Weedwacker SST25
Tower Hobbies
Logged in as Guest
  Printable Version
All Forums >> Radios, Batteries, Clubhouse and more >> The Clubhouse >> Weedwacker SST25
Page: [1]
Login
Weedwacker SST25 - 4/26/2008 6:48:07 PM
FrancisPerson
Status: offline
I know this is a model airplane forum BUT there are lots of engine guys in our ranks. I have a Weedwacker SST25 and it is a POS. It only starts if I folow the directions "EXACTLY". Once running you have to keep goosing it else it will die at low throttle. The idle speed screw is set to max but after a while it dies when I let it go below 1/2 throttle. There are two screws on the carb and I do not know which is the low needle and which is the high needle or which you adjust 1st????
These numbers are stamped on the othe side: 1037 and T669 ???
My K&B Sportsters run better than this.
Francis
Click to see fullsize image.
Click for fullsize
Click for fullsize
Click for fullsize
< Message edited by FrancisPerson -- 4/26/2008 6:52:58 PM >
       Post #: 1
RE: Weedwacker SST25 - 4/26/2008 8:55:31 PM
outdoorhunting
Status: offline
I think I had a motor like that on a 4* 60. It was a little nose heavy, but had unlimited vertical!!! That's how I lost it. I got the nose up & gave it full throttle It went out of sight in about 2 seconds I imagine it's still going straight up & that was a year ago !!! I hope NASA don't give a call someday !!! Sorry Francis, I just couldn't resist ..
(in reply to FrancisPerson)
       Post #: 2
RE: Weedwacker SST25 - 4/26/2008 10:39:35 PM
Darkbird
Status: offline
Try changing the spark plug. can make a world of difference. Otherwise you may get better results if you ask someone in the gas engine forum.
_____________________________
"Whadda ya mean, "There's a loose nut behind the transmitter?!!"
(in reply to outdoorhunting)
       Post #: 3
RE: Weedwacker SST25 - 4/26/2008 10:58:02 PM
Jim Dines
Status: offline
There is an idle screw adjustment. Adjust it.
       Post #: 4
RE: Weedwacker SST25 - 5/3/2008 1:50:41 PM
Flypaper 2
Status: offline
The one closest to the engine is the idle mix. Back it out counter clockwise if you can, But I see no slot in it. May be a fixed jet. The one above with the philips/slot only controls the idle speed.
Gord
Dreamed I was a muffler. Woke up exhausted.
(in reply to Jim Dines)
       Post #: 5
Page:   [1]
Page: [1]
Jump to:
Google
SITE MAP!   : :   FORUM RULES
Kaango.com Classifieds
0.297RCU1
