RE: HHO gas
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> Off Topic Forum - Cars, Trucks, Buggies and more >> RE: HHO gas
Page: <<   < prev  1 [2] 3   next >   >>
Login
RE: HHO gas - 4/26/2008 2:31:53 AM
500 lb. koolaid man
Status: offline
This is a little off topic but if you wanted to take a shot at biodiesel... there's an easy way to do it.
http://www.rcuniverse.com/forum/m_6686865/anchors_6686865/mpage_1/key_biodiesel/anchor/tm.htm#6686865
Getting the car to run off of pure hydrogen is a whole other story... one near to impossible since it's very inefficient to make hydrogen, although very worth wile despite what some people think.
My advice for wiring it all and hooking up the gas lines is try to pick up tips from water4gas.com there's a lot to learn there, and also realize that it might be even more efficient to use the alternator for power, only using the unused electricity.
Another thing about hooking it up to your engine is the bubbler. You'll blow your self up with out one so make one, it's easy.
Oh and congrads on what you've done so far. Any chance that you could take a picture? Also what's your power source? Thanks.
_____________________________
I have too many projects already... but I always find more.
(in reply to JB COMP)
       Post #: 26
RE: HHO gas - 4/26/2008 2:41:45 AM
The_Shark
Status: offline
i only think a regular engine will work off of hydrogen if it uses a carberator, because it doesnt inject fuel into each cylinder, it lets it go in the intake manifold, and the vaccume takes it in. myth busters are proof of this, you can run a car on it, but you cant make it nearly as fast.
almost %100 sure you cant get this to work without lots and lots of power, and lots and lots of water, its impractical, the best idea is to have a hydrogen tank that you refill in the future, making a self supporting car is BS.
whats a better idea is to get the gas injectors pressured at thousands of PSI, this atomizes the fuel and will give you 120MPG, but again it is most likely not probible for a average joe to make it.
HEY! if you dont want to be judged, dont make a spectacle of yourself!!
       Post #: 27
RE: HHO gas - 4/26/2008 2:57:51 AM
JB COMP
Status: offline
quote:
ORIGINAL: 500 lb. koolaid man
I'll try to get some next time we use it.
LX Comp: STS21B, JP-3, DX3.0 - CRT: STS 30 Rev2 or Mach 427, STS 0702, DX3.0 - T-maxx: TRX2.5
Airtronics. BlueBird.
(in reply to 500 lb. koolaid man)
       Post #: 28
RE: HHO gas - 4/26/2008 3:20:17 AM
500 lb. koolaid man
Status: offline
ok thanks. And just curious, what are you using to power it?
       Post #: 29
RE: HHO gas - 4/26/2008 3:33:24 AM
JB COMP
Status: offline
Oh sorry, I was in the middle of something when I posted on that last post. We are using jumper cables hooked up to a car battery and the cables are hooked up to a 60amp amp meter that has clips coming out the other side. (took us a while to find the amp meter)
       Post #: 30
RE: HHO gas - 4/26/2008 8:50:12 PM
RCtruckRacer
Status: offline
Klein's gas (or Brown's gas) seems to work quite well as a torch, but I just don't see how it could work well in a combustion engine. After all, once the gas is in the chamber how do you get all of it to burn? I don't see how its possible not to have some leftover water after the ignition cycle. I know guys used to put a bit of water in the carb of older engines that used leaded fuel to get rid of the built up carbon...
In the torch any recombination of molecules happens outside the point of ignition so it can't interfere.
Perhaps cars like the Honda FCX will be the way of the future.
Some people see the glass half full. Others see it half empty. I see a glass that's twice as big as it needs to be.
My opinions are my own, and are not necessarily those of RCU
       Post #: 31
RE: HHO gas - 4/26/2008 9:01:59 PM
JB COMP
Status: offline
quote:
ORIGINAL: RCtruckRacer
With the HHo you will get water in your intake, engine, and exhaust. That is why you have to rust proof the engine and exhaust or just run a little gas and you won't have to.
