RE: My First Crawler    Gallery
Logged in as Guest
    Search This Thread
Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Rock Crawlers >> RE: My First Crawler
Page: <<   < prev  1 [2]
Login
RE: My First Crawler - 5/22/2008 1:58 AM
bluebirdrc
Score: 100
Last Login: 6/15/2010
Status: offline
Check this site for free frame pattern.
http://offroader5.freeservers.com/templates.html
Get thick walled tubing from ACE Hardware. Find some 3/16 aluminum plate. I cut mine with a scroll saw.
Do it your self. It will be worth it.
Hide Signatures
(in reply to misasi)
       Post #: 26
RE: My First Crawler - 5/22/2008 9:23 AM
misasi
Score: 100
Last Login: 3/4/2013
Status: offline
Thanks i think i will venture and try building it myself. how does your model crawl in comparison to a kit car? Im sure its no AX10 but i find DIY jobs are much more rewarding.
_____________________________
Z-Car ZMXT8-,JPX .21/086 , ACE Servos, Futaba Fasst
Northern MI Track / Ontario http://thomsonrctrack.com
Hide Signatures
(in reply to bluebirdrc)
       Post #: 27
RE: My First Crawler - 5/22/2008 12:28 PM
cflight
Score: 100
Last Login: 3/3/2009
Status: offline
May I suggest checking allelectronis for gear head/ geared motors?
They have all sorts of gearhead motors , stock changing regularly. If you run a gearhead to a transfer case, say some 1/4" flat stock aluminum, housing four bearings, two shafts and drilled out pinions, ... you got a transfer case needing some drive cups or drive shafts.
I've found brazing tubing is the easiest chassis if you have a torch, chopping aluminum stocks fun if you have a cut wheel....?
Hide Signatures
       Post #: 28
RE: My First Crawler - 5/22/2008 12:32 PM
cflight
Score: 100
Status: offline
Cut, file, drill,...........
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to cflight)
       Post #: 29
RE: My First Crawler - 5/22/2008 3:10 PM
bluebirdrc
Score: 100
Status: offline
Vere nice gear box. Should get CG low.
I have not seen the other Crawlers my self. I am still in the building stage.
Just built this one from information I obtained from this sight and others like it.
I can tell you that after watching the online video, mine will be able to hold its own.
I will be taking it apart and rebuilding it cleaner. Better servos, clean and paint the frame.
When I get the links adjusted the way I want them I will use them as patterns to cut solid ones.
Watch the videos and look at the other rigs on this sight, they will give you plenty of ideas.
There is no reason you can't build a crawler that is just as good or better than the store bought ones.
Be sides you don't thing these guys leave them stock do they. You just make yours better from scratch.
Besides it's fun.
Hide Signatures
       Post #: 30
RE: My First Crawler - 5/22/2008 11:32 PM
bansheemaniac
Score: 100
Last Login: 1/10/2010
Status: offline
what metal and thickness did you use?
Hide Signatures
       Post #: 31
RE: My First Crawler - 5/23/2008 6:24 AM
astroboycp
Score: 100
Last Login: 8/29/2012
Status: offline
Did you DIY that frame yourself?
Tam KingTiger|TigerI|Sturmtiger|Sherman|Jadgpanther|Leopard|Pershing|WSNT34|Stuart|Scania|KingHauler|Volvo|Mercedes|Tundra
Hide Signatures
       Post #: 32
RE: My First Crawler - 5/23/2008 7:00 AM
bluebirdrc
Score: 100
Status: offline
Witch frame are you asking about?
Hide Signatures
(in reply to astroboycp)
       Post #: 33
RE: My First Crawler - 7/12/2008 7:48 PM
bluebirdrc
Score: 100
Status: offline
Hello every body"
Took a crud video of the first real test.
It's hard to see how steep the area is. I took the video from the top looking down.
Sorry for the quality.
http://www.youtube.com/watch?v=yHDvU5YHE4k
Hide Signatures
       Post #: 34
Jump to:
Google
SITE MAP!   : :   FORUM RULES
0.344RCU1
