Redharris
CA, USA Status: offline
Yep.....that Can Happen (Just like Mac says).... See if you cant figgure a way to mount a Throttle return spring to the carb SLIDER... Probably wont help if a High Torque servo decides to stick Wide Open, but if the servo just Dies n goes loose (broken wire) or the linkage comes loose, it might save you... Damn, but you are havin the Worst luck with all that small Stuff.... Ya need to get all that small stuff sorted out, so you can Run like you're Supposed too....... And.....run into a building at Full Throttle, the way WE all do! Lol....
_____________________________
OFFICIAL HIMOTO RACING SUPPORT - THE REVOLUTION HAS BEGUN http://himotoracing.com :: http://himotoracingusa.com
