freakingfast
CA, USA Status: offline
Success! That thing is fastest thing I’ve flown. Eyeball speed looked to be about 190+ and I think there’s more to be found. It was realy gusty, so much so that I had to hold the plane down on the work table so it wouldn’t blow away. I launched at a lower angle than normal so it won’t end up right over my head. It was a bit twitchy on the roll axis at takeoff so I’ll reduce my rates and remove the all the expo that I use for launch. Trim was close, two clicks up and one right. I set the timer at 2 minutes 45 seconds which was perfect for an 8 oz. tank, which left about enough fuel left for one landing go around. The smoke trail was nice and constant and the engine ran flawlessly. I pulled the plug and the element was still shinny, centered and even. The clipped wing DD flew better than I had hoped, smooth high speed low passes, and predicable turns. I tried some abrupt turns and “walls” and not a hint of high speed stall. My biggest surprise was the roll rate, faster than the standard DD and about twice that of the Outlaw! What a buzz saw! The landing was perfect, with the strong head wind it ran on the landing skids only about 10 feet. I few it once, the only other pilot left, my cap blew off my head and I had to chase my fuel jug so I thought to myself this is nuts, I’m going home in one piece. The prop may be too much; it didn’t unload much, maybe 1 K or so. I was a bit busy at the time to realy listen. It was probably running about 22.5K at best and I’d like to see it at about 24 in flight. Next time out I may want to try a 8.8 X 9.5 and maybe a 8.8 X 9.25. A very good day!
_____________________________
When in doubt, give it full power. The smaller pieces fit easier in the bag! Revver Bro #201
