RE: 8.8X9.75 @ 19,300+ !
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Extreme Speed Prop Planes >> RE: 8.8X9.75 @ 19,300+ !
Page: <<   < prev  1 2 3 4 [5]
Login
RE: 8.8X9.75 @ 19,300+ ! - 5/28/2008 4:26:56 AM
combatpigg
Status: online
It's an OMEN.. ...a superior power is trying to tell you THAT is the diameter you should be using.....
_____________________________
Led Zeppelin is NOT "old fogie" music.
(in reply to freakingfast)
       Post #: 101
RE: 8.8X9.75 @ 19,300+ ! - 5/28/2008 4:37:39 AM
freakingfast
Status: offline
I've heard of in-flight trimable pitch before, but not in-flight trimable diameter/disc area. LOL
When in doubt, give it full power. The smaller
pieces fit easier in the bag! Revver Bro #201
(in reply to combatpigg)
       Post #: 102
RE: 8.8X9.75 @ 19,300+ ! - 5/28/2008 12:10:38 PM
daven
Status: online
Those are the new ones, the old ones didn't have the pronounced witness lines around the edges.
They were added so that it could be easily seen if someone was modifying a stock prop for racing.
Dave Norman
klasskote.com
supertrc.com
       Post #: 103
RE: 8.8X9.75 @ 19,300+ ! - 5/28/2008 1:27:32 PM
freakingfast
Status: offline
Thanks daven !
(in reply to daven)
       Post #: 104
RE: 8.8X9.75 @ 19,300+ ! - 5/28/2008 4:38:09 PM
mmattockx
Status: offline
quote:
ORIGINAL: freakingfast
It's just a self-optimizing prop. Don't let APC know that, they might start charging more!
Mark
Waco Brotherhood #4
       Post #: 105
RE: 8.8X9.75 @ 19,300+ ! - 5/28/2008 10:01:15 PM
combatpigg
Status: online
It makes sense that hard manuevering could blow the tips off, instead of it being just an rpm issue.
(in reply to mmattockx)
       Post #: 106
RE: 8.8X9.75 @ 19,300+ ! - 5/28/2008 10:51:07 PM
daven
Status: online
This is APC's suggestion:
Racing Props
8.75 N,W and 8.8 series 40 Pylon props
Maximum RPM=225,000/Prop diameter (inches)
Also, from APC"s site (and there is a lot more)
Ideally, a product can be designed with credible knowledge of the environment (loads acting on the product) and capabilities of the product to withstand that environment (not fail). There is nothing ideal about designing a model airplane propeller because some major components of propeller loads are very uncertain. The principle load components acting on a propeller are:
Centrifugal (from circular motion causing radial load)
Thrust/drag (from lift and drag acting on blade sections)
Torsional acceleration ( from engine combustion and/or pre-ignition)
Vibration (from resonant frequencies or forced excitation)
Another potential source of loading is aero elastic tip flutter. This may be caused by self exciting aerodynamic loads at a resonant frequency.
Dave Norman
klasskote.com
supertrc.com
       Post #: 107
RE: 8.8X9.75 @ 19,300+ ! - 5/29/2008 3:47:10 AM
freakingfast
Status: offline
Ok, I cut down a 8.8 X 9.25 to 8.5 diameter and it still broke. So I put on a 8.75 X 9.25W (bottom prop) and it broke too. Yet a 8.8 X 9.0, 8.75 X 9.5 NN or 8.8X 9.75 will not break. I’m almost positive I heard the props tips let go near the bottom of a shallow dive so it’s not a change of direction that triggers the event. It must be harmonics + RPM that causes it to happen. The 9.25 pitch was the fastest prop……before it self trims. The fastest prop that stays intact is the 8.8 X 9.75. I’m waiting on some 8.8 X 9.5 to try.
The used OS 46 VX DF engine now has 2 gallons that I have put though it, this doesn’t take long when 8oz lasts only 2½ minutes at WOT . The engine still has some pinch at the top with the glow plug out and cool. It’s not a finicky engine, starts, idles and runs great. I lost some glow plugs due to vibration/foaming (ya-think? ) so ran out of OS# 8 and found that K&B 1L’s and Fox standard /long’s worked just as well and within one or two clicks of the #8. My YS 45 is very picky, it wants OS #8 and won’t run for beans on a Fox standard /long.
The real good news is, I think I have the hand launches down real good on this heavy, torquie clipped wing devil. I’ll wait for no wind condition launches to confirm it.
Click to see fullsize image.
Click for fullsize
(in reply to daven)
       Post #: 108
RE: 8.8X9.75 @ 19,300+ ! - 5/29/2008 4:09:12 AM
med601
Status: offline
Hey guys,
Help me out! What do you know about this engine K&B 7.5 ducted fan. Will this work on my DD?
