what motor for the 52in fusion
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Profile and Fun Flying Planes >> OMP - Ohio Model Products Support Forum >> what motor for the 52in fusion Page: [1]
Login
what motor for the 52in fusion - 4/25/2008 6:42:17 PM
dragnbye
Status: offline
i am looking for somthing with good pullout and great power. i dont care about 2 or 4 storke what is the setup your using and do you like or would you change it
_____________________________
buy a funtana 100, saito culb member 559
       Post #: 1
RE: what motor for the 52in fusion - 4/25/2008 7:37:06 PM
AFSalmon
Status: online
Any .46 bb motor will be a good choice. We all used the TT Pro .46, OS .46FX, GMS .47, etc. motors a lot. the new OS .55AX is one of the better choices these days and my personal favorite.
Mike (Salmon) Pilkenton, Chief Slab Designer
Ohio Model Planes, Team OMP Captain
(in reply to dragnbye)
       Post #: 2
RE: what motor for the 52in fusion - 4/26/2008 3:09:47 AM
Brasilfred
Status: offline
Ola Salomon,
my Mark/Moki .61-2strk with standard muffler is looking for nice kit (not arf).
Greetings from Brazil
Manfred
P.S. How i can register me on your sites? Your registration form knows only 2 countries US and Canada and our Zip have 8 numbers.
       Post #: 3
RE: what motor for the 52in fusion - 4/26/2008 4:24:48 PM
daveopam
Status: offline
I have a Saito 72 on mine with a APC13x4W. This is a sweet combo. I can point mine up at arms length, throttle up and let go. It pulls out with great authority. Hover is about 1/2 power.
david
"Choose your shirt and shoes by the color. Choose your friends by their character." unknown
(in reply to Brasilfred)
       Post #: 4
RE: what motor for the 52in fusion - 4/27/2008 2:07:10 PM
AFSalmon
Status: online
The problem with .61 engines are they are essentially the same physical size and weight as most .91 motors. The 52 Fusion is not designed for that big or heavy engine. Currently the 52 Fusion ARF and kit are both sold out.
(in reply to daveopam)
       Post #: 5
RE: what motor for the 52in fusion - 5/1/2008 7:51:45 AM
Chuckar
Status: offline
I have a 52” Fusion and a OS .55AX what would be the best prop to run on it.
Thanks Tom
(in reply to AFSalmon)
       Post #: 6
RE: what motor for the 52in fusion - 5/1/2008 1:19:21 PM
AFSalmon
Status: online
Tom, a 13-4 is the most popular prop for the OS 55.
(in reply to Chuckar)
       Post #: 7
RE: what motor for the 52in fusion - 5/6/2008 12:21:31 AM
toro_0397
Status: offline
hi
can someone tell me what is the total weight of the plane with an os 55
thanks
       Post #: 8
RE: what motor for the 52in fusion - 5/6/2008 1:13:23 PM
AFSalmon
Status: online
Kinda depends on several other factors like what servos are used and what size battery. Most Fusions weight in about 4 1/4 lbs with the .46 motor like the OS 46FX. I think the 55AX is a couple oz heavier so say 4 lbs 6 oz typical.
(in reply to toro_0397)
       Post #: 9
RE: what motor for the 52in fusion - 5/7/2008 3:05:29 AM
toro_0397
Status: offline
does somebody knows when the fusion 52 arf is going to be in stock again?
is it true that they changed the covering for ultracote?
thanks
       Post #: 10
RE: what motor for the 52in fusion - 5/7/2008 12:44:53 PM
AFSalmon
Status: online
All future OMP ARFs will be Ultracoat. The 52 Fusion will be produced again probably this next Fall. We have several other slabs we'll be focussing on over the summer.
       Post #: 11
RE: what motor for the 52in fusion - 5/8/2008 11:49:30 PM
3dak
Status: offline
Hi Mike, Suggestions for engine for 47 edge? It was kit built by a friend and I have an OS 70fs or a Rossi 45. Could also put the rossi on a tuned pipe as well. I'm near denver and fly at 5000 ft. Thanks in advance
       Post #: 12
RE: what motor for the 52in fusion - 5/9/2008 1:13:13 PM
AFSalmon
Status: online
quote:
ORIGINAL: 3dak
Hi, I responded in the other thread for you.
(in reply to 3dak)
       Post #: 13
Page:   [1]
Page: [1]
Jump to:
