RE: TMMY Scale Composites 35% scale Cessna    Gallery
Logged in as Guest
    Search This Thread
Printable Version
Premier Pilot 1/4 scale full body pilot
Seller:  Ren DiLeo
Details:   $129.00   |  3/24/2013   |  Classified Ad
We will rotate YOUR AD in this spot if you select "Forum Featured" when placing or editing your ad!
All Forums >> RC Airplanes >> Giant Scale Aircraft - General >> RE: TMMY Scale Composites 35% scale Cessna
Page: <<   < prev  56 57 [58] 59 60 61 62 63 64 65   next >   >>
Login
RE: TMMY Scale Composites 35% scale Cessna - 4/1/2012 7:30 PM
TSHARK203
Score: 107
Last Login: 5/19/2013
Status: online
I find I did not have any flat spots in my tires when I was using Glennis Wheels on my last bird. I am going to try the skylites being they came with this bird. The old tires Tommy was using were crap as they were foam and would flat out on you.
I as I stated earlier have added gussets in the aft joint of the fuse to try and help spread the load out. Plane should be done this week after the rest of my lights show from Details 4 Scale. Dan does a great job with the lights and my two little guys show as well. If my new seats from Tommy arrive as well I will really be in business.
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
_____________________________
Fly the friendly Luftwaffe skies.
Hide Signatures
(in reply to cgcrc)
       Post #: 1426
RE: TMMY Scale Composites 35% scale Cessna - 4/2/2012 2:06 PM
style fly
Score: 100
Last Login: 4/29/2013
Status: offline
Hey Guys - thank you for all your response to all my ?'s.... they were all very usefull- as far as my fuse I DID reinforce the join platform - We sanded down the the dry "RICE GLUE" and re-glued with AERO-POXY with added fiberglass and wood block supports-  If you zoom in on the photo -you will see the support up-grade to the rear joint plate- the back cover goes over it and hides everything- we also added a extra center bolt on the top- I too had a issue where on the 2nd flight the rear tail broke off the and totaled the whole plane- it was a bad day.........needless  to say we did our best to prevent it from happening again- This is my 2nd cessna from Tommy- I just have to have this plane in my fleet- it has too much WOW factor
Click for fullsize
< Message edited by style fly -- 4/2/2012 3:41 PM >
Hide Signatures
(in reply to cgcrc)
       Post #: 1427
RE: TMMY Scale Composites 35% scale Cessna - 4/2/2012 7:08 PM
cgcrc
Score: 100
Last Login: 5/9/2013
Status: offline
Hi Fellows;
The gussets you have added look pretty good and as you say a necessity. A fair bit of weight hanging out there with the trike gear or tail dragger.
Looks like Tommy has changed his wheel selection a few times. The orginal with the 185 had a small industrial wheel and tire with a inner tube.
No flat spots but very heavy. Thus the change over to Sullivan.
Have fun with your 182’s this year, they look great.
Regards
Randy
Hide Signatures
(in reply to style fly)
       Post #: 1428
RE: TMMY Scale Composites 35% scale Cessna - 4/2/2012 7:12 PM
cgcrc
Score: 100
Status: offline
Forgot to mention, George, really like the added touches with the instrument panel, operational controls, pilots and your civil air patrol paint scheme.
Randy
Hide Signatures
       Post #: 1429
RE: TMMY Scale Composites 35% scale Cessna - 4/3/2012 6:05 AM
TSHARK203
Score: 107
Status: online
quote:
ORIGINAL: cgcrc
Randy
Thanks Randy for the comments. I need to do a tail dragged like yours next.
I am hoping that this plane will be a real head turner not only in the air but on the ground as well. I am hoping that I can dress up this on as well as the last one. Got to go back to work on the plane. I am adding functional scale gas caps for filling the fuel tanks through the wing. I figured the plane is big enough so it souls work just fine.
George
Hide Signatures
(in reply to cgcrc)
       Post #: 1430
RE: TMMY Scale Composites 35% scale Cessna - 4/4/2012 12:15 PM
style fly
Score: 100
Status: offline
So here is the lastest mod to the transport cradel. I had to raise the back of the cradel to compensate for the contour of the fuse- its now very secure for high mileage transporting- next is to make one for the tail. I'll post photos as soon as possible. You will see a double chin brace - most of the weight is on that support- Im not sure how I could have done it different but this seems fine......