(in reply to RCtruckRacer)
       Post #: 32
RE: HHO gas - 4/26/2008 11:54:43 PM
The_Shark
Status: offline
we have the technology of the future, atomized fuel injectors, they give you 120mpg without hurting performance or redesigning the whole engine.
but the gove, keeps this secret because what would happen if you can buy a car that got 120mpg tomorrow? you would junk your car and fill your tank with 3 gallons, so that junked car along with the millions of other out dated cars would be of no use, car companies and auto sales would go out of business, that would hurt economy something fierce.
so even if they have successful prototypes, you will not get your hands on it for years and years, even a lifetime.
       Post #: 33
RE: HHO gas - 4/27/2008 12:23:51 AM
JB COMP
Status: offline
quote:
ORIGINAL: The_Shark
Well who cares about car companies I want something that will save me money when I go to fill up the tank
(in reply to The_Shark)
       Post #: 34
RE: HHO gas - 4/27/2008 12:31:34 AM
The_Shark
Status: offline
we all do..... if you replace the air filter with a cotton one you will gain 1mpg, if you get a better exghost system it will go up 1 or 2mpg, if you use better octain (doesnt always work) you can gain 1mpg.
so you can possibly get upto 4mpg, which is actually pretty great.
also, if i drive MY car with more pedal, i get 1.5mpg better
       Post #: 35
RE: HHO gas - 4/27/2008 4:38:31 AM
500 lb. koolaid man
Status: offline
I worked on a new cell most of the afternoon and it works amazing. I stole the idea from water4gas.com where they wrap wire around the plus sign shaped thing in the picture(the wood). What I did for anyone interested... I cut out 3 pieces of wood and glued them together. Then I ripped the copper wires out of a power cord(like from a lamp) and wrapped them around the wood "intertwined sort of" as shown in the second picture. I plugged it in and that's the best results I've ever gotten by far. Hydrogen mist, I can smell it, lots of bubbles. Funny how the hydrogen wire(negative) turned blue. And the water went from cold to warm(no surprise). I think my mini torch will be made after I get a new power source. My 6 amp computer power supply doesn't run more than 15 seconds at a time before I have to restart it.
sorry no shots of it in action... hopefully tomorrow
This is a picture from water4gas.com showing how my wires are wrapped(the red and black, + and -) it also shows what a bubbler is.
This is my CPS(computer power supply) and also in the picture is what I made this morning... a torch tip. I cut the top of an air compressor thing meant for filling up basket balls and stuff and what do ya know... hobby fuel line fits perfectly snug on the inside! So that's my fuel line for the torch tip.
       Post #: 36
RE: HHO gas - 4/27/2008 2:58:05 PM
The_Shark
Status: offline
very cool. gotta find a better amp though, i know some speaker recivers put out around 30 to 75 amps, but the volts tend to be low.
       Post #: 37
RE: HHO gas - 4/27/2008 8:10:15 PM
rcluke
Status: online
quote:
ORIGINAL: JB COMP
Anyone know anything about? or how to hook it up to a car to run HHO instead of gas? My family is tried of paying for the $3.50+ a gallon stuff (one of my bro's is paying over a $1,000 a month just in diesel for his truck)
If anyone knows anything about or electronics, we would appreciate the help.
$3.50 is cheap as hell.
1 gallon = 4.55 litres.
over here it is £1.12+ per litre.
that's £5.96 a gallon ($11.92)
you really have it good, i wouldnt be moaning if i was you
My Racer - Novak GTB 5.5T Brushless Tamiya TA-05
NOVAK OR NOTHING
       Post #: 38
RE: HHO gas - 4/27/2008 9:46:22 PM
JB COMP
Status: offline
quote:
ORIGINAL: rcluke
quote:
ORIGINAL: JB COMP
You probably make more then we do over here.
(in reply to rcluke)
       Post #: 39
RE: HHO gas - 4/27/2008 9:49:21 PM
hands without shadows
Status: offline
Hey koolaid, do you think you could get a short vid of just how much H2 it produces? Right now I'm using a piece of half inch PVC pipe with two copper wires wrapped around it in a double helix with a pitch of about 3/16" running on 12v and it still takes me over an hour to fill a water baloon.
_________
O||||||||O
       Post #: 40
RE: HHO gas - 4/28/2008 1:24:00 AM
500 lb. koolaid man
Status: offline
Hands, I'm glad to hear you're trying to make HHO too That makes for 3 of us here. Basically most of my weekend has went into trying to make an HHO torch and I got close today but no cigar. After I fin