I cant figure out if this will accept a prop.
Click for fullsize
Click for fullsize
       Post #: 109
RE: 8.8X9.75 @ 19,300+ ! - 5/29/2008 6:56:05 AM
freakingfast
Status: offline
I can’t quite tell what your prop shaft looks like, but normally you use a short shaft adapter (Tru Turn part number TT-0141-A) for props. Ream out the prop to fit the adapter’s OD. On the back side (engine side) of the prop's hub (APC), there is a .375 diameter counter bore, this is your true center pilot diameter for your reamer. You should pre-drill the hole .020"to .040" smaller than the reamer first. Stone/grind the lead/hook off the drill flutes just a touch to zero so the drill won’t grab or dig in. To keep the hole strait this should be done in a drill press or mill using a VICE, NOT YOUR HANDS. I like to finnish it off by reaming a clearance diameter about +.010" half way through from the front.
Practice on those broken props I know you have hanging on your wall
They do sell little stepped hand reamers, but half the time they tend to run too far off center for high speed apps and take too long to do. Balance when done.
This is only safe to do to large hub props like APC pylon(D-1) or carbon.
Good luck.
< Message edited by freakingfast -- 5/29/2008 7:16:17 AM >
(in reply to med601)
       Post #: 110
RE: 8.8X9.75 @ 19,300+ ! - 5/30/2008 4:10:28 AM
med601
Status: offline
I don't understand why i can't turn over the engine by turning the thrust washer. I'm I missing some thing obvious?
Click for fullsize
Click for fullsize
       Post #: 111
RE: 8.8X9.75 @ 19,300+ ! - 5/30/2008 4:37:32 AM
freakingfast
Status: offline
It looks like it uses a split cone/collet drive and this needs to have a fan or prop tightened before the prop driver will clamp to the crankshaft. I don’t know if it’s an easily doable prop drive. That extension sure hangs out there to clear the carb, I wonder if you need it?
And you may not need a short shaft adaptor if you can do without the extension.
< Message edited by freakingfast -- 5/30/2008 4:38:37 AM >
       Post #: 112
RE: 8.8X9.75 @ 19,300+ ! - 5/30/2008 9:23:02 AM
proptop
Status: offline
IIRC the prop should just barely clear the carb without the extension ( gonna haveta check one of mine just out of curiosity ) and FF is right about the collet, all ya gotta do it put a prop on it and tighten the nut and you'll be able to turn it over.
If not, just get a longer stud and use the extension. The prop stud is your standard 1/4 x 28 so you can get an all threaded 1/4 x 28 bolt and just cut it to whatever length you want/need.
< Message edited by proptop -- 5/30/2008 9:28:22 AM >
It's bad luck to be superstitious...
Revver Bro #77
       Post #: 113
RE: 8.8X9.75 @ 19,300+ ! - 6/1/2008 7:04:20 AM
freakingfast
Status: offline
Discovered more power!
In a glow plug of all things. I was using mainly using OS #8’s, K&B 1-L and Fox standard Longs. The Fox worked once the engine had been running but otherwise they are too cold blooded. The K&B seemed to be a tad better than the others, so I sent for some, and while I was at it, I got some K&B HP longs P.N.7300 (good for ducted fans and 30% or more). I tried the HPs and got a surprise in the air, much more unload with the 8.8X 9.75!
The new speed is harder to control; the roll axis is twitchier. I’m already at 100% expo so I may need to drop the rates a bit. The new plug was wanting it richer by a quarter turn so my flight time is less. When the timer goes off at 2 ½ minutes, land! No cool down laps.
The bad news
Now this prop is throwing tips in a dive after about 10 flights with the new plug.
I used a cut down prop 8.5X9.75 with about the same speed and so far so good.
The news gets worse
Thrown tips, imbalance and subsequent lean outs took it’s toll on the main bearing.
Two of the balls started fretting (flaking) and small pieces knocked out glow plug element, mercifully killing the engine. The top of the piston and the bottom of the cylinder head button look like they were sand blasted. There was very little scoring and the compression is still normal and it ran great till it quit. The rotary valve, case, rod ends and crank are like new. I ordered a couple sets of ceramic bearings and that’s all I’ll do for it. In the mean time I put one of the engine’s twins on the dust too keep flying.
< Message edited by freakingfast -- 6/1/2008 7:25:43 AM >
(in reply to proptop)
       Post #: 114
RE: 8.8X9.75 @ 19,300+ ! - 6/1/2008 7:48:27 AM
Petrovsky
Status: offline
Possibly caused by detonation?- I have seen this on a Rossi 40 (without any signs of pieces/chips going through the engine that could have caused it). K&B HP is a good plug.
