supertib
quote:
ORIGINAL: FrankBlack THey are NOT the same as an old ninja, they are vastly different inside, especially the crank, the hole in the back its alot smaller in diameter, they have a bit more grunt than a ninja aswell, ive been running one for the past couple months, great engine and consumption. Im using the 3009 pipe with long header. The 3009 is smoother than the 2053 (and yes i have both and have tried both) and has a bit better consumption. they are identical to the MR tuned Ninja...saying they are vastly different is not accurate at all......... the MR FLS pipes will suck the power out of these motors pretty badly, run a 086 or 053 and you will see way more power then if you use any of the FLS pipes.....FLS pipes will lose about 25% of the motors power as compared to a 053 These GRP's are mellow motors, they are not crazy, nor do you need to use a 6.5 mm venturi.... someone is embellishing the story here big time..... the GRP's are not overly powerful ( especially with included FLS pipes) , they are smooth and linear and are known to be easy to drive............ if you think a GRP is brutal then go drive a P7R/JPX or a CL7B, as the GRP is one of the mildest easy to drive mills your going to find.......i love the GRP built engines, but they are known to be smooth and easy to drive, not known to be wild and uncontrollable like is being said here....
< Message edited by supertib -- 5/12/2008 1:46:42 PM >
_____________________________
seeing is believing !
