CD's
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> AMA Discussions >> CD's
Page: [1]
Login
CD's - 4/22/2008 1:58:32 AM
funflyerf4
Status: offline
What is the difference between a CD and a CD for a turbine waiver.Can any CD sign off a person for a turbine waiver?
       Post #: 1
RE: CD's - 4/22/2008 2:55:35 AM
pilott28
Status: offline
The difference between a CD and a Turbine CD, is that a Turbine CD not only holds the CD designation but also possesses a turbine waiver.
If you are applying for a fixed wing turbine waiver, you need two signatures, one from any waiver holder and the other from any Turbine CD.
There is also a small list of Designated Turbine CD's. See AMA pub 510k. The folks on this list are the only ones that can sign off on "rotary" turbine waivers.
_____________________________
Keith Sievers
(in reply to funflyerf4)
       Post #: 2
RE: CD's - 4/22/2008 8:28:24 PM
funflyerf4
Status: offline
I'm allready a turbine waiverd pilot if I took the test for a cd then I would be able to sign off people for a waiver?Not that I want to be a cd but am curious as to how it works.
(in reply to pilott28)
       Post #: 3
RE: CD's - 4/23/2008 5:26:19 AM
pilott28
Status: offline
quote:
ORIGINAL: funflyerf4
You are correct ... if you complete the qualifications for a CD and you hold a waiver, you can be the "CD" signature on a fixed wing waiver app. A second signature from any other waiver holder would also be required.
Keith Sievers
       Post #: 4
RE: CD's - 4/25/2008 4:41:23 AM
busted2props
Status: offline
Nevermind. Wanted to know how much experience is required for stuff like this.
< Message edited by busted2props -- 4/25/2008 4:49:38 AM >
Send Lawyers, Guns and Money!
       Post #: 5
RE: CD's - 4/25/2008 12:45:17 PM
pilott28
Status: offline
quote:
ORIGINAL: busted2props
The theory is that you should have a fair amount of experience, enough to be a Contest Director for an event. As part of the process, you need two other CD's to sign off on your application, certifying that they think you are qualified to fulfill this role.
There is some responsibility and risk that comes with the CD waiver signoff. If you sign someone off who is really not qualified, and they go out and hurt someone, there is a high probability that the lawyers will find you.
Keith Sievers
(in reply to busted2props)
       Post #: 6
RE: CD's - 4/25/2008 5:42:06 PM
littlecrankshaf
Status: offline
quote:
ORIGINAL: pilott28
There is some responsibility and risk that comes with the CD waiver signoff. If you sign someone off and they go out and hurt someone, there is a high probability that the lawyers will find you.
The term “Qualified" will likely be determined during any litigation where serious injury takes place... your friends may also be there giving their unique and subjective observations as well.
The waiver system allows the diffusion of personal responsibility.
Many look at the waiver system as just the means of qualifying for turbine operation but it is much more than that…technically turbines are prohibited within the AMA but that prohibition can be waived providing someone will sign on the appropriate dotted lines…
Wow! Another epiphany…that is why the suckups suckup. Super sucking protection power. Yea baby.
       Post #: 7
RE: CD's - 4/25/2008 9:43:33 PM
busted2props
Status: offline
PILOTT28 and LCS,
Thanks for the info. Kinda thought it worked that way. Goes down all the streets to the original signature. HMMMM...Makes ya think, don't it?????????
(Don't it was intentional.)
(in reply to littlecrankshaf)
       Post #: 8
RE: CD's - 4/26/2008 6:05:04 AM
ira d
Status: offline
quote:
ORIGINAL: littlecrankshaf
quote:
ORIGINAL: pilott28
In the 15 or so years the turbine wavier system has been in place I have never heard
of a CD being sued has anyone else?
Ira d
       Post #: 9
RE: CD's - 4/26/2008 6:47:30 AM
littlecrankshaf
Status: offline
quote:
ORIGINAL: ira d
quote:
ORIGINAL: pilott28
Never have either and probably will not ever. Just some scare tactics are overly used...this suing thing is used all too often to justify most any restriction...it works quite well. Heck, AMA likely owes its whole existence to the concept.
< Message edited by littlecrankshaf -- 4/26/2008 6:48:25 AM >
(in reply to ira d)
       Post #: 10
RE: CD's - 4/26/2008 1:07:32 PM
BarracudaHockey
Status: offline
Hmm.....I was under the impression that is was a way to organize modelers for the common good. To present ourselves as a body to goverment agencies to get the frequencies we use, to organize events, to communicate with each other, and to promote the hobbby.
Andy - Helicopter Forum Moderator
AMA 77227 http://www.jaxrc.com
       Post #: 11
RE: CD's - 4/26/2008 5:35:13 PM
littlecrankshaf
Status: offline
quote:
ORIGINAL: BarracudaHockey
That is what is indeed openly touted but it is also a greater truth that without the spell of "fear factor" instilled and the provided "antidote" of insurance by the AMA it would be a certainty that AMA would not have survived until today. I am one that regrets deeply that the AMA only survives due to insurance because of the fear of modeling. I am further dismayed and sadden that few recognize the truth… Most or happy to perpetuate the “spell” and wonder why the hobby lags while touting “Aero modeling is a worthwhile activity”. The “spell” had the intended effect…the survival of AMA is proof of its success.
I may be unusual in that I truly believe the hobby, although different would continue without the AMA. I base that belief on the fact that I built and flew models long before I knew about AMA and its benefits. Yes, there are benefits. We just need to learn how to use them properly. That is why I counter those that hinge what they say on fear………………………………………………………………………………………………………………………………………………….That is not the right answer. We need to move from there.
(in reply to BarracudaHockey)
       Post #: 12
RE: CD's - 4/26/2008 6:32:31 PM
804
Status: online
I am suspending my LCS ban for a short time here to un-twist and de-spin the above.
Today, you must be protected from the sharks swimming in circles around people engaging in any "potentially hazardous" activity.
AMA has simply made it easy, cheap, and uniform(for administrative purposes for clubs, individuals, and governments) to insure against legal problems. Insurance may be the largest factor for joining AMA, but due to today's circumstances, not because AMA has steered it that way.
You , o' sage one, may deny that, but your head is clearly buried neck deep in sand if you can't recognize that AMA has done far more as a large group than a nationwide collection of individuals could ever hope to.
Yes, you truly are unusual, but be that as it may, the fact is we would have far fewer places to fly, far fewer planes to fly, and most likely, far fewer people enjoying this hobby.
And aside and maybe above all that, it still is everything BarracudaHockey mentioned above.
       Post #: 13
RE: CD's - 4/26/2008 7:46:38 PM
BarracudaHockey
Status: offline
Ah! A well thought out and lucid post (and completely true). So rare in a discussion of the AMA.
< Message edited by BarracudaHockey -- 4/26/2008 7:47:35 PM >
(in reply to 804)
       Post #: 14
RE: CD's - 4/27/2008 4:07:46 AM
KidEpoxy
Status: online
When you say "unifo
