RE: My custom Rx hump pack
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Monster Trucks >> HPI Monster Truck Forum >> RE: My custom Rx hump pack Page: <<   < prev  1 [2] 3   next >   >>
Login
RE: My custom Rx hump pack - 5/6/2008 4:00:45 AM
go-to
Status: offline
quote:
ORIGINAL: Rudeboy
Soldering battery cells works best if you use a heavy tip on your soldering iron: it stores more heat than a small tip.
The faster you can solder, the better for the cell: batteries don't like excessive heat. That means a big iron.
Properly sand the battery terminals: they're likely to be nickel plated against corrosion.
Use an etching compound, this really helps, but you have to wash the remains off afterwards.
First tin the battery terminals and the wire seperately, solder them together afterwards.
That about sums it up.
I wouldn't suggest this to someone with no technique...from someone that's soldered for so long at such a high level. Giving anyone with no experience a hot iron and large tip is just *asking* for a burnt piece.
And you don't need to sand or etch on the terminals. I didn't on this pack I made here.
Now you are correct about tinning both the battery and wire before putting them together. That is great technique that not many follow.
_____________________________
Savage X SS, FLM LCG TVP, Axial .28, 3-speed, 18/49
Savage 25, SureFire 32R RB Mods, 4-gears diff's, 2-speed, 18/47
(in reply to Rudeboy)
       Post #: 26
RE: My custom Rx hump pack - 5/6/2008 4:33:38 AM
Rudeboy
Status: offline
Well, if you use too small an iron, you're gonna be frying your cells. I'm not saying you should use a 150W gutter soldering tool. I'm saying you should use a decent temp controlled iron, at least 35 to 40 watts strong, set at no more than 280-290 degrees C (535-555 degrees F) when using standard 60/40 Sn/Pb resin core solder.
The bigger tip has more heat capacity at low temps, so it won't cool down below soldering temp.
My experience is that an etching compound helps when soldering cells with resin core solder. I always use it. It cuts down the time needed to tin the terminals, and again less heat into your cells is better.
Sanding "may not" be needed, but it sure helps. Bare metal works best, and you never know what these cells are coated with. It certainly won't hurt anything!
But that's just my 0.02$
Revver Brother #33
...I think it needs more power...
(in reply to go-to)
       Post #: 27
RE: My custom Rx hump pack - 5/6/2008 5:01:02 AM
go-to
Status: offline
quote:
ORIGINAL: Rudeboy
[Sarcasm mode on]
Thanks for the lesson...very very helpful to me.
[/Sarcasm mode off]
Man I wanna say more, but I'll let it go if you will. I certainly don't need a lesson in basic soldering skills.
       Post #: 28
RE: My custom Rx hump pack - 5/6/2008 5:39:43 AM
Rudeboy
Status: offline
Well, I'm sorry I hurt your feelings...
Revver Brother #33
(in reply to go-to)
       Post #: 29
RE: My custom Rx hump pack - 5/6/2008 5:44:00 AM
go-to
Status: offline
quote:
ORIGINAL: Rudeboy
Ya didn't. That was the point.
       Post #: 30
RE: My custom Rx hump pack - 5/12/2008 4:27:38 AM
nghtrdr
Status: offline
hmmm...
me likes!
great work man.
i use those same cells in my tx they last forever.
my question is about charging. if i make this pack (im not too bad at soldering) can i charge it using my Team Orion Avionics advanced flight charger (#ORI62200). what charge current should be used? can i still fast charge?
hxxp://www.teamorion-avionics.com/Advantage+Chargers/Advanced+Flight+Charger
thnx and again great work!
nightrider
(in reply to go-to)
       Post #: 31
RE: My custom Rx hump pack - 5/12/2008 4:50:26 AM
go-to
Status: offline
quote:
ORIGINAL: nghtrdr
hmmm...
me likes!
great work man.
nightrider
You certainly can use that charger. I charge my pack at 2.2amps which doesn't heat up the pack too much and makes for a long-lasting pack. I never found it necessary to charge above 1c which would be 2.5amps in this case.
(in reply to nghtrdr)
       Post #: 32
RE: My custom Rx hump pack - 5/12/2008 9:42:35 PM
nghtrdr
Status: offline
cool
thnx for the info!
(in reply to go-to)
       Post #: 33
RE: My custom Rx hump pack - 5/13/2008 2:44:05 AM
brett65
Status: offline
Hey, what do you mean by 1C charge? Is that coulombs or something? My duratrax charger is in amps, so when I saw you guys using C it threw me for a loop.
Truckzilla w/LRP28,Firestorm,Spek DX3.0,Micro-T,uglystik,SkyRaider Mach 1 TTpro 46,Phoenix Extra 300S OS 55AX Futaba 2.4 6EX
       Post #: 34
RE: My custom Rx hump pack - 5/13/2008 3:07:58 AM
go-to
Status: offline
quote:
ORIGINAL: brett65
1C for a 2500mAh pack would be 2.5amps. 2C would be 5amps. See?
(in reply to brett65)
       Post #: 35
RE: My custom Rx hump pack - 5/13/2008 4:56:49 PM
brett65
Status: offline
quote:
ORIGINAL: go-to
quote:
ORIGINAL: brett65
Oh! It's dependent upon the battery! Seems like I learn something new everyday!
(in reply to go-to)
       Post #: 36
RE: My custom Rx hump pack - 5/13/2008 5:45:12 PM
go-to
Status: offline
quote:
ORIGINAL: brett65
Man you got that right...
       Post #: 37
RE: My custom Rx hump pack - 5/14/2008 8:58:51 PM
brett65
Status: offline
Thought I would share that I saw that Rayovac has rechargeable 2400mAh AA Nimh batteries now, 5 bucks for four and they will work in the energizer recharger or with an rc charger.
(in reply to go-to)
       Post #: 38
RE: My custom Rx hump pack - 5/14/2008 9:39:51 PM
go-to
Status: offline
quote:
ORIGINAL: brett65