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
(in reply to TSHARK203)
       Post #: 1431
RE: TMMY Scale Composites 35% scale Cessna - 4/6/2012 4:17 AM
cgcrc
Score: 100
Status: offline
Hi Fellows;
Style Fly, nice looking and functional transportation cradle. No worries now re flat spots on the tires or securing the model to avoid rolling around in the back of your vehicle or trailer.
George, keep us posted on the added details to your 182, agreed, it certainly adds to the appearance and added conversation with the spectators.
Also agreed, the size of model makes easier access and fabrication of those special parts. I’m just finishing the aluminum step on the fuse for the pilot access to the wing tanks etc.
If you do pursue with the 185 at some point let me know and I can pass on my experiences with this model.
Regards
Randy
Hide Signatures
       Post #: 1432
RE: TMMY Scale Composites 35% scale Cessna - 4/6/2012 7:41 AM
spidernad
Score: 100
Status: offline
Oh No!
I've discoverd RC scale rock crawler trucks!
Had to find some something to do while I'm waiting for an engine for my Cessna.
Here are a couple of pics of my first build attempt.
I know, it's not a plane.
Click for fullsize
Click for fullsize
Watch my RC videos here: http://www.youtube.com/user/spidernad1
Hide Signatures
(in reply to cgcrc)
       Post #: 1433
RE: TMMY Scale Composites 35% scale Cessna - 4/6/2012 12:13 PM
style fly
Score: 100
Status: offline
Hey Dan- I think you posted on the wrong forum !!!!!!!!!!!!! That engine better get here fast or we are going to lose you to the 4 wheelers  ( LOL )  anyway it is a mean truck
Hide Signatures
(in reply to spidernad)
       Post #: 1434
RE: TMMY Scale Composites 35% scale Cessna - 4/6/2012 5:07 PM
spidernad
Score: 100
Status: offline
quote:
ORIGINAL: style fly
I hear that!
Hide Signatures
       Post #: 1435
RE: TMMY Scale Composites 35% scale Cessna - 4/8/2012 4:20 AM
style fly
Score: 100
Status: offline
I could not stand the shiny top of the Cessna dash board - I went to JoAnn's Fabric and picked up some mat vinyl leather - I made this templet- cut one out - now it looks much better....
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by style fly -- 4/8/2012 4:17 PM >
Hide Signatures
       Post #: 1436
RE: TMMY Scale Composites 35% scale Cessna - 4/8/2012 5:44 AM
TSHARK203
Score: 107
Status: online
Well I am almost finised with the CAP bird. She will have pleanty of flights on her before Joe Nall. I have all my nav lights run an working thanks to Dan Gill at Details 4 Scale. He does great work as always. The new lights and strobes are so bright you have no trouble seeing them in the day light. They are much better then the set I had on the last bird. I got all my other wires and leads run and closed the plane up this evening. Now it is on to the detail work.
I figured on this plane I wanted to hide the swithches better so I made a panel an installed them under the seat at an angel. Much easier to get to then what I had before. I did some detail work on my landing lights by adding a smooth lens to the landing light an a waffel lens to the taxi light. As per the full scale. My pilots showed up form Patti and holy s#!t do they look great The flight suits she and Katherine did are top notch. I did the mod on the mini me so now his head turns with the rudder and the arms will move with Dan's wonderful rigg he made for my panel. The civil air partol patches I had custom made arrived today. So now I get the task of copying them all and shrinking them down on heavy card stock to add them to the flight suits. But it is all in the details as it is with any plane. I will have more pics tomorrow.
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 1437
RE: TMMY Scale Composites 35% scale Cessna - 4/8/2012 7:10 AM
mifsudm
Score: 100
Last Login: 5/10/2013
Status: offline
Hi Mario,
what is the take off weight of your Cessna??
regards
Martin.
Hide Signatures
(in reply to mario tavarez14)
       Post #: 1438
RE: TMMY Scale Composites 35% scale Cessna - 4/8/2012 7:55 AM
TSHARK203
Score: 107
Status: online
A few more pics
Click for fullsize
Click for fullsize
Click for fullsize
Click for fullsize
Hide Signatures
       Post #: 1439
RE: TMMY Scale Composites 35% scale Cessna - 4/8/2012 11:43 AM
Adrian_CH
Score: 100
Last Login: 4/18/2013
Status: offline
Hy Tshark,
from where you get the Dashboard?
