My First Crawler
Tower Hobbies
Logged in as Guest
  Printable Version
CEN Racing Genesis Monster Truck - RTR - RTR
Seller:  solidgold5
Details:   $250.00   |  7/15/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Rock Crawlers >> My First Crawler
Page: [1] 2   next >   >>
Login
My First Crawler - 4/22/2008 6:33:17 PM
bluebirdrc
Status: offline
Hello all:
Here is my first attempt at a crawler.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 1
RE: My First Crawler - 4/22/2008 7:20:32 PM
nitrosportsandrunner
Status: offline
nice chassis, what tranny are you planning on using?
_____________________________
VXL on 3s lipo, wheely king crawler, tt01 drifter
(in reply to bluebirdrc)
       Post #: 2
RE: My First Crawler - 4/22/2008 9:33:05 PM
hands without shadows
Status: offline
Nice Manta.
Why did you leave so much thread exposed? Are you switching it Jato ends or...?
_________
O||||||||O
(in reply to nitrosportsandrunner)
       Post #: 3
RE: My First Crawler - 4/22/2008 9:38:30 PM
t9dragon
Status: offline
Nice work.....................
(in reply to hands without shadows)
       Post #: 4
RE: My First Crawler - 4/22/2008 11:52:46 PM
bluebirdrc
Status: offline
Thank you
I am using an Axial Scorpion transmition from Stormer Hobbies for $35.
2 Scorpion differentials for $36 each.
I got the pattern from this sight.
http://offroader5.freeservers.com/templates.html
I am still cutting and trimming.
I changed the upper arms to V shape so the shocks will clear.
To start with it will have rear steering. If I find some competition I will lock down the rear and go with a DIG.
(in reply to t9dragon)
       Post #: 5
RE: My First Crawler - 4/26/2008 5:12:38 PM
bluebirdrc
Status: offline
What off the shelf drive shaft, at a local hobby shop will fit the Scorpion trans and axles?
       Post #: 6
RE: My First Crawler - 4/27/2008 4:31:40 AM
FORDMIKE65
Status: offline
I've read on several posts that the Traxxas Stampede driveshafts will work
Losi LST,XXN-T,Mini LST,Mini LST2,Micro Baja,Axial AX-10,Stampede MudBogger,Rustler,Mini M-01,Mini TG-10,TL01
       Post #: 7
RE: My First Crawler - 4/28/2008 3:42:00 PM
bluebirdrc
Status: offline
What gears should I use? What is the largest sper gear I can install?
Thank you
(in reply to FORDMIKE65)
       Post #: 8
RE: My First Crawler - 4/28/2008 3:58:38 PM
nomobux
Status: online
quote:
ORIGINAL: bluebirdrc
Thank you
On a stock axial , a 90 spur is about it , if i remember right
" I GOTTS NOMOBUX "
       Post #: 9
RE: My First Crawler - 4/28/2008 4:23:53 PM
bluebirdrc
Status: offline
Thankyou
(in reply to nomobux)
       Post #: 10
RE: My First Crawler - 4/30/2008 1:30:13 AM
bluebirdrc
Status: offline
Here are a few updated photos of my project.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
       Post #: 11
RE: My First Crawler - 5/3/2008 4:50:10 PM
bluebirdrc
Status: offline
OK, I have another question. How much weight to put in the tires?
This question was asked before but I'm confused.
One person uses 7.5oz per front tires only and the other uses 12oz per each front and 9oz for each back.
Pretty wide spreed. Any one els have some input? Please
Thank you
Mike
       Post #: 12
RE: My First Crawler - 5/3/2008 6:54:44 PM
Status: offline
Use whatever amount of weight works best for you. Just try different setups.
_________
O||||||||O
       Post #: 13
RE: My First Crawler - 5/3/2008 10:43:51 PM
N4TEC
Status: offline
I use 3.5 oz front and rear, works good for me.
Sadly, 98% of teens have switched to rap music. If you're part of the other 2% that like real hip-hop put this in your sig.
       Post #: 14
RE: My First Crawler - 5/4/2008 12:23:18 AM
bluebirdrc
Status: offline
I have moved to the next step.
Shocks, a body and weight on the wheels and it will be ready.
Then I will take it all apart and make it pretty.
Click for fullsize
