nikg
GadgetI don't think Red meant it in a degrading or mean type of way. (I don't think) Anyway, the C rating for these batteries refers to their current output. 1C is one times the capacity of the battery, so 10C is ten times, 15C is fifteen times and so on. Using a 2000mAh battery for simplicity of the math, a 10C would be able to deliver 20 amps, a 15C would deliver 30 amps, and a 20C would deliver 40 amps. So, the 2200mAh batteries in your case would deliver 33 amps (15C) and 44 amps (20C). Usually higher amps are more desirable, but I run an electric truck where bursts of high current are needed. I have no idea the requirements for a Heli, but I'm assuming they may not be as high. I'm not sure, though. As far as their fit you would need to know the dimensions. The difference between the 2100 and 2200 packs are most likely little or nothing, but again you would have to check. For NIMH and NICD sub-c cells, 3300mAh and 4600mAh cells are just about the same size because they are classified as sub-c. I would think in Lipo the more important consideration is the S and P numbers. The S indicates how many cells are in series (2S are 7.4v and 3S are 11.1v etc) and the P is how many of these groups are in parallel. The higher the S, the higher the voltage and the higher the P the higher the amperage (typically). So if your Heli takes 2100 2S 2P packs and you are getting 2200 2S 2P packs, then I bet they will probably fit. I would make sure I did my research before investing in batteries, it will pay dividends in the long run.
