outperform JP-4.... 2 totally different goals for each pipe.... 086 is oldschool before noise regulations when they could design a pipe for power with no concern for noise regulations..The 086 is a very old pipe and since its design many levels of noise regulations have been enforced, the JP-4 is designed for the latest and most stringent noise standards ever... So in order to meet noise regulations the pipe has to be choked back and restricted, which is definitely going to sacrifice some HP..... If i lived in Europe and I was forced to use EFRA pipes I would consider a JP-4, but here in North America we can run the older more powerful pipes like the 086 and 053...
Run what you wish, but at least now you know the differences in these pipes, and the design goals when these pipes were made....... If its any use to you Adam at AB Mods has dynoed dozens of motors and as a 95% rule the 086 pipe is the king, just play with header length to adjust where the powerband will be...
But don't get me wrong a JP-4 will work quite fine on this motor, it just wont open up quite as well as an 086 will..the JP4 will also be much much quieter too..the mileage may go to the 086 tho.....
(in reply to shankdog626)
       Post #: 30
RE: Sirio 21 CL7B STI Engine - 5/13/2008 7:31:59 PM
shankdog626
Status: offline
Alright Supertib, I'll keep it (jp-4) for a while because the majority
of the tracks I go to aren't terribly long. Plus, this pipe is so darn
pretty !!! I got the chrome one.
Losi 8
       Post #: 31
RE: Sirio 21 CL7B STI Engine - 5/13/2008 10:06:39 PM
nascardad24
Status: offline
The cl7b sti is a long stroke meaning more low end grunt, it also has great top end. Check out rc tech in the str thread, Ryan Lutz runs this engine and uses a spacer between the header and pipe to tame the low end down a bit.
Id stay away from a low end pipe as this engine already has more than enough.
Kyosho STRR~Futaba~Sirio~Acer Racing~BCE~
Horsepower sells engines, Torque wins races
       Post #: 32
RE: Sirio 21 CL7B STI Engine - 5/13/2008 11:59:46 PM
shankdog626
Status: offline
So what all do I have to seal ?
Back plate ?
Carb ?
The screw that holds the carb ?
What is the other needle for ?
I bought p3 ultra hot glow plugs for it like recommended.
Should I run my Gen2 30% while breaking in ?
Sorry for the dumb questions but I'm a noob and don't want this motor going bad quick.
Losi 8
(in reply to nascardad24)
       Post #: 33
RE: Sirio 21 CL7B STI Engine - 5/14/2008 12:18:02 AM
supertib
Status: offline
the Sirio really isn't that long of a stroke... it only has 0.09 mm longer stroke then a Picco P7R or RB C6...it also shares port timings with P7R. very nice motor, the sleeve design is extremely similar to a GRP .21..the sleeves could have been produced in the same factory as they share identical tooling marks in the ports ( Which are very unique to GRP) ...The Sirio has slightly more aggressive timing, slightly larger ports and much more lightened crank.... All in all the Cl7B is a very advanced engine, i am impressed
       Post #: 34
RE: Sirio 21 CL7B STI Engine - 5/14/2008 12:37:00 AM
shankdog626
Status: offline
Hey, I just noticed on AMain every single Sirio pipe is an EFRA type pipe.
the 2013, 2056,2057 and 2058.
Losi 8
       Post #: 35
RE: Sirio 21 CL7B STI Engine - 5/14/2008 1:39:34 AM
BKNate
Status: offline
Here is a picture of my Sirio Black Engine
Click to see fullsize image.
Click for fullsize
Click for fullsize
       Post #: 36
RE: Sirio 21 CL7B STI Engine - 5/14/2008 2:08:44 AM
nascardad24
Status: offline
ROAR rule along with pro series rules mandate you run a pipe thats not loud. I forget what the deciples are but most pipes made are legal for major event. Local tracks may not mind, however the roar or pro series will.
Nice BKNate. Both mine are silver case. Ceramic bearings will be installed soon enough on mine.
       Post #: 37
RE: Sirio 21 CL7B STI Engine - 5/15/2008 6:44:49 PM
shankdog626
Status: offline
So, you WOULDN'T put a sealant on any part of this engine?
Back Plate?
Carb?
Pinch bolt that holds the carb on?
The bolt that holds the high speed needle onto the carb ?
Thanks in advance.
< Message edited by shankdog626 -- 5/15/2008 6:45:20 PM >
Losi 8
       Post #: 38
RE: Sirio 21 CL7B STI Engine - 5/16/2008 12:39:18 AM
BKNate
Status: offline
Whoever reads this, go out and buy the engine. It is one of the fastest engines out. I also just got in a (EVO 4 Black Sti Engine), can't wait to break that in also
       Post #: 39
RE: Sirio 21 CL7B STI Engine - 5/16/2008 7:24:47 AM
shankdog626
Status: offline
what about sealing things on it ?
Losi 8
(in reply to BKNate)
       Post #: 40
RE: Sirio 21 CL7B STI Engine - 5/16/2008 2:41:23 PM
nascardad24
Status: offline
