What are you using for canopy glue?
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Airplanes >> Giant Scale Aircraft - General >> What are you using for canopy glue?
Page: [1]
Login
What are you using for canopy glue? - 4/25/2008 9:18:45 PM
XtremeAerosport
Status: offline
RC-56?
Shoe-Goo?
Epoxy?
CyA?
Spit & Bubblegum?
Tell us your preferred glue, what has worked and what has not.
How about glues available at Michaels or Wal-Mart?
Jon
_____________________________
Jonathan Ott
Extreme Aerosports
       Post #: 1
RE: What are you using for canopy glue? - 4/26/2008 1:16:01 PM
pahtreek
Status: offline
I have always used rc-56, then I put a light coat of 30min+ epoxy over the outside edge after it has cured to keep oil, gas etc from getting into the joint. Never had a problem except if I ever needed to take it off....lol
"Now YOU listen to me Bobby Boucher! ARF's are da-devil !"
But mama, I LOVE them! They make me feel good.
(in reply to XtremeAerosport)
       Post #: 2
RE: What are you using for canopy glue? - 4/26/2008 3:47:40 PM
FBaity
Status: offline
RC-56 has worked well for me on last 20 or so projects, furthermore, I find should I need to I can remove the canopy.
Frank Baity
AMA 38026
(in reply to pahtreek)
       Post #: 3
RE: What are you using for canopy glue? - 4/27/2008 7:11:20 PM
safeTwire
Status: offline
RC 56 works great! Applies colored white and dries clear. I have removed covering material where the canopy sits, or, have just scuffed the material slightly (instead of removal) and have had good results either way. You can add a healthy fillet of this glue for insurance, and unless your aiming for static points in Scale, it will look ok. Holds very well too. I "dumb-thumbed" In an Extra 300 into a plume of confetti, and the canopy stayed fixed to the balsa, which saved the pilot!
(in reply to FBaity)
       Post #: 4
RE: What are you using for canopy glue? - 4/27/2008 9:25:01 PM
SunDevilPilot
Status: offline
Used RC-56 in the past. Recently switched to E-6000 and found it far superior. Quite a bit thicker making it easier to apply. Plus, once applied any "runs" can be removed by waiting about 5 minutes and rubbing it off. Turns into a little ball and comes off clean. Does not fog plastic or monokote and once dried will not come off.
Can be purchased at Michaels or the craft department of Walmart.
Heard about it on the jet forums. Used it on my 29% Edge and was much happier than with RC-56.
SunDevilPilot
Click to see fullsize image.
Click for fullsize
Click for fullsize
"In God we Trust. All others we run through NCIC"
(in reply to safeTwire)
       Post #: 5
RE: What are you using for canopy glue? - 4/28/2008 2:00:18 PM
Edwin
Status: offline
Guess another bump for RC-56. My latest bottle says Formula 560, from Pacer.
Edwin
(in reply to SunDevilPilot)
       Post #: 6
RE: What are you using for canopy glue? - 4/28/2008 2:33:17 PM
Mark in Michigan
Status: offline
I just tried the Pacer Canopy Glue for the first time and liked it.
(in reply to Edwin)
       Post #: 7
RE: What are you using for canopy glue? - 4/29/2008 3:52:01 PM
XtremeAerosport
Status: offline
Thanks guys. I've used RC-56 or Formula 560 in the past, but don't care for it being so thin. I've spied the E-6000 in the stores and wondered about it, but wanted to know if anyone else had treid any other adheasives.
Jon
Jonathan Ott
Extreme Aerosports
(in reply to Mark in Michigan)
       Post #: 8
RE: What are you using for canopy glue? - 4/29/2008 4:25:28 PM
FlyingGreg
Status: offline
I've used Goop anp and Canopy Glue, the white kind with good success. The Goop has to be cleaned with alcohol before if fully cures, but man does it hold. Canopy glue is a little easier since it cleans with water but I don't think it holds as well. That E6000 stuff sounds like the berries. Will give it a try. Thanks, SunDevil!
...nothing in moderation...
       Post #: 9
RE: What are you using for canopy glue? - 4/30/2008 12:45:33 AM
kid chuckles
Status: online
Best glue is screwing it on lol. Can remove quickly and no mess. Other than that Spit and gum would hold goooooood.
(in reply to FlyingGreg)
       Post #: 10
RE: What are you using for canopy glue? - 4/30/2008 10:34:27 PM
jammd33
Status: offline
E6000 or Zap A Dap A Goo
(in reply to kid chuckles)
       Post #: 11
RE: What are you using for canopy glue? - 4/30/2008 10:35:39 PM
jammd33
Status: offline
E6000 or Zap A Dap A Goo use a small syringe and apply a thin bead. holds great/ very neat.
       Post #: 12
RE: What are you using for canopy glue? - 5/1/2008 1:44:54 AM
bodywerks
Status: offline
Never liked the RC-56 and had little success with it, and it is a pain to use because it flows too easily and it really doesn't clean up all that well.
Now, on an ARF, I use clear RTV - about a 1/16" tall bead. You need to roughen up the canopy and covering where it will contact with some 180-220 and wipe it clean with 90%+ isopropyl alcohol. You then press the canopy on to about where you want it, wipe away excess with an alcohol-dampened cloth, then position it exactly where you want it, tape it in a couple places and again wipe the excess, then really tape it down and let it sit for about 12 hours and remove the tape. If any RTV has oozed out wher there was tape, you can typically roll your finger over it and lift it off. After 24 hours it's all cured and ready for flying. The RC56 seems to take a month!!!
On a kit build, I use a high grade of 30-45minute epoxy, and I roughen up the canopy with some 60-80 grit.
STRAIGHTEN UP AND FLY LIGHT!!!
(in reply to jammd33)
       Post #: 13
RE: What are you using for canopy glue? - 5/1/2008 8:17:06 PM
HornetFitter
Status: offline
I used 12 minute epoxy on my H9 Cub.
Hold very well and on the windscreen, I got some tiny little #2 x 3/8 hex head screws to hold it in place. That way I can remove it.
(in reply to bodywerks)
       Post #: 14
RE: What are you using for canopy glue? - 5/4/2008 10:17:40 PM
Top_Gunn
Status: offline
I use a mixture of epoxy, microballoons, and paint (to match the covering). The microballoons make the epoxy less runny. I've used RC-56 (or whatever they call it now), and it's great after it dries, but it does run. The epoxy mixture doesn't, and adding the balloons makes it set up pretty fast, too.
(in reply to HornetFitter)
       Post #: 15
RE: What are you using for canopy glue? - 5/4/2008 11:05:10 PM
XtremeAerosport
Status: offline
I picked up a tube of E6000 at wal mart this weekend. I also got a sampler pack of all the Eileen's tacky glue series for under $2 at W-M. I think the E6000 will be the way to go.
Jon
Jonathan Ott
Extreme Aerosports
(in reply to Top_Gunn)
       Post #: 16
RE: What are you using for canopy glue? - 7/21/2008 7:02:56 AM
