Design for Windy conditions
Tower Hobbies
Logged in as Guest
  Printable Version
WILD THING 40 - Kit
Seller:  THOR-RCU
Details:   $70.00   |  7/17/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Aerodynamics >> Design for Windy conditions
Page: [1] 2   next >   >>
Login
Design for Windy conditions - 4/23/2008 10:16:52 PM
subtleguru
Status: offline
Sometimes while one model can handle 15mph cross winds comfortably others are battered around the sky and really difficult to land. So the question is what are the characteristics that influence how well a model reacts to windy and gusty conditions.
Some possibilities
1. Wind loading ?
2. High cruise speed (relative to gust strength)
3. Large effective rudder
4. Size ?
5. Low drag
Is wind loading relevant or does is just influence cruise speed ? Likewise for size.
Needless to say I am talking about powered flight and not slope or dynamic soaring.
       Post #: 1
RE: Design for Windy conditions - 4/23/2008 11:41:50 PM
crasherboy
Status: offline
Wing loading ,maybe some effect, but in my opinion the design of the craft would be more inportant,like a shoulder or low wing with not to much dihedral. To much rudder[fin] would not help you in better handling,in my humble opinion. A high wing ,light wing loading ,a lot of dihedral like in a trainer ,more fin and rudder area than needed for good control ,would, it seems to me would be the worse in crosswinds. Maybe others here have some ideas on this subject. O yes ,a lot of fuselage side area would make it more prone to being blown around.
_____________________________
Do unto others as you would be done unto,well most of the time anyway!
(in reply to subtleguru)
       Post #: 2
RE: Design for Windy conditions - 4/24/2008 12:27:31 AM
HighPlains
Status: online
quote:
15mph cross winds
I read the thread title and thought you were designing for wind. 15 mph is a mild breeze.
"Pay no attention to the man behind the curtain"
       Post #: 3
RE: Design for Windy conditions - 4/24/2008 1:02:09 AM
combatpigg
Status: offline
A low aspect ratio wing with a medium wing loading should be able to slice its way through and penetrate best. You have to consider down wind handling too, a lead sled can fall out of the sky.
Led Zeppelin is NOT "old fogie" music.
(in reply to HighPlains)
       Post #: 4
RE: Design for Windy conditions - 4/24/2008 1:33:27 AM
dick Hanson
Status: offline
side area has nothing to do with how a model reacts to wind.
It has to do with how you perceive what is really happening
the ideal windy weather mode lhas instant acceleration and speed required to present an apparant straight line
this means a light model - not overkill wing area. heavy loaded models don't bounce in gusts but constant wind is an entirely different matter .
I am watching you
Libby
(in reply to combatpigg)
       Post #: 5
RE: Design for Windy conditions - 4/24/2008 1:46:21 AM
wellss
Status: offline
A wing with lower lift slope and no dihedral. Side loads won't upset model laterally.
There are two ways to reduce the lift slope of the wing.
1. Low aspect ratio - side effect is increased induced drag, faster roll rate
2. Sweep
You could keep a high aspect ratio for less drag where wind gusts won't upset the roll as much, but then use sweep ( back or forward doesn't matter ) to reduce the lift slope. Something like the Vultee Vengence with it's swept back inboard section and swept forward outboard section was always appealing to me.
(in reply to dick Hanson)
       Post #: 6
RE: Design for Windy conditions - 4/24/2008 2:42:18 AM
combatpigg
Status: offline
For me, a .40 sized model is large and my best foul weather flyers are deltas.
(in reply to wellss)
       Post #: 7
RE: Design for Windy conditions - 4/24/2008 2:57:50 AM
Lomcevak Duck
Status: offline
I'll second CP on the delta thing. My all time best windy day flyer was my Diamond Dust. A Sky-Dart spad was close second.
When someone loses a plane in the pits, you do a lomcevak duck.
Press Alt F4 to see my other witty line.
       Post #: 8
RE: Design for Windy conditions - 4/24/2008 5:35:40 AM
BMatthews
Status: offline
Yep, I have to say that 15 isn't considered high around here either.
The only real concern for a windy weather model is that it be able to fly faster than the wind. Outside of that any semi sporty aerobatic model with the CG chosen to be a little closer to the neutral point is going to do just fine. The semi sporty implying such things as Ugly Stiks, GP Sportsters and other similar low to shoulder winged models with minimal dihedral.
Heck, I fly a big light wing loading Barnstormer biplane in winds up to 15 to 18 mph.
Some different flying techniques are needed to fly wind but most of it is just using a little common sense to modify your usual habits.
Bruce-
Proudly wasting balsa since 1965.
Free Flighters go that extra mile........
(in reply to Lomcevak Duck)
       Post #: 9
RE: Design for Windy conditions - 4/24/2008 3:23:20 PM
Villa
Status: offline
I think there is a strong psychological factor involved in high wind flying. While in the air and high up, it can be a lot of fun to see the plane being tossed around. But if you are afraid of damaging the plane during the landing, that fear can drive you right into the ground. A high wind landing with gusts and wind direction changes is a very high tension moment for me. But I'm not afraid of damaging or totaling the plane. I only have SPAD planes now and they survive landing up side down, rolling over and even cartwheels. A very responsive engine with lots of power is a must.
(in reply to BMatthews)
       Post #: 10
RE: Design for Windy conditions - 4/24/2008 5:16:08 PM
alfredbmor
Status: offline
quote:
ORIGINAL: subtleguru
Some possibilities
1. Wind loading ?
4. Size ?
5. Low drag
The best characteristics are those that have the pattern contest planes, IMHO they can beat any plane in a high wind scenario.
Saito Club Member
       Post #: 11
RE: Design for Windy conditions - 4/24/2008 6:44:39 PM
subtleguru
Status: offline
Ahh ...
I imagine it is all a matter of runway width and flying ability then ?
What kind of wind speeds to people consider high then ?
       Post #: 12
RE: Design for Windy conditions - 4/24/2008 8:14:57 PM
alfredbmor
Status: offline
Considering the type of plane I would put it this way:
A tiger Moth model (between 40 and 60 size) won’t like winds of more than 15 mph
A pattern Plane (Venus 40, or Venus II) will fly fine on winds around 30 mph
The ability of the pilot is a must to handle strong winds with any model but there are some "friendly" airframes that can handle high winds easier than others.
I live in an area of high speed winds and there are many pilots at my flying field who manage the wind effortless (Not my case) some of them are very good with pattern planes and have had several first places on pattern contests.
I have learned then that the wind is not an obstacle to fly sport planes but as a personal preference I use to go to the field when winds are mild.
Saito Club Member
       Post #: 13
RE: Design for Windy conditions - 4/24/2008 11:03:48 PM
dick Hanson
Status: offline
quote:
ORIGINAL: alfredbmor
Having flown/designed pattern planes for years- I had to learn to fly in wind long agoand so it poses no problem to me-I get to fly when others won't .
more time for me -
Our old Tipos / ELANS etc, handled easily in wind. fast n light
I am watching you
Libby
(in reply to alfredbmor)
       Post #: 14
RE: Design for Windy conditions - 4/25/2008 12:31:47 AM
