Villa
Someone asked what is considered "high wind". Obviously it is a relative thing and depends on experience and nerve, etc. If I am standing comfortably with my feet parallel and my hat is not ready to blow off, the wind is not bad, below 15 MPH. If I have to lower my chin strap and put one foot slightly back for better balance/support, the wind is very interesting. Sometimes I have wished I had not taken off. If you are coming in for a landing with the wind gusting and your pattern plane is going up and down about 10 feet, and rolling 90 degrees before you can correct it, and this happens during the whole approach, you know you are having a good time. If things get real bad abort and go around. But if it appears you have control even though the plane is being tossed around, continue the approach, because you know that as you get a few feet off the ground, ground effect will calm things down and the plane has a good chance of making ground contact with the main gear first. Of course, sometimes a down draft drives you into the ground. That is when a tough plane, like the SPADS I fly now, shine. The adrenalin rush after such a landing is priceless. Many people I see at the field are afraid of the wind they are afraid to damage the plane.
< Message edited by Villa -- 4/26/2008 11:34:38 PM >