Greetings from Switzerland
Adrian
Hide Signatures
       Post #: 1440
RE: TMMY Scale Composites 35% scale Cessna - 4/8/2012 11:53 AM
Adrian_CH
Score: 100
Status: offline
I get the Lightsystem from InnoSky.It works very well and is fully self programmable with a PC.
Adrian
Hide Signatures
(in reply to Adrian_CH)
       Post #: 1441
RE: TMMY Scale Composites 35% scale Cessna - 4/8/2012 12:41 PM
style fly
Score: 100
Status: offline
Hey Tshark that Cessna is insane it could have a place at Top-Gun........ when you get to Joe Nall see Scott from SKS video and get interviewed on DVD. great work -Please keep posting photos.....
Hide Signatures
       Post #: 1442
RE: TMMY Scale Composites 35% scale Cessna - 4/8/2012 3:35 PM
TSHARK203
Score: 107
Status: online
quote:
ORIGINAL: style fly
She is still a long long way from top gun quality but it will be OK for local events. I still have tons of work to do inside and outside the plane. I also have video cams I need to find a way to install in the plane. Well today is antenna making day what joy. I am also going to tackle the fuel filler from the wing. Carp I guess I should have not closed up the cockpit floor yet. As the fuel line has to run from the wing to the fuel tank.
Adrian
The dash came from Vogelsang-aeroscale here in the USA. He orders them from a guy who custom makes them over in Germany.
Hide Signatures
       Post #: 1443
RE: TMMY Scale Composites 35% scale Cessna - 4/8/2012 3:52 PM
mifsudm
Score: 100
Status: offline
hi Tshark,
i installed the fuel system from the wing and it turned out to be awesome. i will post some pics later.
regards
Martin.
Hide Signatures
       Post #: 1444
RE: TMMY Scale Composites 35% scale Cessna - 4/8/2012 4:44 PM
TSHARK203
Score: 107
Status: online
Hey style fly
Do you still have any parts from your cessna that crashed. I have some how lost the divider that covers up the back in the fuse. Or if any one has an extra one please let me know.
George
Hide Signatures
(in reply to mifsudm)
       Post #: 1445
RE: TMMY Scale Composites 35% scale Cessna - 4/8/2012 5:11 PM
style fly
Score: 100
Status: offline
Hey Tshark , Im sorry - I do not have that back plate- after the crash I sold the remains of the plane to a fiberglass exbert who is going to repair it for static display - Im surprised that Tommy wont send it to you!!!! I can send you a templet if it helps    let me know
Hide Signatures
       Post #: 1446
RE: TMMY Scale Composites 35% scale Cessna - 4/8/2012 5:15 PM
Adrian_CH
Score: 100
Status: offline
Tshark many Thx,
Have you the Adress from the German Guy?Germany is only 50 Km from me.....
Adrian
Hide Signatures
       Post #: 1447
RE: TMMY Scale Composites 35% scale Cessna - 4/8/2012 6:30 PM
spidernad
Score: 100
Status: offline
quote:
ORIGINAL: Adrian_CH
Tshark many Thx,
Adrian
Adrian, the web address is.  http://www.noll-modelltechnik.de/index.htm
Dan
Hide Signatures
       Post #: 1448
RE: TMMY Scale Composites 35% scale Cessna - 4/8/2012 6:35 PM
spidernad
Score: 100
Status: offline
quote:
ORIGINAL: Adrian_CH
Tshark many Thx,
Adrian
Adrian,
This is the page with the Cessna 182 Dash.  http://www.noll-modelltechnik.de/cockpits_sonstige_2.htm
Dan
Hide Signatures
       Post #: 1449
RE: TMMY Scale Composites 35% scale Cessna - 4/9/2012 5:32 AM
frets24
Score: 148
Status: offline
Tshark,
That pic of you and the "mini-me" pilot figure is awesome!! I'm sure that will be the hit of the field once somebody susses out that the figure is YOU I've spent 100's of hours in a 172 Cessna and your I panel and interior look great!
"The American taxpayer has always been politicaly deceived. Its their Birthright!"
Lord Mountjoy, The Mouse on the Moon
Hide Signatures
       Post #: 1450
Jump to:
Google
SITE MAP!   : :   FORUM RULES
2.516RCU1
