I DONT KNOW WHAT IS WRONG WITH MY CAR!!
Tower Hobbies
Logged in as Guest
  Printable Version
HPI Racing Savage X SS - Kit
Seller:  CrazyBRONCOguy
Details:   $500.00   |  8/17/2008   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Cars, Buggies, Trucks, Tanks and more >> RC Drifting >> I DONT KNOW WHAT IS WRONG WITH MY CAR!!
Page: [1]
Login
I DONT KNOW WHAT IS WRONG WITH MY CAR!! - 4/26/2008 5:44:32 PM
charmanderxd
Status: offline
Hi every one i got a tt-01 and a hitech aggressor 3 ch transmitter and for some reason the first few days it was doing fine but like 3 days after i drift around with it it just in times just go full throttle on me and hit things i thought it had dirt or water in the receiver and so i let it dry out for a few days and i blew in side of it. But it still dose the same thing
Can anyone tell me whats going on???????
Thanks for reading.
       Post #: 1
RE: I DONT KNOW WHAT IS WRONG WITH MY CAR!! - 4/27/2008 3:27:50 AM
magnat
Status: offline
Check your controller Batteries they may be flat??
It Sounds like your ESC may be getting out of range ?? What model ESC is it?
_____________________________
Traction: What a drag.....
(in reply to charmanderxd)
       Post #: 2
RE: I DONT KNOW WHAT IS WRONG WITH MY CAR!! - 4/27/2008 5:52:39 AM
charmanderxd
Status: offline
Well my battery is always fully charged it uses 8 aa and i bought rechargeable batteries for it the ESC model is HFS-03MT and i never get out of range because my back yard is small it only goes like 15-20 feet away from me and one time i was only like 5 feet away and it still dose the same thing. so i dont know whats going on?????
       Post #: 3
RE: I DONT KNOW WHAT IS WRONG WITH MY CAR!! - 4/27/2008 7:29:44 AM
magnat
Status: offline
HFS-03MT is your Reciever Model not your ESC, the ESC is connected to the Motor...
       Post #: 4
RE: I DONT KNOW WHAT IS WRONG WITH MY CAR!! - 4/27/2008 7:59:31 AM
charmanderxd
Status: offline
oh lol oops still noob XD my esc is a tamiya TEU-101BK
       Post #: 5
RE: I DONT KNOW WHAT IS WRONG WITH MY CAR!! - 4/27/2008 11:32:38 AM
TIGER76
Status: offline
If youve centred your trims on the radio etc sounds like your ESC is on the way out,which is surprising as the TEU-101BK is a tough lil esc too,has it ran in water? that usually kills them pretty quickly,the dust shouldnt be a problem mines been caked in mud,dust,crap loads of times and still runs fine but i know when it hits puddles it shutsdown for a while lol
VXL pede/ 9.6v 4200 mAh & 8.4v mAh
TT-01r / Quake ESC / Trinity D6 9Turn / Orion Rocket Pack 4500 (X2)
       Post #: 6
RE: I DONT KNOW WHAT IS WRONG WITH MY CAR!! - 4/27/2008 4:14:17 PM
FireStriker
Status: offline
check the attena's on both the transmitter and reciever, it might be loss of signal
Keep It Slideways......
Street Drifter/ Street Racer.......
(in reply to TIGER76)
       Post #: 7
RE: I DONT KNOW WHAT IS WRONG WITH MY CAR!! - 4/28/2008 3:00:28 AM
charmanderxd
Status: offline
Well water might be the problem because i use buckets to practice drifting, and i hit the buckets and sometimes there are water in them so water is the problem. so what is a good esc for a stock tt-01d? i need to buy the aluminum shaft soon to.
(in reply to FireStriker)
       Post #: 8
RE: I DONT KNOW WHAT IS WRONG WITH MY CAR!! - 4/28/2008 5:32:55 AM
AutoXMan
Status: offline
It shouldn't be the ESC. I think it is your receiver. ESC's can handle water 200% better than receivers which cannot tolerate any water. Try a different radio setup before you spend your hard earned money on something you may (probably) not need.
       Post #: 9
RE: I DONT KNOW WHAT IS WRONG WITH MY CAR!! - 4/28/2008 6:02:47 AM
charmanderxd
Status: offline
So i am kind of confused so you want me to but a new transmitter or just the receiver?
(in reply to AutoXMan)
       Post #: 10
RE: I DONT KNOW WHAT IS WRONG WITH MY CAR!! - 4/28/2008 8:19:11 AM
magnat
Status: offline
Just the Reciever..
So if you have a 27Mhz System, you need to buy a New 3-channel reciever, the thingy which all the wires plug into and has the Aerial wire comming out of it
If you have a 40Mhz system then you need to buy a new 40mhz 3-channel reciever..
Quickest way to tell what Mhz system you have is to look at the Crystals.. see what channel they are then buy a reciever to suite...
       Post #: 11
RE: I DONT KNOW WHAT IS WRONG WITH MY CAR!! - 4/29/2008 5:40:54 AM
NoobDrifter
Status: offline
I'm having the same problem after running 16volts through my 12volt futaba magnum controller(two 7.2v packs connected to it because I was out of AA's). It was fine the first day, then I let a friend run it and ever since it looses signal at 20ft. I changed the to 3 different receivers with the same results. Finally I went to a different controller and it works fine.
(in reply to magnat)
       Post #: 12
Page:   [1]
Page: [1]
Jump to:
