isaacslaw
Joined: 9/29/2003 From: Nicosia, CYPRUS Status: offline
I would have to say the engine is definitely lean. Be very careful with this engine and make sure you don't stand in the prop arc or in front of it It will shred aluminum spinners when it backfires and throw the prop savagely. I would also say that castor oil in this engine might not be the best (don't flame me castor guys). I have a 110fz and had to spend quite a long while polishing my valve stems from the baked on castor oil it was causing all kinds of problems. These engines are much much much different than two strokes. They are much different than other 4 strokes. You need to spend time to fully understand how they work and how they tune. Start with the regulator screw flush with the housing. Set your high speed needle at full throttle and make sure its a LITTLE bit rich. Then set your low needle at idle (remembering that the low needle is an air bleed and works the opposite of most two strokes turn in to richen, out to lean). If the RPMs rise at idle, richen it. If they lower at idle, lean it. Finally, set your regulator for good transition. If transition is sluggish, try leaning the regulator, but it could also need adjustment the other way. You may find that the regulator can only be set properly by observing what it does in the air. With the YS 110, after every adjustment, you need to run the thottle up to full to sort of clear it out. You will not be able to tune it properly without doing this. Also, you must also check other things in the system fuel lines, fuel filters, tank pressure, etc. ALL of these things affect the tuning of the YS. Make sure all gaskets are set right and don't leak. Make sure all screws are tight but not too tight. YS requires patience to tune properly. Also, I do not know how many gallons of fuel are through it, but if it's new, you just need to run about 3 gallons through it before it finally settles down to its normal state. THese are really tremedous engines, but take some time to figure out. THere is a thread called "YS Club" in the 3d forum where there is a lot of information from some very knowledgeable people. Also, the support forum for YS is really good. Good luck.
