Hobbsy
VA, USA Status: offline
I would think any oil you put on the air filter is going to be replaced in a matter of seconds with lube oil since every two stroke engine I own spits fuel out of the carb. If you put it on dry it will be oily before you get the engine started. My personal fave for after run is Corrosion X, if you put an engine on the shelf for 5 years and then pull the back plate it will look like new inside and the Corrosion X will look exactly like it did when you put it in there.
_____________________________
Giant Saito, 73.2 Cu. In., 70.5HP @ 5,800 rpm, 79 ft. lbs torque @ 3,500 rpm, 57 mpg, 3.50 bore, 3.81 stroke. 563 lbs.
