Dodgey99
Joined: 4/30/2003 From: london, IL, UNITED KINGDOM Status: offline
Glad to hear you are getting on a bit better! I tried taking off with the nose-in just now. Blimey! damn near impossible!! Lots more time on the flight sim needed :-) The onboard tail mixer is a bit of a mystery. Sometimes I have to fly with loads, sometimes I have to remove it mid flight! I have now put revo mixing on my TX which seems to have helped, but then again, maybe not! One thing I do do now it give the gyro a good 30 seconds to initialise before moving the heli at all. I'm always inputting gentle rudder to keep her in line, but she will hover for quite a while without much rudder input. Sudden changes in throttle always result in tail rotation. The little motor simply can't keep up. I've ordered a high authority motor to deal with this. I'm fairly sure your TX should work. I'm using PPM. When you say "shift" what are you referreing to? Also, does you all-in one board have a pot (screw) or two to adjust? I know the picolo boards have 2. One for the gyro and one for the Tail mix. If so, search the web for piccolo setup - I have seen sites that detail getting it all right. As a general rule of thumb, info for the FP (fixed pitch) Picollo (as well as parts) apply to the Hummingbird. Keep going. You'll get there. I can now hover a good 5-7 minutes with no touch down and plenty of height. I'm now becoming a danger to objects of value higher up in my living room :-O I'm seriously considering getting a Picollo Pro now as I fancy collective pitch control. :-) Oh dear, must stop spending...
